Thank you, i can't publish the file but here is what i did:
Data -> CoverageStores -> New
-> Data set description: TIFF with geographic information, Data set ID: any
-> Namespace: any, URL: correct path to local file
-> Submit
And this is the output of gdalinfo -mm -stats -checksum:
Driver: GTiff/GeoTIFF
Files: (...)
Size is 4677, 6623
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235630016,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 6623.0)
Upper Right ( 4677.0, 0.0)
Lower Right ( 4677.0, 6623.0)
Center ( 2338.5, 3311.5)
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
Computed Min/Max=0.000,255.000
Minimum=0.000, Maximum=255.000, Mean=249.464, StdDev=35.256
Checksum=62906
Metadata:
STATISTICS_MINIMUM=0
STATISTICS_MAXIMUM=255
STATISTICS_MEAN=249.46395439197
STATISTICS_STDDEV=35.255934549218
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
Minimum=0.000, Maximum=255.000, Mean=250.515, StdDev=29.163
Checksum=1215
Metadata:
STATISTICS_MEAN=250.51492177547
STATISTICS_STDDEV=29.162700857636
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
Minimum=0.000, Maximum=255.000, Mean=251.724, StdDev=24.064
Checksum=62560
Metadata:
STATISTICS_MEAN=251.7240543262
STATISTICS_STDDEV=24.063600023489
Simone Giannecchini wrote:
Ciao Filippo,
I guess that to help you out we need more info on your geotiff file,
as well as on how you are trying to load it.
If needed, we can give you the link to our own ftp server so that you
can upload a sample tiff file.
Anyway, it would be helpful if you could provide us with a gdalinfo on
your geotiff file in order to understand if it is correct or not.
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Fri, Dec 5, 2008 at 12:37 PM, Snamprogetti
<filippo.bultrighini@anonymised.com> wrote:
When trying to create a CoverageStore from a GeoTIFF file, i get the
following error:
The following exception was thrown:
org.vfny.geoserver.global.ConfigurationException: Could not obtain a
reader
for the CoverageDataSet. Please check the CoverageDataSet configuration!
The CoverageStore seems to be created anyway, but when i try to create a
new
Coverage with it i get the same error.
What does it mean?
Regards
View this message in context: http://www.nabble.com/Could-not-obtain-a-reader-for-the-CoverageDataSet-tp20852143p20912086.html
