Hello all,
I am trying to import the Natural Earth data set and am currently stuck due to the following exception when I click “Submit” on the “Coverage Data Set Editor” while trying to create a new Coverage Data Set:
java.lang.ArrayIndexOutOfBoundsException: 1
I followed the tutorial for “High performance coverage serving” and then the tutorial for “Using the ImageMosaic plugin”.
Here is a brief summary of what I did:
- Downloaded the “Landcover, shaded relief, water” TIF data from here: http://www.shadedrelief.com/natural/pages/download.html
- Created a tiled GeoTIFF file for each of the hemisphere TIF files.
- Added overviews to both GeoTIFFs.
- Created the index files/shape files.
- Created a properties file “natural_earth.properties” with the following entries:
Name=natural_earth
Levels=0.011111111111110,0.011111111111110
LevelsNum=1
Envelope2D=-180.005556,-89.994444,179.994444,90.005556
NumFiles=2 - Created a projection file “natural_earth.prj” with the following entries:
PROJCS[“Albers Equal area”,
GEOGCS[“WGS 84”,
DATUM[“World Geodetic System 1984”,
SPHEROID[“WGS 84”,6378137.0,298.257223563,
AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”,0.0,
AUTHORITY[“EPSG”,“8901”]],
UNIT[“degree”,0.017453292519943295],
AXIS[“Geodetic latitude”,NORTH],
AXIS[“Geodetic longitude”,EAST],
AUTHORITY[“EPSG”,“4326”]],
PROJECTION[“Albers Equal Area”,
AUTHORITY[“EPSG”,“9822”]],
UNIT[“m”,1.0],
AXIS[“Easting”,EAST],
AXIS[“Northing”,NORTH],
AUTHORITY[“EPSG”,“41111”]] - Created a new directoy “natural_earth” under GeoServer’s “coverages” directory and copied all related files there.
- Attempted to create a new Coverage Data Set from the web interface with the following parameters:
Namespace: topp
Type: ImageMosaic
URL: file:coverages/natural_earth/natural_earth.shp
I am running GeoServer 1.5.4 and am new to all of this stuff. So it is probably a configuration error on my part, but I’m not sure how to troubleshoot this problem?
Chris Ward
Software Engineer
CTSG Research & Development
Ball Aerospace & Technologies
This message and any enclosures are intended only for the addressee. Please
notify the sender by email if you are not the intended recipient. If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful. Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
