[Geoserver-users] Coverage - Display Pb with "Raster" style
got an image from ENVI as .tif and .tfw.
Put it as WMS, used the style "Raster". In the demo the image cannot display
(sometimes black, sometimes white), but the image is there, when i click,
the WFS at the bottom display the RGB balue..
how can i do to display it properly ?
is there a problem with de Raster style of geoserver ?
thks for help
View this message in context: http://www.nabble.com/Coverage---Display-Pb-with-"Raster"-style-tp19447377p19447377.html
Ciao Florent,
the default raster style does its best to show “something” to the user in case he does not specify his own style.
It might really be that on some combinations of bands/datatype/format results are quite funny.
However is you case, being an RGB image things should be quite straightforward.
Honestly I suspect that you are image is not a simple RGB image, therefore I think it would be of help having some more info on that image itself.
As I mentioned in another email seeing the results of a gdalinfo on it would be of great help.
Ciao,
Simone.
On Fri, Sep 12, 2008 at 2:34 AM, floflo <florent.gravin@anonymised.com> wrote:
Put it as WMS, used the style “Raster”. In the demo the image cannot display
the WFS at the bottom display the RGB balue…
thks for help
View this message in context: http://www.nabble.com/Coverage—Display-Pb-with-%22Raster%22-style-tp19447377p19447377.html
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Eng. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://www.geo-solutions.it/simone.giannecchini
