I cann’t save coverage settings to the server.
Several hours before,i can still save the settings of coverage to the server.
After that,i restart the server to test the function of Geocache.Then i lost the
settings of my coverages.i guess that is caused by my changing of some settings of the
server to test Geocache at first, so I setup Geoserver in another computer.The Result
is the same.The settings of featureTypes can be saved normally.
Can anyone help me on this?
The Server Console shows the following bug informations when the server are loading:
08 March 19:30:31 WARN [referencing.factory] - Axis elements found in a wkt defin
ition, the force longitude first axis order hint might not be respected:
PROJCS[“WGS84 / Simple Mercator”, GEOGCS[“WGS 84”, DATUM[“WGS_1984”, SPHEROID[“W
GS_1984”, 6378137.0, 298.257223563]], PRIMEM[“Greenwich”, 0.0], UNIT[“degree”, 0
.017453292519943295]], PROJECTION[“Mercator_1SP_Google”], PARAMETER[“latitude_of
_origin”, 0.0], PARAMETER[“central_meridian”, 0.0], PARAMETER[“scale_factor”, 1.
0], PARAMETER[“false_easting”, 0.0], PARAMETER[“false_northing”, 0.0], UNIT[“m”,
1.0], AXIS[“x”, EAST], AXIS[“y”, NORTH], AUTHORITY[“EPSG”,“54004”]]
08 March 19:30:32 WARN [geoserver.catalog] - Error loading ‘tyuio_xz/info.xml’, i
gnoring
08 March 19:30:32 INFO [geoserver.catalog] -
java.lang.NullPointerException
at org.geoserver.catalog.util.LegacyCoverageInfoReader.requestCRSs(Legac
yCoverageInfoReader.java:201)
at org.geoserver.catalog.util.LegacyCatalogImporter.readCoverage(LegacyC
atalogImporter.java:624)
at org.geoserver.catalog.util.LegacyCatalogImporter.imprt(LegacyCatalogI
mporter.java:221)
at org.geoserver.config.GeoServerLoader.initialize(GeoServerLoader.java:
112)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(
GeoServerLoader.java:76)
at org.springframework.beans.factory.support.AbstractAutowireCapableBean
Factory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanF
actory.java:350)
Factory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
Factory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
Factory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
Factory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getOb
ject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistr
y.getSingleton(DefaultSingletonBeanRegistry.java:221)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBe
an(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean
(AbstractBeanFactory.java:185)
(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver
.resolveReference(BeanDefinitionValueResolver.java:269)
.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.ConstructorResolver.resolve
ConstructorArguments(ConstructorResolver.java:495)
at org.springframework.beans.factory.support.ConstructorResolver.autowir
eConstructor(ConstructorResolver.java:162)
Factory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
Factory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
Factory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.
preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finish
BeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refres
h(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationCon
text(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationConte
xt(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitiali
zed(ContextLoaderListener.java:45)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.
java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.jav
a:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:
510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:
39)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection
.java:152)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHan
dlerCollection.java:156)
39)
.java:152)
39)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:
130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
39)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
XuZhen
