[Geoserver-users] coverage stoes
Hello,
Does anyone know if there are freely available satellite imagery close to what google offers? What is the best freely available coverage images of the United States?
Thank you so much
Signed,
Alessandro Ferrucci
Hi Alessandro,
Take a look at the GOES images you can find at URL:
http://www.gis.ssd.nesdis.noaa.gov/
You might need to play with the raster SLD to get imagery close to what
Google is offering.
Bernard
On Mon, 2009-05-18 at 11:47 -0400, Alessandro Ferrucci wrote:
Hello,
Thank you so much
Signed,
Alessandro Ferrucci
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables
unlimited royalty-free distribution of the report engine
for externally facing server and web deployment.
http://p.sf.net/sfu/businessobjects
_______________________________________________ Geoserver-users mailing list Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
Thank you so much, I will look at their data.
On Mon, May 18, 2009 at 12:08 PM, Bernard Clement <bernard@anonymised.com> wrote:
Hi Alessandro,
Google is offering.
Bernard
Hello,
Thank you so much
Signed,
Alessandro Ferrucci
Signed,
Alessandro Ferrucci
On Mon, May 18, 2009 at 11:47 AM, Alessandro Ferrucci
<alessandroferrucci@anonymised.com> wrote:
Hello,
the United States?
There are some insanely high res images available from NASA:
http://zulu.ssc.nasa.gov/mrsid/mrsid.pl
Each piece is one UTM zone. Be aware that even for just the US the
dataset will be *huge*. We had an entire set downloaded at one point
and I think it was something like 80+ gigs in MrSID format, which
means in GeoTIFF it would be simply astronomical.
If you don't need to see down to this level of detail, the TrueMarble
images are available for free at 250m/pixel resolution which is double
the best BlueMarble map:
http://www.unearthedoutdoors.net/global_data/true_marble/download
However I found the contrast on TrueMarble to bee a bit high (northern
Africa is simply blinding) so you might want to adjust that in your
SLD. I just went with BlueMarble 500m res images instead.
This message brought to you by Speed of Light Beer
When you're approaching infinite mass
It's Speed of Light time!
If I were you, I'd browser here:
http://edc.usgs.gov/
You can find very high res imagery, same as used by WorldWind.
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Mon, May 18, 2009 at 5:47 PM, Alessandro Ferrucci
Hello,
the United States?
Thank you so much
Signed,
Alessandro Ferrucci
