[Geoserver-users] Coverage with mosaick
Dear list,
being new to geoserver wcs - I'm trying setting up a new wcs with a gdal created image catalog|/
I use geoserver 1.6.4
I followed this howto:
http://geoserver.org/display/GEOSDOC/Using+the+ImageMosaic+plugin
Everything works fine until I try to setup a new "coverage"
My error message which appears when choosing the new created Coverage datastore and hitting "new" is
The following exception was thrown:
/|org.vfny.geoserver.global.ConfigurationException: Coverage dimensions: Invalid input file providedexists: false isDirectory: false canRead: false
|/I have setup my .properties file with the help of gdalinfo, so I think it is OK. I also have a .prj file
Any ideas? Thanks in advance!
Till
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams@anonymised.com http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
Ciao Till,
the message
"Invalid input file providedexists: false isDirectory: false canRead:
false" seems to indicate that either you are pointing the mosaic
reader to the wrong file or the file is somehow , locked/unreadable.
There is amissing space in the mesage but the first part is exists:
false which mens that the file you are pointing the mosaic towards
does not exist!
I might need more info to help you out on this.
Simone.
On Mon, Oct 20, 2008 at 5:09 PM, Till Adams <adams@anonymised.com> wrote:
Dear list,
Till
53111 Bonn
Germany
Till Adams
Geschäftsführung
Komplementärin:
vertreten durch:
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Eng. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://www.geo-solutions.it/simone.giannecchini
http://www.linkedin.com/in/simonegiannecchini
Simone, (list)
thank for your help! Just to complete this task:
In the end it was my fault in the "location" item of my index file I put in the full path to the data, not the pure filename.
I changed, so that my index file now is in the same directory as the tiff-tiles
and changed the location entry to "abc.tif" without any path and everything works fine!
Regards, Till
Ciao Till,
the log does not help too much, I do not find the error you pointed me
towards yesterday ( I would increase the logging level for debugging
and then i would send things back again), however:
1> I would use geoserver 1.6.5 instead of 1.6.4
2> did you double check permission on the data dir?
3> can you describe how you are trying to set up this coverage, it
might be that you are entering an incorrect path.
Simone.
On Tue, Oct 21, 2008 at 10:03 AM, Till Adams <adams@anonymised.com> wrote:
Simone,
thank you so much, get attached the log from yesterday. I think the time
between 13 and 17h is interesting.
The problem is, we have about 200 tiles (tif) and want to serve them as WCS
via geoserver. I've created
the files I sent you yesterday.
The problem appears when trying to setup a new coverage,
thanks al ot again!
Till
53111 Bonn
Germany
Till Adams
Geschäftsführung
Komplementärin:
vertreten durch:
127.0.0.1 - - [20/10/2008:08:23:52 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Aline&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_lines.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411335.6640625,4568126.953125,413894.3359375,4569498.046875&WIDTH=1819&HEIGHT=975
HTTP/1.1" 200 3482
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apolygon&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_polygons.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411335.6640625,4568126.953125,413894.3359375,4569498.046875&WIDTH=1819&HEIGHT=975
HTTP/1.1" 200 12169
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apoint&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_points.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411335.6640625,4568126.953125,413894.3359375,4569498.046875&WIDTH=1819&HEIGHT=975
HTTP/1.1" 200 3154
127.0.0.1 - - [20/10/2008:08:24:04 +0000] "GET
/geoserver/wfs?typename=cite%3Aline&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A23031&BBOX=410909.21875,4567898.4375,414320.78125,4569726.5625
HTTP/1.1" 200 4581
127.0.0.1 - - [20/10/2008:08:24:10 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Aline&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_lines.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411290.6640625,4568115.703125,413849.3359375,4569486.796875&WIDTH=1819&HEIGHT=975
HTTP/1.1" 200 3472
127.0.0.1 - - [20/10/2008:08:24:17 +0000] "GET
/geoserver/wfs?typename=cite%3Aline&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A23031&BBOX=410864.21875,4567887.1875,414275.78125,4569715.3125
HTTP/1.1" 200 4581
HTTP/1.1" 200 4581
HTTP/1.1" 200 3472
HTTP/1.1" 200 3472
127.0.0.1 - - [20/10/2008:08:25:15 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apolygon&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_polygons.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411290.6640625,4568115.703125,413849.3359375,4569486.796875&WIDTH=1819&HEIGHT=975
HTTP/1.1" 200 13087
127.0.0.1 - - [20/10/2008:08:25:23 +0000] "GET
HTTP/1.1" 200 3472
127.0.0.1 - - [20/10/2008:08:25:24 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apoint&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_points.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411290.6640625,4568115.703125,413849.3359375,4569486.796875&WIDTH=1819&HEIGHT=975
HTTP/1.1" 200 1829
127.0.0.1 - - [20/10/2008:08:25:32 +0000] "GET
HTTP/1.1" 200 13087
127.0.0.1 - - [20/10/2008:08:25:35 +0000] "GET
HTTP/1.1" 200 3472
127.0.0.1 - - [20/10/2008:12:08:12 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apoint&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_points.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411323.0078125,4568126.953125,413906.9921875,4569498.046875&WIDTH=1837&HEIGHT=975
HTTP/1.1" 200 1846
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Aline&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_lines.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411323.0078125,4568126.953125,413906.9921875,4569498.046875&WIDTH=1837&HEIGHT=975
HTTP/1.1" 200 3491
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apolygon&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_polygons.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411323.0078125,4568126.953125,413906.9921875,4569498.046875&WIDTH=1837&HEIGHT=975
HTTP/1.1" 200 11420
127.0.0.1 - - [20/10/2008:12:56:42 +0000] "GET /geoserver/ HTTP/1.1" 200
424
127.0.0.1 - - [20/10/2008:12:56:44 +0000] "GET /geoserver/style.css
HTTP/1.1" 200 1287
127.0.0.1 - - [20/10/2008:12:56:44 +0000] "GET /geoserver/gs.gif HTTP/1.1"
404 1393
127.0.0.1 - - [20/10/2008:12:56:44 +0000] "GET /geoserver/gs.ico HTTP/1.1"
404 1393
127.0.0.1 - - [20/10/2008:12:56:45 +0000] "GET /geoserver/gs.ico HTTP/1.1"
404 1393
127.0.0.1 - - [20/10/2008:12:56:45 +0000] "GET /geoserver/welcome.do
HTTP/1.1" 200 3329
127.0.0.1 - - [20/10/2008:12:56:50 +0000] "GET /geoserver/images/gs.ico
HTTP/1.1" 200 5694
127.0.0.1 - - [20/10/2008:12:56:50 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:12:58:30 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=6.756420135513948,50.727980256100935,7.5529289245446485,51.00965055251168
HTTP/1.1" 200 2397
127.0.0.1 - - [20/10/2008:12:58:31 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=752121.248966137,6573316.90201213,840788.201761059,6623000.970388597
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=752121.248966137,6573316.90201213,840788.201761059,6623000.970388597
HTTP/1.1" 200 1411
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=752121.248966137,6573316.90201213,840788.201761059,6623000.970388597
HTTP/1.1" 200 1189
127.0.0.1 - - [20/10/2008:12:58:51 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apoint&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_points.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411137.3828125,4568126.953125,414092.6171875,4569498.046875&WIDTH=2101&HEIGHT=975
HTTP/1.1" 200 2097
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Aline&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_lines.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411137.3828125,4568126.953125,414092.6171875,4569498.046875&WIDTH=2101&HEIGHT=975
HTTP/1.1" 200 3934
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apolygon&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_polygons.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411137.3828125,4568126.953125,414092.6171875,4569498.046875&WIDTH=2101&HEIGHT=975
HTTP/1.1" 200 12006
127.0.0.1 - - [20/10/2008:12:58:56 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.05511093140046,50.83380608761927,7.2542381286581365,50.90422362776622
HTTP/1.1" 200 1853
127.0.0.1 - - [20/10/2008:12:58:57 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=785371.3562642326,6591948.427653305,807538.0944629633,6604369.444747422
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=785371.3562642326,6591948.427653305,807538.0944629633,6604369.444747422
HTTP/1.1" 200 1411
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=785371.3562642326,6591948.427653305,807538.0944629633,6604369.444747422
HTTP/1.1" 200 1189
127.0.0.1 - - [20/10/2008:12:59:06 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=6.955547332771625,50.79855742002475,7.353801727286972,50.93939251390105
HTTP/1.1" 200 2397
127.0.0.1 - - [20/10/2008:12:59:07 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=774287.9871648676,6585737.919106247,818621.4635623284,6610579.95329448
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=774287.9871648676,6585737.919106247,818621.4635623284,6610579.95329448
HTTP/1.1" 200 1411
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=774287.9871648676,6585737.919106247,818621.4635623284,6610579.95329448
HTTP/1.1" 200 1189
127.0.0.1 - - [20/10/2008:12:59:42 +0000] "GET /geoserver/config/index.do
HTTP/1.1" 302 0
127.0.0.1 - - [20/10/2008:12:59:43 +0000] "GET /geoserver/admin/login.do
HTTP/1.1" 200 2784
127.0.0.1 - - [20/10/2008:12:59:44 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:12:59:49 +0000] "POST
/geoserver/j_acegi_security_check HTTP/1.1" 302 0
127.0.0.1 - - [20/10/2008:12:59:49 +0000] "GET
/geoserver/admin/login.do?login_error=1 HTTP/1.1" 200 2827
127.0.0.1 - - [20/10/2008:12:59:49 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:00:47 +0000] "POST
127.0.0.1 - - [20/10/2008:13:00:47 +0000] "GET /geoserver/config/index.do
HTTP/1.1" 200 2730
127.0.0.1 - - [20/10/2008:13:00:48 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:00:51 +0000] "GET
/geoserver/config/data/index.do HTTP/1.1" 200 2857
127.0.0.1 - - [20/10/2008:13:00:51 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:00:57 +0000] "GET
/geoserver/config/data/format.do HTTP/1.1" 200 2917
127.0.0.1 - - [20/10/2008:13:00:58 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:01:04 +0000] "GET
/geoserver/config/data/formatNew.do HTTP/1.1" 200 2932
127.0.0.1 - - [20/10/2008:13:01:05 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:02:22 +0000] "POST
/geoserver/config/data/formatNewSubmit.do HTTP/1.1" 200 3179
127.0.0.1 - - [20/10/2008:13:02:23 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:04:37 +0000] "POST
/geoserver/config/data/formatNewSubmit.do HTTP/1.1" 200 3178
127.0.0.1 - - [20/10/2008:13:04:37 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:17:42 +0000] "POST
127.0.0.1 - - [20/10/2008:13:17:43 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:21:41 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apoint&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_points.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411598.28125,4568126.953125,413631.71875,4569498.046875&WIDTH=1446&HEIGHT=975
HTTP/1.1" 200 3134
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Aline&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_lines.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411598.28125,4568126.953125,413631.71875,4569498.046875&WIDTH=1446&HEIGHT=975
HTTP/1.1" 200 3128
127.0.0.1 - - [20/10/2008:13:21:42 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apolygon&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_polygons.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411598.28125,4568126.953125,413631.71875,4569498.046875&WIDTH=1446&HEIGHT=975
HTTP/1.1" 200 14106
127.0.0.1 - - [20/10/2008:13:21:49 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apoint&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_points.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=412106.640625,4568469.7265625,413123.359375,4569155.2734375&WIDTH=1446&HEIGHT=975
HTTP/1.1" 200 1762
127.0.0.1 - - [20/10/2008:13:21:50 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Aline&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_lines.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=412106.640625,4568469.7265625,413123.359375,4569155.2734375&WIDTH=1446&HEIGHT=975
HTTP/1.1" 200 3620
127.0.0.1 - - [20/10/2008:13:21:51 +0000] "GET
HTTP/1.1" 200 3128
HTTP/1.1" 200 3134
HTTP/1.1" 200 14106
127.0.0.1 - - [20/10/2008:13:25:00 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 3291
127.0.0.1 - - [20/10/2008:13:25:01 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:25:17 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 3240
127.0.0.1 - - [20/10/2008:13:25:18 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:25:53 +0000] "GET
127.0.0.1 - - [20/10/2008:13:25:53 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:26:00 +0000] "POST
/geoserver/config/data/formatSelectSubmit.do HTTP/1.1" 200 3189
127.0.0.1 - - [20/10/2008:13:26:15 +0000] "GET
127.0.0.1 - - [20/10/2008:13:26:16 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:26:34 +0000] "POST
127.0.0.1 - - [20/10/2008:13:26:34 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:26:56 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 3242
127.0.0.1 - - [20/10/2008:13:27:07 +0000] "POST
127.0.0.1 - - [20/10/2008:13:27:07 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:27:25 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 3239
127.0.0.1 - - [20/10/2008:13:27:37 +0000] "POST
127.0.0.1 - - [20/10/2008:13:27:37 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:27:44 +0000] "POST
127.0.0.1 - - [20/10/2008:13:27:44 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:28:57 +0000] "GET
127.0.0.1 - - [20/10/2008:13:29:00 +0000] "GET
127.0.0.1 - - [20/10/2008:13:29:18 +0000] "GET /geoserver/config/index.do
HTTP/1.1" 200 2730
127.0.0.1 - - [20/10/2008:13:29:25 +0000] "GET
/geoserver/config/wcs/index.do HTTP/1.1" 200 2755
127.0.0.1 - - [20/10/2008:13:29:25 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:29:28 +0000] "GET
/geoserver/config/wcs/coverageplugins.do HTTP/1.1" 200 2838
127.0.0.1 - - [20/10/2008:13:29:29 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:31:15 +0000] "GET /geoserver/welcome.do
HTTP/1.1" 200 3337
127.0.0.1 - - [20/10/2008:13:31:15 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:31:18 +0000] "GET /geoserver/config/index.do
HTTP/1.1" 200 2730
127.0.0.1 - - [20/10/2008:13:31:20 +0000] "GET
127.0.0.1 - - [20/10/2008:13:31:25 +0000] "GET
/geoserver/config/data/coverageSelect.do HTTP/1.1" 200 2896
127.0.0.1 - - [20/10/2008:13:31:26 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:31:31 +0000] "GET
127.0.0.1 - - [20/10/2008:13:31:32 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:31:33 +0000] "GET
127.0.0.1 - - [20/10/2008:13:31:33 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:31:41 +0000] "POST
127.0.0.1 - - [20/10/2008:13:33:14 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 2936
127.0.0.1 - - [20/10/2008:13:33:14 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:33:19 +0000] "POST
/geoserver/config/data/formatSelectSubmit.do HTTP/1.1" 200 3207
127.0.0.1 - - [20/10/2008:13:33:34 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 3256
127.0.0.1 - - [20/10/2008:13:33:35 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:34:37 +0000] "POST
127.0.0.1 - - [20/10/2008:13:34:38 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:34:40 +0000] "POST
127.0.0.1 - - [20/10/2008:13:34:55 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 500 532
127.0.0.1 - - [20/10/2008:13:34:55 +0000] "GET
/geoserver/config/data/gs.ico HTTP/1.1" 404 1405
127.0.0.1 - - [20/10/2008:13:34:56 +0000] "GET
127.0.0.1 - - [20/10/2008:13:35:01 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:35:06 +0000] "POST
127.0.0.1 - - [20/10/2008:13:35:06 +0000] "GET
127.0.0.1 - - [20/10/2008:13:35:07 +0000] "GET
127.0.0.1 - - [20/10/2008:13:35:08 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:35:17 +0000] "POST
127.0.0.1 - - [20/10/2008:13:35:18 +0000] "GET
127.0.0.1 - - [20/10/2008:13:35:21 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:35:29 +0000] "GET
/geoserver/config/data/format.do HTTP/1.1" 200 2936
127.0.0.1 - - [20/10/2008:13:35:34 +0000] "POST
127.0.0.1 - - [20/10/2008:13:35:36 +0000] "POST
127.0.0.1 - - [20/10/2008:13:35:36 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:35:41 +0000] "POST
127.0.0.1 - - [20/10/2008:13:35:41 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:35:50 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 3255
127.0.0.1 - - [20/10/2008:13:35:51 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:41:23 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 2935
127.0.0.1 - - [20/10/2008:13:41:23 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:41:29 +0000] "GET
/geoserver/config/data/index.do HTTP/1.1" 200 2876
127.0.0.1 - - [20/10/2008:13:41:30 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:41:32 +0000] "GET
/geoserver/config/data/coverageSelect.do HTTP/1.1" 200 2914
127.0.0.1 - - [20/10/2008:13:41:32 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:41:35 +0000] "POST
/geoserver/config/data/coverageSelectSubmit.do HTTP/1.1" 200 6824
127.0.0.1 - - [20/10/2008:13:41:37 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:41:56 +0000] "POST
/geoserver/config/data/coverageEditorSubmit.do HTTP/1.1" 200 6824
127.0.0.1 - - [20/10/2008:13:41:56 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:47:33 +0000] "GET
127.0.0.1 - - [20/10/2008:13:47:35 +0000] "GET
/geoserver/config/data/format.do HTTP/1.1" 200 2935
127.0.0.1 - - [20/10/2008:13:47:35 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:47:38 +0000] "POST
127.0.0.1 - - [20/10/2008:13:47:39 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:47:44 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 2937
127.0.0.1 - - [20/10/2008:13:47:45 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:47:47 +0000] "POST
/geoserver/admin/saveToGeoServer.do HTTP/1.1" 200 2749
127.0.0.1 - - [20/10/2008:13:47:50 +0000] "POST
/geoserver/admin/saveToXML.do HTTP/1.1" 200 2731
127.0.0.1 - - [20/10/2008:13:47:51 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:47:52 +0000] "POST
/geoserver/admin/loadFromXML.do HTTP/1.1" 200 2731
127.0.0.1 - - [20/10/2008:13:47:54 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:47:55 +0000] "GET
/geoserver/config/data/index.do HTTP/1.1" 200 2858
127.0.0.1 - - [20/10/2008:13:47:55 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:47:58 +0000] "GET
/geoserver/config/data/coverageSelect.do HTTP/1.1" 200 2897
127.0.0.1 - - [20/10/2008:13:47:59 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:48:02 +0000] "POST
/geoserver/config/data/coverageSelectSubmit.do HTTP/1.1" 200 6807
127.0.0.1 - - [20/10/2008:13:48:03 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:48:05 +0000] "POST
/geoserver/config/data/coverageEditorSubmit.do HTTP/1.1" 200 6765
127.0.0.1 - - [20/10/2008:13:48:06 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:48:12 +0000] "POST
/geoserver/config/data/coverageEditorSubmit.do HTTP/1.1" 200 6826
127.0.0.1 - - [20/10/2008:13:49:51 +0000] "POST
127.0.0.1 - - [20/10/2008:13:49:51 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:50:09 +0000] "POST
127.0.0.1 - - [20/10/2008:13:50:10 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:50:20 +0000] "POST
/geoserver/config/data/coverageEditorSubmit.do HTTP/1.1" 200 6820
127.0.0.1 - - [20/10/2008:13:56:47 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=6.512489318879458,50.608081492131525,8.105506896940856,51.17116374949055
HTTP/1.1" 200 2397
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=724966.9946733781,6552258.500723497,902300.9002632217,6651626.637476427
HTTP/1.1" 200 262
127.0.0.1 - - [20/10/2008:13:56:48 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=724966.9946733781,6552258.500723497,902300.9002632217,6651626.637476427
HTTP/1.1" 200 1411
127.0.0.1 - - [20/10/2008:13:56:49 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=724966.9946733781,6552258.500723497,902300.9002632217,6651626.637476427
HTTP/1.1" 200 1189
127.0.0.1 - - [20/10/2008:13:58:00 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=6.772384643570588,50.764259357122114,7.568893432601287,51.04571104080775
HTTP/1.1" 200 2397
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=753898.4098735198,6579699.39387306,842565.3626684418,6629383.462249527
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=753898.4098735198,6579699.39387306,842565.3626684418,6629383.462249527
HTTP/1.1" 200 1411
127.0.0.1 - - [20/10/2008:13:58:01 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=753898.4098735198,6579699.39387306,842565.3626684418,6629383.462249527
HTTP/1.1" 200 1189
127.0.0.1 - - [20/10/2008:13:58:04 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.050991058351599,50.8885784619392,7.150554656980435,50.92375916823052
HTTP/1.1" 200 804
127.0.0.1 - - [20/10/2008:13:58:05 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=784912.7340943643,6601608.15710138,795996.1031937294,6607818.665648436
HTTP/1.1" 200 262
127.0.0.1 - - [20/10/2008:13:58:06 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=784912.7340943643,6601608.15710138,795996.1031937294,6607818.665648436
HTTP/1.1" 200 782
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=784912.7340943643,6601608.15710138,795996.1031937294,6607818.665648436
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:13:58:55 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=6.906280517586076,50.83873877820127,7.304534912101424,50.979452621984954
HTTP/1.1" 200 1634
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=768803.6303861695,6592817.898850183,813137.1067836303,6617659.933038416
HTTP/1.1" 200 262
127.0.0.1 - - [20/10/2008:13:58:56 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=768803.6303861695,6592817.898850183,813137.1067836303,6617659.933038416
HTTP/1.1" 200 1411
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=768803.6303861695,6592817.898850183,813137.1067836303,6617659.933038416
HTTP/1.1" 200 834
127.0.0.1 - - [20/10/2008:13:58:59 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.080774307251474,50.90372295561231,7.105665206908684,50.91251776399826
HTTP/1.1" 200 329
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=788228.1901956062,6604281.064433768,790999.0324704476,6605833.691570532
HTTP/1.1" 200 262
127.0.0.1 - - [20/10/2008:13:59:00 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=788228.1901956062,6604281.064433768,790999.0324704476,6605833.691570532
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=788228.1901956062,6604281.064433768,790999.0324704476,6605833.691570532
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:13:59:43 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=6.99365615845124,50.87292803971285,7.192783355708916,50.94328650904165
HTTP/1.1" 200 1104
127.0.0.1 - - [20/10/2008:13:59:44 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=778530.2422336616,6598846.869455092,800696.9804323922,6611267.886549208
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=778530.2422336616,6598846.869455092,800696.9804323922,6611267.886549208
HTTP/1.1" 200 1411
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=778530.2422336616,6598846.869455092,800696.9804323922,6611267.886549208
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:13:59:52 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=6.694965362564728,50.76719087077016,7.491474151595428,51.048624884685495
HTTP/1.1" 200 2397
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=745280.1349355659,6580215.343813917,833947.0877304879,6629899.412190383
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=745280.1349355659,6580215.343813917,833947.0877304879,6629899.412190383
HTTP/1.1" 200 1411
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=745280.1349355659,6580215.343813917,833947.0877304879,6629899.412190383
HTTP/1.1" 200 1189
127.0.0.1 - - [20/10/2008:14:00:40 +0000] "GET /geoserver/welcome.do
HTTP/1.1" 200 3337
127.0.0.1 - - [20/10/2008:14:00:41 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:00:51 +0000] "GET
/geoserver/ows?service=WCS&request=GetCapabilities HTTP/1.1" 200 1203
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.074680328373115,50.82025205614419,7.273807525630791,50.89069005408637
HTTP/1.1" 200 2079
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=787549.8115700568,6589559.770519735,809716.5497687875,6601980.787613852
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=787549.8115700568,6589559.770519735,809716.5497687875,6601980.787613852
HTTP/1.1" 200 1411
127.0.0.1 - - [20/10/2008:14:00:52 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=787549.8115700568,6589559.770519735,809716.5497687875,6601980.787613852
HTTP/1.1" 200 1189
127.0.0.1 - - [20/10/2008:14:01:09 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.149009704590837,50.851501727388296,7.198791503905257,50.86910940554266
HTTP/1.1" 200 782
127.0.0.1 - - [20/10/2008:14:01:10 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=795824.1198804434,6595068.01386958,801365.8044301262,6598173.26814311
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795824.1198804434,6595068.01386958,801365.8044301262,6598173.26814311
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795824.1198804434,6595068.01386958,801365.8044301262,6598173.26814311
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:01:36 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.162088155746957,50.855789132129075,7.1869790554041675,50.86459299292974
HTTP/1.1" 200 672
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=797280.0064033049,6595824.023852327,800050.8486781462,6597376.65098909
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=797280.0064033049,6595824.023852327,800050.8486781462,6597376.65098909
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=797280.0064033049,6595824.023852327,800050.8486781462,6597376.65098909
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:02:14 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.1679353713991745,50.85822729077044,7.180380821227778,50.86262919879307
HTTP/1.1" 200 612
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=797930.9154721775,6596253.982136358,799316.336609598,6597030.295704741
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=797930.9154721775,6596253.982136358,799316.336609598,6597030.295704741
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:02:15 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=797930.9154721775,6596253.982136358,799316.336609598,6597030.295704741
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:03:02 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.170952856540806,50.859468332287534,7.177175581455107,50.86166927966577
HTTP/1.1" 200 612
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=798266.8203815734,6596472.842846213,798959.5309502836,6596860.999630405
HTTP/1.1" 200 262
127.0.0.1 - - [20/10/2008:14:03:03 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=798266.8203815734,6596472.842846213,798959.5309502836,6596860.999630405
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=798266.8203815734,6596472.842846213,798959.5309502836,6596860.999630405
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:03:20 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=6.974937021740281,50.790085302911294,7.37319141625563,50.93094595320085
HTTP/1.1" 200 2397
127.0.0.1 - - [20/10/2008:14:03:21 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=776446.4374671981,6584245.904144192,820779.9138646589,6609087.938332425
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=776446.4374671981,6584245.904144192,820779.9138646589,6609087.938332425
HTTP/1.1" 200 1411
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=776446.4374671981,6584245.904144192,820779.9138646589,6609087.938332425
HTTP/1.1" 200 1189
127.0.0.1 - - [20/10/2008:14:03:27 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.1418428421023,50.85772612412464,7.154288291930904,50.86212807945665
HTTP/1.1" 200 329
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=795026.3083977452,6596165.601822414,796411.7295351657,6596941.915390798
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795026.3083977452,6596165.601822414,796411.7295351657,6596941.915390798
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795026.3083977452,6596165.601822414,796411.7295351657,6596941.915390798
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:03:49 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.14461356401456,50.85918728075782,7.15083628892886,50.86138824140185
HTTP/1.1" 200 329
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=795334.7437501048,6596423.278210693,796027.454318815,6596811.434994885
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795334.7437501048,6596423.278210693,796027.454318815,6596811.434994885
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795334.7437501048,6596423.278210693,796027.454318815,6596811.434994885
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:03:57 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.1467244625092805,50.859712134652085,7.152947187423581,50.86191307052269
HTTP/1.1" 200 329
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=795569.7278956206,6596515.838674619,796262.4384643309,6596903.995458811
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795569.7278956206,6596515.838674619,796262.4384643309,6596903.995458811
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795569.7278956206,6596515.838674619,796262.4384643309,6596903.995458811
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:04:00 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.148674428463107,50.860172646751685,7.154897153377408,50.862373560885686
HTTP/1.1" 200 329
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=795786.7971126346,6596597.053017161,796479.5076813449,6596985.209801353
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795786.7971126346,6596597.053017161,796479.5076813449,6596985.209801353
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795786.7971126346,6596597.053017161,796479.5076813449,6596985.209801353
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:04:03 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=796047.1607401948,6596793.818648538,796739.8713089051,6597181.975432729
HTTP/1.1" 200 262
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.151013314724094,50.861288353900086,7.157236039638396,50.863489215371025
HTTP/1.1" 200 329
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=796047.1607401948,6596793.818648538,796739.8713089051,6597181.975432729
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=796047.1607401948,6596793.818648538,796739.8713089051,6597181.975432729
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:04:06 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.152568995952732,50.86204681635416,7.1587917208670335,50.86424764202411
HTTP/1.1" 200 329
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=796220.3383823794,6596927.583448014,796913.0489510896,6597315.740232206
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=796220.3383823794,6596927.583448014,796913.0489510896,6597315.740232206
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=796220.3383823794,6596927.583448014,796913.0489510896,6597315.740232206
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:04:10 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.154497504234439,50.86292038728483,7.1607202291487395,50.86512117171994
HTTP/1.1" 200 329
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=796435.0189422597,6597081.651833136,797127.72951097,6597469.808617327
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=796435.0189422597,6597081.651833136,797127.72951097,6597469.808617327
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=796435.0189422597,6597081.651833136,797127.72951097,6597469.808617327
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:04:19 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.107827067377172,50.84641119251666,7.207390666006007,50.88162374375978
HTTP/1.1" 200 1085
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=791239.6896769323,6594170.475951703,802323.0587762974,6600380.98449876
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=791239.6896769323,6594170.475951703,802323.0587762974,6600380.98449876
HTTP/1.1" 200 1411
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=791239.6896769323,6594170.475951703,802323.0587762974,6600380.98449876
HTTP/1.1" 200 834
127.0.0.1 - - [20/10/2008:14:04:44 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.152807712555429,50.86814792707458,7.177698612212637,50.87694945447703
HTTP/1.1" 200 674
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=796246.9121930317,6598003.673486718,799017.7544678731,6599556.300623481
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=796246.9121930317,6598003.673486718,799017.7544678731,6599556.300623481
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:04:45 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=796246.9121930317,6598003.673486718,799017.7544678731,6599556.300623481
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:18:08 +0000] "GET /geoserver/config/index.do
HTTP/1.1" 200 2731
127.0.0.1 - - [20/10/2008:14:18:08 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:18:11 +0000] "GET
127.0.0.1 - - [20/10/2008:14:18:12 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:18:13 +0000] "GET
/geoserver/config/data/format.do HTTP/1.1" 200 2918
127.0.0.1 - - [20/10/2008:14:18:14 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:18:18 +0000] "POST
/geoserver/config/data/formatSelectSubmit.do HTTP/1.1" 200 3191
127.0.0.1 - - [20/10/2008:14:18:50 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 2930
127.0.0.1 - - [20/10/2008:14:18:50 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:18:52 +0000] "POST
/geoserver/admin/saveToGeoServer.do HTTP/1.1" 200 2743
127.0.0.1 - - [20/10/2008:14:18:54 +0000] "POST
127.0.0.1 - - [20/10/2008:14:18:55 +0000] "POST
127.0.0.1 - - [20/10/2008:14:18:57 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:18:59 +0000] "GET
127.0.0.1 - - [20/10/2008:14:19:00 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:19:01 +0000] "GET
127.0.0.1 - - [20/10/2008:14:19:02 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:19:06 +0000] "POST
127.0.0.1 - - [20/10/2008:14:19:10 +0000] "POST
/geoserver/config/data/coverageEditorSubmit.do HTTP/1.1" 200 6807
127.0.0.1 - - [20/10/2008:14:19:10 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:19:14 +0000] "POST
/geoserver/config/data/coverageEditorSubmit.do HTTP/1.1" 200 6868
127.0.0.1 - - [20/10/2008:14:20:20 +0000] "POST
/geoserver/admin/saveToGeoServer.do HTTP/1.1" 200 2740
127.0.0.1 - - [20/10/2008:14:20:21 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:20:22 +0000] "POST
/geoserver/admin/saveToXML.do HTTP/1.1" 200 2739
127.0.0.1 - - [20/10/2008:14:20:23 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:20:24 +0000] "POST
127.0.0.1 - - [20/10/2008:14:20:26 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:20:29 +0000] "GET
127.0.0.1 - - [20/10/2008:14:20:30 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:20:33 +0000] "GET
/geoserver/config/wcs/coverageplugins.do HTTP/1.1" 200 2837
127.0.0.1 - - [20/10/2008:14:20:42 +0000] "GET
127.0.0.1 - - [20/10/2008:14:20:43 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:20:46 +0000] "GET
/geoserver/config/wcs/content.do HTTP/1.1" 200 2845
127.0.0.1 - - [20/10/2008:14:20:46 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:20:51 +0000] "GET
127.0.0.1 - - [20/10/2008:14:20:54 +0000] "GET
/geoserver/config/wcs/description.do HTTP/1.1" 200 3188
127.0.0.1 - - [20/10/2008:14:20:54 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:21:00 +0000] "GET
127.0.0.1 - - [20/10/2008:14:21:00 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:21:05 +0000] "GET /geoserver/config/index.do
HTTP/1.1" 200 2731
127.0.0.1 - - [20/10/2008:14:21:05 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:21:09 +0000] "GET
127.0.0.1 - - [20/10/2008:14:21:10 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:21:28 +0000] "GET /geoserver/wcs? HTTP/1.1"
200 621
127.0.0.1 - - [20/10/2008:14:21:49 +0000] "GET
/geoserver/wcs?service=wcs&Request=Capabilities&version=1.0.0 HTTP/1.1" 200
260
127.0.0.1 - - [20/10/2008:14:22:01 +0000] "GET
/geoserver/wcs?service=wcs&Request=getCapabilities&version=1.0.0 HTTP/1.1"
200 1203
127.0.0.1 - - [20/10/2008:14:22:14 +0000] "GET
/geoserver/wcs?service=wms&Request=getCapabilities&version=1.0.0 HTTP/1.1"
200 15790
127.0.0.1 - - [20/10/2008:14:22:21 +0000] "GET
/geoserver/wms?service=wms&Request=getCapabilities&version=1.0.0 HTTP/1.1"
200 15790
127.0.0.1 - - [20/10/2008:14:22:31 +0000] "GET
/geoserver/wms?service=wms&Request=getCapabilities&version=1.1.1 HTTP/1.1"
200 15790
127.0.0.1 - - [20/10/2008:14:24:33 +0000] "GET
/geoserver/wcs?service=wcs&request=GetCapabilities&version=1.0.0&SERVICE=WMS&REQUEST=GetCapabilities
HTTP/1.1" 200 136395
127.0.0.1 - - [20/10/2008:14:24:51 +0000] "GET
127.0.0.1 - - [20/10/2008:14:24:53 +0000] "GET
/geoserver/wcs?service=wcs&request=GetCapabilities&version=1.0.0&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&BBOX=6.346175,36.491772,20.829683,46.590767&SRS=EPSG:4326&WIDTH=774&HEIGHT=540&LAYERS=nurc%3Amosaic&STYLES=&FORMAT=image/png&TRANSPARENT=TRUE
HTTP/1.1" 200 4998
127.0.0.1 - - [20/10/2008:14:28:50 +0000] "GET
127.0.0.1 - - [20/10/2008:14:28:59 +0000] "GET
127.0.0.1 - - [20/10/2008:14:29:01 +0000] "GET
/geoserver/wcs?service=wcs&request=GetCapabilities&version=1.0.0&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&BBOX=-130.851680,20.705200,-62.005400,54.114100&SRS=EPSG:4326&WIDTH=959&HEIGHT=465&LAYERS=nurc%3AImg_Sample&STYLES=&FORMAT=image/png&TRANSPARENT=TRUE
HTTP/1.1" 200 4998
127.0.0.1 - - [20/10/2008:14:38:00 +0000] "GET
HTTP/1.1" 200 2097
HTTP/1.1" 200 3934
127.0.0.1 - - [20/10/2008:14:38:01 +0000] "GET
HTTP/1.1" 200 12006
127.0.0.1 - - [20/10/2008:14:40:52 +0000] "GET
HTTP/1.1" 200 2097
HTTP/1.1" 200 12006
HTTP/1.1" 200 3934
127.0.0.1 - - [20/10/2008:14:44:47 +0000] "GET
/geoserver/config/data/store.do HTTP/1.1" 200 2912
127.0.0.1 - - [20/10/2008:14:44:48 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:44:52 +0000] "GET
127.0.0.1 - - [20/10/2008:14:44:54 +0000] "GET
127.0.0.1 - - [20/10/2008:14:44:58 +0000] "GET
127.0.0.1 - - [20/10/2008:14:45:08 +0000] "POST
/geoserver/config/data/formatNewSubmit.do HTTP/1.1" 200 3175
127.0.0.1 - - [20/10/2008:14:45:38 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 500 610
127.0.0.1 - - [20/10/2008:14:45:38 +0000] "GET
127.0.0.1 - - [20/10/2008:14:45:39 +0000] "GET
127.0.0.1 - - [20/10/2008:14:45:46 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:46:20 +0000] "POST
127.0.0.1 - - [20/10/2008:14:46:22 +0000] "GET
127.0.0.1 - - [20/10/2008:14:46:38 +0000] "POST
127.0.0.1 - - [20/10/2008:14:46:39 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:46:41 +0000] "GET
/geoserver/config/data/index.do HTTP/1.1" 200 2869
127.0.0.1 - - [20/10/2008:14:46:41 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:46:43 +0000] "GET
127.0.0.1 - - [20/10/2008:14:46:44 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:46:48 +0000] "GET
/geoserver/config/data/namespace.do HTTP/1.1" 200 2967
127.0.0.1 - - [20/10/2008:14:46:51 +0000] "GET
/geoserver/config/data/namespaceNew.do HTTP/1.1" 200 2768
127.0.0.1 - - [20/10/2008:14:46:52 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:46:58 +0000] "POST
/geoserver/config/data/namespaceNewSubmit.do HTTP/1.1" 200 2859
127.0.0.1 - - [20/10/2008:14:46:59 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:47:04 +0000] "POST
/geoserver/config/data/namespaceSubmit.do HTTP/1.1" 200 2895
127.0.0.1 - - [20/10/2008:14:47:04 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:47:10 +0000] "GET
127.0.0.1 - - [20/10/2008:14:47:11 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:47:12 +0000] "GET
127.0.0.1 - - [20/10/2008:14:47:13 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:47:21 +0000] "GET
/geoserver/config/data/formatNew.do HTTP/1.1" 200 2942
127.0.0.1 - - [20/10/2008:14:47:32 +0000] "POST
/geoserver/config/data/formatNewSubmit.do HTTP/1.1" 200 3192
127.0.0.1 - - [20/10/2008:14:47:33 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:47:48 +0000] "POST
127.0.0.1 - - [20/10/2008:14:47:48 +0000] "GET
127.0.0.1 - - [20/10/2008:14:47:49 +0000] "GET
127.0.0.1 - - [20/10/2008:14:48:28 +0000] "POST
127.0.0.1 - - [20/10/2008:14:48:28 +0000] "GET /geoserver/style.css
HTTP/1.1" 304 0
127.0.0.1 - - [20/10/2008:14:48:29 +0000] "GET
/geoserver/config/data/gs.gif HTTP/1.1" 404 1405
127.0.0.1 - - [20/10/2008:14:48:31 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:48:46 +0000] "POST
127.0.0.1 - - [20/10/2008:14:48:47 +0000] "GET
127.0.0.1 - - [20/10/2008:14:48:57 +0000] "GET
/geoserver/config/data/format.do HTTP/1.1" 200 2950
127.0.0.1 - - [20/10/2008:14:48:57 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:49:01 +0000] "POST
/geoserver/config/data/formatSelectSubmit.do HTTP/1.1" 200 3199
127.0.0.1 - - [20/10/2008:14:49:06 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 2950
127.0.0.1 - - [20/10/2008:14:49:09 +0000] "POST
127.0.0.1 - - [20/10/2008:14:49:09 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:49:11 +0000] "POST
127.0.0.1 - - [20/10/2008:14:49:11 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:49:12 +0000] "POST
127.0.0.1 - - [20/10/2008:14:49:14 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:49:15 +0000] "GET
127.0.0.1 - - [20/10/2008:14:49:16 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:49:18 +0000] "GET
127.0.0.1 - - [20/10/2008:14:49:18 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:49:27 +0000] "GET
/geoserver/config/data/coverageNew.do HTTP/1.1" 200 2819
127.0.0.1 - - [20/10/2008:14:49:34 +0000] "POST
/geoserver/config/data/coverageNewSubmit.do HTTP/1.1" 500 610
127.0.0.1 - - [20/10/2008:14:49:34 +0000] "GET
127.0.0.1 - - [20/10/2008:14:49:39 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:49:42 +0000] "POST
127.0.0.1 - - [20/10/2008:14:49:43 +0000] "GET
127.0.0.1 - - [20/10/2008:14:49:45 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:49:48 +0000] "POST
/geoserver/config/data/coverageNewSubmit.do HTTP/1.1" 200 6835
127.0.0.1 - - [20/10/2008:14:49:48 +0000] "GET
/geoserver/config/data/colorpicker.jpg HTTP/1.1" 404 1414
127.0.0.1 - - [20/10/2008:14:49:56 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:59:04 +0000] "POST
127.0.0.1 - - [20/10/2008:14:59:04 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:59:14 +0000] "GET
127.0.0.1 - - [20/10/2008:14:59:17 +0000] "GET
/geoserver/config/data/format.do HTTP/1.1" 200 2939
127.0.0.1 - - [20/10/2008:14:59:17 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:59:18 +0000] "GET
/geoserver/config/data/formatNew.do HTTP/1.1" 200 2933
127.0.0.1 - - [20/10/2008:14:59:19 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:59:40 +0000] "POST
/geoserver/config/data/formatNewSubmit.do HTTP/1.1" 200 3182
127.0.0.1 - - [20/10/2008:14:59:54 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 2947
127.0.0.1 - - [20/10/2008:14:59:55 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:00:08 +0000] "POST
/geoserver/admin/saveToGeoServer.do HTTP/1.1" 200 2745
127.0.0.1 - - [20/10/2008:15:00:09 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:00:10 +0000] "POST
/geoserver/admin/saveToXML.do HTTP/1.1" 200 2741
127.0.0.1 - - [20/10/2008:15:00:12 +0000] "POST
/geoserver/admin/loadFromXML.do HTTP/1.1" 200 2730
127.0.0.1 - - [20/10/2008:15:00:14 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:00:20 +0000] "GET
127.0.0.1 - - [20/10/2008:15:00:27 +0000] "GET
/geoserver/config/data/coverageSelect.do HTTP/1.1" 200 2895
127.0.0.1 - - [20/10/2008:15:00:28 +0000] "GET
/geoserver/config/data/coverageNew.do HTTP/1.1" 200 2818
127.0.0.1 - - [20/10/2008:15:00:33 +0000] "POST
/geoserver/config/data/coverageNewSubmit.do HTTP/1.1" 500 550
127.0.0.1 - - [20/10/2008:15:00:35 +0000] "GET
127.0.0.1 - - [20/10/2008:15:02:01 +0000] "GET
127.0.0.1 - - [20/10/2008:15:02:05 +0000] "POST
127.0.0.1 - - [20/10/2008:15:02:05 +0000] "GET /geoserver/style.css
HTTP/1.1" 304 0
127.0.0.1 - - [20/10/2008:15:02:06 +0000] "GET
127.0.0.1 - - [20/10/2008:15:02:21 +0000] "POST
/geoserver/admin/saveToGeoServer.do HTTP/1.1" 200 2738
127.0.0.1 - - [20/10/2008:15:02:23 +0000] "POST
/geoserver/admin/saveToXML.do HTTP/1.1" 200 2737
127.0.0.1 - - [20/10/2008:15:02:23 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:02:24 +0000] "POST
127.0.0.1 - - [20/10/2008:15:02:26 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:02:27 +0000] "GET
127.0.0.1 - - [20/10/2008:15:02:29 +0000] "GET
127.0.0.1 - - [20/10/2008:15:02:29 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:02:40 +0000] "GET
127.0.0.1 - - [20/10/2008:15:02:40 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:02:44 +0000] "POST
127.0.0.1 - - [20/10/2008:15:02:46 +0000] "GET
127.0.0.1 - - [20/10/2008:15:03:04 +0000] "GET
HTTP/1.1" 200 2097
HTTP/1.1" 200 3934
HTTP/1.1" 200 12006
127.0.0.1 - - [20/10/2008:15:03:33 +0000] "GET
127.0.0.1 - - [20/10/2008:15:04:51 +0000] "GET
127.0.0.1 - - [20/10/2008:15:04:53 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:04:57 +0000] "GET /geoserver/welcome.do
HTTP/1.1" 200 3337
127.0.0.1 - - [20/10/2008:15:04:57 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:06:45 +0000] "GET /geoserver/config/index.do
HTTP/1.1" 200 2730
127.0.0.1 - - [20/10/2008:15:06:45 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:06:47 +0000] "GET
127.0.0.1 - - [20/10/2008:15:06:47 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:06:49 +0000] "GET
127.0.0.1 - - [20/10/2008:15:06:50 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:06:52 +0000] "GET
127.0.0.1 - - [20/10/2008:15:06:53 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:06:58 +0000] "POST
127.0.0.1 - - [20/10/2008:15:06:58 +0000] "GET
127.0.0.1 - - [20/10/2008:15:06:59 +0000] "GET
127.0.0.1 - - [20/10/2008:15:35:06 +0000] "POST
127.0.0.1 - - [20/10/2008:15:35:07 +0000] "GET
127.0.0.1 - - [20/10/2008:15:35:46 +0000] "GET
127.0.0.1 - - [20/10/2008:15:36:02 +0000] "GET
127.0.0.1 - - [20/10/2008:15:36:02 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:36:04 +0000] "GET
/geoserver/config/data/format.do HTTP/1.1" 200 2938
127.0.0.1 - - [20/10/2008:15:36:04 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:36:08 +0000] "POST
/geoserver/config/data/formatSelectSubmit.do HTTP/1.1" 200 3197
127.0.0.1 - - [20/10/2008:15:36:16 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 2949
127.0.0.1 - - [20/10/2008:15:36:17 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:36:19 +0000] "POST
127.0.0.1 - - [20/10/2008:15:36:20 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:36:21 +0000] "POST
127.0.0.1 - - [20/10/2008:15:36:21 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:36:23 +0000] "POST
127.0.0.1 - - [20/10/2008:15:36:25 +0000] "GET
127.0.0.1 - - [20/10/2008:15:36:26 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:36:28 +0000] "GET
127.0.0.1 - - [20/10/2008:15:36:29 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:36:32 +0000] "GET
127.0.0.1 - - [20/10/2008:15:36:32 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:36:41 +0000] "GET
127.0.0.1 - - [20/10/2008:15:36:42 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:36:50 +0000] "POST
127.0.0.1 - - [20/10/2008:15:36:51 +0000] "GET
127.0.0.1 - - [20/10/2008:15:36:56 +0000] "POST
127.0.0.1 - - [20/10/2008:15:36:56 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:36:57 +0000] "GET
127.0.0.1 - - [20/10/2008:15:37:01 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:15:37:06 +0000] "POST
127.0.0.1 - - [20/10/2008:15:37:08 +0000] "GET
127.0.0.1 - - [20/10/2008:18:54:17 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apoint&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_points.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411812.3828125,4568126.953125,413417.6171875,4569498.046875&WIDTH=1141&HEIGHT=975
HTTP/1.1" 200 2841
127.0.0.1 - - [20/10/2008:18:54:18 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Aline&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_lines.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411812.3828125,4568126.953125,413417.6171875,4569498.046875&WIDTH=1141&HEIGHT=975
HTTP/1.1" 200 2815
127.0.0.1 - - [20/10/2008:18:54:19 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apoint&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_points.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411329.3359375,4568126.953125,413900.6640625,4569498.046875&WIDTH=1828&HEIGHT=975
HTTP/1.1" 200 1838
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Aline&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_lines.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411329.3359375,4568126.953125,413900.6640625,4569498.046875&WIDTH=1828&HEIGHT=975
HTTP/1.1" 200 3483
127.0.0.1 - - [20/10/2008:18:54:20 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apolygon&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_polygons.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411329.3359375,4568126.953125,413900.6640625,4569498.046875&WIDTH=1828&HEIGHT=975
HTTP/1.1" 200 12239
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams@anonymised.com http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
Ciao Till,
I am glad that things worked out in the end.
Btw, are you preprocessing your data, adding overviews and the like?
Simone.
On Tue, Oct 21, 2008 at 4:14 PM, Till Adams <adams@anonymised.com> wrote:
Simone, (list)
thank for your help! Just to complete this task:
In the end it was my fault in the "location" item of my index file I put in
the full path to the data, not the pure filename.
I changed, so that my index file now is in the same directory as the
tiff-tiles
and changed the location entry to "abc.tif" without any path and everything
works fine!
Regards, Till
Ciao Till,
the log does not help too much, I do not find the error you pointed me
towards yesterday ( I would increase the logging level for debugging
and then i would send things back again), however:
1> I would use geoserver 1.6.5 instead of 1.6.4
2> did you double check permission on the data dir?
3> can you describe how you are trying to set up this coverage, it
might be that you are entering an incorrect path.
Simone.
On Tue, Oct 21, 2008 at 10:03 AM, Till Adams <adams@anonymised.com> wrote:
Simone,
thank you so much, get attached the log from yesterday. I think the time
between 13 and 17h is interesting.
The problem is, we have about 200 tiles (tif) and want to serve them as
WCS
via geoserver. I've created
the files I sent you yesterday.
The problem appears when trying to setup a new coverage,
thanks al ot again!
Till
53111 Bonn
Germany
Till Adams
Geschäftsführung
Komplementärin:
vertreten durch:
127.0.0.1 - - [20/10/2008:08:23:52 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Aline&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_lines.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411335.6640625,4568126.953125,413894.3359375,4569498.046875&WIDTH=1819&HEIGHT=975
HTTP/1.1" 200 3482
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apolygon&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_polygons.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411335.6640625,4568126.953125,413894.3359375,4569498.046875&WIDTH=1819&HEIGHT=975
HTTP/1.1" 200 12169
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apoint&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_points.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411335.6640625,4568126.953125,413894.3359375,4569498.046875&WIDTH=1819&HEIGHT=975
HTTP/1.1" 200 3154
127.0.0.1 - - [20/10/2008:08:24:04 +0000] "GET
/geoserver/wfs?typename=cite%3Aline&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A23031&BBOX=410909.21875,4567898.4375,414320.78125,4569726.5625
HTTP/1.1" 200 4581
127.0.0.1 - - [20/10/2008:08:24:10 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Aline&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_lines.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411290.6640625,4568115.703125,413849.3359375,4569486.796875&WIDTH=1819&HEIGHT=975
HTTP/1.1" 200 3472
127.0.0.1 - - [20/10/2008:08:24:17 +0000] "GET
/geoserver/wfs?typename=cite%3Aline&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A23031&BBOX=410864.21875,4567887.1875,414275.78125,4569715.3125
HTTP/1.1" 200 4581
HTTP/1.1" 200 4581
HTTP/1.1" 200 3472
HTTP/1.1" 200 3472
127.0.0.1 - - [20/10/2008:08:25:15 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apolygon&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_polygons.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411290.6640625,4568115.703125,413849.3359375,4569486.796875&WIDTH=1819&HEIGHT=975
HTTP/1.1" 200 13087
127.0.0.1 - - [20/10/2008:08:25:23 +0000] "GET
HTTP/1.1" 200 3472
127.0.0.1 - - [20/10/2008:08:25:24 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apoint&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_points.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411290.6640625,4568115.703125,413849.3359375,4569486.796875&WIDTH=1819&HEIGHT=975
HTTP/1.1" 200 1829
127.0.0.1 - - [20/10/2008:08:25:32 +0000] "GET
HTTP/1.1" 200 13087
127.0.0.1 - - [20/10/2008:08:25:35 +0000] "GET
HTTP/1.1" 200 3472
127.0.0.1 - - [20/10/2008:12:08:12 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apoint&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_points.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411323.0078125,4568126.953125,413906.9921875,4569498.046875&WIDTH=1837&HEIGHT=975
HTTP/1.1" 200 1846
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Aline&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_lines.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411323.0078125,4568126.953125,413906.9921875,4569498.046875&WIDTH=1837&HEIGHT=975
HTTP/1.1" 200 3491
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apolygon&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_polygons.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411323.0078125,4568126.953125,413906.9921875,4569498.046875&WIDTH=1837&HEIGHT=975
HTTP/1.1" 200 11420
127.0.0.1 - - [20/10/2008:12:56:42 +0000] "GET /geoserver/ HTTP/1.1"
200
424
127.0.0.1 - - [20/10/2008:12:56:44 +0000] "GET /geoserver/style.css
HTTP/1.1" 200 1287
127.0.0.1 - - [20/10/2008:12:56:44 +0000] "GET /geoserver/gs.gif
HTTP/1.1"
404 1393
127.0.0.1 - - [20/10/2008:12:56:44 +0000] "GET /geoserver/gs.ico
HTTP/1.1"
404 1393
127.0.0.1 - - [20/10/2008:12:56:45 +0000] "GET /geoserver/gs.ico
HTTP/1.1"
404 1393
127.0.0.1 - - [20/10/2008:12:56:45 +0000] "GET /geoserver/welcome.do
HTTP/1.1" 200 3329
127.0.0.1 - - [20/10/2008:12:56:50 +0000] "GET /geoserver/images/gs.ico
HTTP/1.1" 200 5694
127.0.0.1 - - [20/10/2008:12:56:50 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:12:58:30 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=6.756420135513948,50.727980256100935,7.5529289245446485,51.00965055251168
HTTP/1.1" 200 2397
127.0.0.1 - - [20/10/2008:12:58:31 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=752121.248966137,6573316.90201213,840788.201761059,6623000.970388597
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=752121.248966137,6573316.90201213,840788.201761059,6623000.970388597
HTTP/1.1" 200 1411
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=752121.248966137,6573316.90201213,840788.201761059,6623000.970388597
HTTP/1.1" 200 1189
127.0.0.1 - - [20/10/2008:12:58:51 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apoint&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_points.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411137.3828125,4568126.953125,414092.6171875,4569498.046875&WIDTH=2101&HEIGHT=975
HTTP/1.1" 200 2097
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Aline&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_lines.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411137.3828125,4568126.953125,414092.6171875,4569498.046875&WIDTH=2101&HEIGHT=975
HTTP/1.1" 200 3934
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apolygon&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_polygons.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411137.3828125,4568126.953125,414092.6171875,4569498.046875&WIDTH=2101&HEIGHT=975
HTTP/1.1" 200 12006
127.0.0.1 - - [20/10/2008:12:58:56 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.05511093140046,50.83380608761927,7.2542381286581365,50.90422362776622
HTTP/1.1" 200 1853
127.0.0.1 - - [20/10/2008:12:58:57 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=785371.3562642326,6591948.427653305,807538.0944629633,6604369.444747422
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=785371.3562642326,6591948.427653305,807538.0944629633,6604369.444747422
HTTP/1.1" 200 1411
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=785371.3562642326,6591948.427653305,807538.0944629633,6604369.444747422
HTTP/1.1" 200 1189
127.0.0.1 - - [20/10/2008:12:59:06 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=6.955547332771625,50.79855742002475,7.353801727286972,50.93939251390105
HTTP/1.1" 200 2397
127.0.0.1 - - [20/10/2008:12:59:07 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=774287.9871648676,6585737.919106247,818621.4635623284,6610579.95329448
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=774287.9871648676,6585737.919106247,818621.4635623284,6610579.95329448
HTTP/1.1" 200 1411
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=774287.9871648676,6585737.919106247,818621.4635623284,6610579.95329448
HTTP/1.1" 200 1189
127.0.0.1 - - [20/10/2008:12:59:42 +0000] "GET
HTTP/1.1" 302 0
127.0.0.1 - - [20/10/2008:12:59:43 +0000] "GET
/geoserver/admin/login.do
HTTP/1.1" 200 2784
127.0.0.1 - - [20/10/2008:12:59:44 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:12:59:49 +0000] "POST
/geoserver/j_acegi_security_check HTTP/1.1" 302 0
127.0.0.1 - - [20/10/2008:12:59:49 +0000] "GET
/geoserver/admin/login.do?login_error=1 HTTP/1.1" 200 2827
127.0.0.1 - - [20/10/2008:12:59:49 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:00:47 +0000] "POST
127.0.0.1 - - [20/10/2008:13:00:47 +0000] "GET
HTTP/1.1" 200 2730
127.0.0.1 - - [20/10/2008:13:00:48 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:00:51 +0000] "GET
/geoserver/config/data/index.do HTTP/1.1" 200 2857
127.0.0.1 - - [20/10/2008:13:00:51 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:00:57 +0000] "GET
/geoserver/config/data/format.do HTTP/1.1" 200 2917
127.0.0.1 - - [20/10/2008:13:00:58 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:01:04 +0000] "GET
/geoserver/config/data/formatNew.do HTTP/1.1" 200 2932
127.0.0.1 - - [20/10/2008:13:01:05 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:02:22 +0000] "POST
/geoserver/config/data/formatNewSubmit.do HTTP/1.1" 200 3179
127.0.0.1 - - [20/10/2008:13:02:23 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:04:37 +0000] "POST
/geoserver/config/data/formatNewSubmit.do HTTP/1.1" 200 3178
127.0.0.1 - - [20/10/2008:13:04:37 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:17:42 +0000] "POST
127.0.0.1 - - [20/10/2008:13:17:43 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:21:41 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apoint&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_points.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411598.28125,4568126.953125,413631.71875,4569498.046875&WIDTH=1446&HEIGHT=975
HTTP/1.1" 200 3134
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Aline&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_lines.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411598.28125,4568126.953125,413631.71875,4569498.046875&WIDTH=1446&HEIGHT=975
HTTP/1.1" 200 3128
127.0.0.1 - - [20/10/2008:13:21:42 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apolygon&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_polygons.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=411598.28125,4568126.953125,413631.71875,4569498.046875&WIDTH=1446&HEIGHT=975
HTTP/1.1" 200 14106
127.0.0.1 - - [20/10/2008:13:21:49 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Apoint&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_points.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=412106.640625,4568469.7265625,413123.359375,4569155.2734375&WIDTH=1446&HEIGHT=975
HTTP/1.1" 200 1762
127.0.0.1 - - [20/10/2008:13:21:50 +0000] "GET
/geoserver/wms?TRANSPARENT=true&LAYERS=cite%3Aline&STYLES=&FORMAT=image%2Fpng8&SLD=http%3A%2F%2Fwww.webmapcenter.de%2F%2Finfogeo%2Fsld%2Fsld_lines.sld&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A23031&BBOX=412106.640625,4568469.7265625,413123.359375,4569155.2734375&WIDTH=1446&HEIGHT=975
HTTP/1.1" 200 3620
127.0.0.1 - - [20/10/2008:13:21:51 +0000] "GET
HTTP/1.1" 200 3128
HTTP/1.1" 200 3134
HTTP/1.1" 200 14106
127.0.0.1 - - [20/10/2008:13:25:00 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 3291
127.0.0.1 - - [20/10/2008:13:25:01 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:25:17 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 3240
127.0.0.1 - - [20/10/2008:13:25:18 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:25:53 +0000] "GET
127.0.0.1 - - [20/10/2008:13:25:53 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:26:00 +0000] "POST
/geoserver/config/data/formatSelectSubmit.do HTTP/1.1" 200 3189
127.0.0.1 - - [20/10/2008:13:26:15 +0000] "GET
127.0.0.1 - - [20/10/2008:13:26:16 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:26:34 +0000] "POST
127.0.0.1 - - [20/10/2008:13:26:34 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:26:56 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 3242
127.0.0.1 - - [20/10/2008:13:27:07 +0000] "POST
127.0.0.1 - - [20/10/2008:13:27:07 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:27:25 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 3239
127.0.0.1 - - [20/10/2008:13:27:37 +0000] "POST
127.0.0.1 - - [20/10/2008:13:27:37 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:27:44 +0000] "POST
127.0.0.1 - - [20/10/2008:13:27:44 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:28:57 +0000] "GET
127.0.0.1 - - [20/10/2008:13:29:00 +0000] "GET
127.0.0.1 - - [20/10/2008:13:29:18 +0000] "GET
HTTP/1.1" 200 2730
127.0.0.1 - - [20/10/2008:13:29:25 +0000] "GET
/geoserver/config/wcs/index.do HTTP/1.1" 200 2755
127.0.0.1 - - [20/10/2008:13:29:25 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:29:28 +0000] "GET
/geoserver/config/wcs/coverageplugins.do HTTP/1.1" 200 2838
127.0.0.1 - - [20/10/2008:13:29:29 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:31:15 +0000] "GET /geoserver/welcome.do
HTTP/1.1" 200 3337
127.0.0.1 - - [20/10/2008:13:31:15 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:31:18 +0000] "GET
HTTP/1.1" 200 2730
127.0.0.1 - - [20/10/2008:13:31:20 +0000] "GET
127.0.0.1 - - [20/10/2008:13:31:25 +0000] "GET
/geoserver/config/data/coverageSelect.do HTTP/1.1" 200 2896
127.0.0.1 - - [20/10/2008:13:31:26 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:31:31 +0000] "GET
127.0.0.1 - - [20/10/2008:13:31:32 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:31:33 +0000] "GET
127.0.0.1 - - [20/10/2008:13:31:33 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:31:41 +0000] "POST
127.0.0.1 - - [20/10/2008:13:33:14 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 2936
127.0.0.1 - - [20/10/2008:13:33:14 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:33:19 +0000] "POST
/geoserver/config/data/formatSelectSubmit.do HTTP/1.1" 200 3207
127.0.0.1 - - [20/10/2008:13:33:34 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 3256
127.0.0.1 - - [20/10/2008:13:33:35 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:34:37 +0000] "POST
127.0.0.1 - - [20/10/2008:13:34:38 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:34:40 +0000] "POST
127.0.0.1 - - [20/10/2008:13:34:55 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 500 532
127.0.0.1 - - [20/10/2008:13:34:55 +0000] "GET
/geoserver/config/data/gs.ico HTTP/1.1" 404 1405
127.0.0.1 - - [20/10/2008:13:34:56 +0000] "GET
127.0.0.1 - - [20/10/2008:13:35:01 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:35:06 +0000] "POST
127.0.0.1 - - [20/10/2008:13:35:06 +0000] "GET
127.0.0.1 - - [20/10/2008:13:35:07 +0000] "GET
127.0.0.1 - - [20/10/2008:13:35:08 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:35:17 +0000] "POST
127.0.0.1 - - [20/10/2008:13:35:18 +0000] "GET
127.0.0.1 - - [20/10/2008:13:35:21 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:35:29 +0000] "GET
/geoserver/config/data/format.do HTTP/1.1" 200 2936
127.0.0.1 - - [20/10/2008:13:35:34 +0000] "POST
127.0.0.1 - - [20/10/2008:13:35:36 +0000] "POST
127.0.0.1 - - [20/10/2008:13:35:36 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:35:41 +0000] "POST
127.0.0.1 - - [20/10/2008:13:35:41 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:35:50 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 3255
127.0.0.1 - - [20/10/2008:13:35:51 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:41:23 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 2935
127.0.0.1 - - [20/10/2008:13:41:23 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:41:29 +0000] "GET
/geoserver/config/data/index.do HTTP/1.1" 200 2876
127.0.0.1 - - [20/10/2008:13:41:30 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:41:32 +0000] "GET
/geoserver/config/data/coverageSelect.do HTTP/1.1" 200 2914
127.0.0.1 - - [20/10/2008:13:41:32 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:41:35 +0000] "POST
/geoserver/config/data/coverageSelectSubmit.do HTTP/1.1" 200 6824
127.0.0.1 - - [20/10/2008:13:41:37 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:41:56 +0000] "POST
/geoserver/config/data/coverageEditorSubmit.do HTTP/1.1" 200 6824
127.0.0.1 - - [20/10/2008:13:41:56 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:47:33 +0000] "GET
127.0.0.1 - - [20/10/2008:13:47:35 +0000] "GET
/geoserver/config/data/format.do HTTP/1.1" 200 2935
127.0.0.1 - - [20/10/2008:13:47:35 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:47:38 +0000] "POST
127.0.0.1 - - [20/10/2008:13:47:39 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:47:44 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 2937
127.0.0.1 - - [20/10/2008:13:47:45 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:47:47 +0000] "POST
/geoserver/admin/saveToGeoServer.do HTTP/1.1" 200 2749
127.0.0.1 - - [20/10/2008:13:47:50 +0000] "POST
/geoserver/admin/saveToXML.do HTTP/1.1" 200 2731
127.0.0.1 - - [20/10/2008:13:47:51 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:47:52 +0000] "POST
/geoserver/admin/loadFromXML.do HTTP/1.1" 200 2731
127.0.0.1 - - [20/10/2008:13:47:54 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:47:55 +0000] "GET
/geoserver/config/data/index.do HTTP/1.1" 200 2858
127.0.0.1 - - [20/10/2008:13:47:55 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:47:58 +0000] "GET
/geoserver/config/data/coverageSelect.do HTTP/1.1" 200 2897
127.0.0.1 - - [20/10/2008:13:47:59 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:48:02 +0000] "POST
/geoserver/config/data/coverageSelectSubmit.do HTTP/1.1" 200 6807
127.0.0.1 - - [20/10/2008:13:48:03 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:48:05 +0000] "POST
/geoserver/config/data/coverageEditorSubmit.do HTTP/1.1" 200 6765
127.0.0.1 - - [20/10/2008:13:48:06 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:48:12 +0000] "POST
/geoserver/config/data/coverageEditorSubmit.do HTTP/1.1" 200 6826
127.0.0.1 - - [20/10/2008:13:49:51 +0000] "POST
127.0.0.1 - - [20/10/2008:13:49:51 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:50:09 +0000] "POST
127.0.0.1 - - [20/10/2008:13:50:10 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:13:50:20 +0000] "POST
/geoserver/config/data/coverageEditorSubmit.do HTTP/1.1" 200 6820
127.0.0.1 - - [20/10/2008:13:56:47 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=6.512489318879458,50.608081492131525,8.105506896940856,51.17116374949055
HTTP/1.1" 200 2397
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=724966.9946733781,6552258.500723497,902300.9002632217,6651626.637476427
HTTP/1.1" 200 262
127.0.0.1 - - [20/10/2008:13:56:48 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=724966.9946733781,6552258.500723497,902300.9002632217,6651626.637476427
HTTP/1.1" 200 1411
127.0.0.1 - - [20/10/2008:13:56:49 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=724966.9946733781,6552258.500723497,902300.9002632217,6651626.637476427
HTTP/1.1" 200 1189
127.0.0.1 - - [20/10/2008:13:58:00 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=6.772384643570588,50.764259357122114,7.568893432601287,51.04571104080775
HTTP/1.1" 200 2397
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=753898.4098735198,6579699.39387306,842565.3626684418,6629383.462249527
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=753898.4098735198,6579699.39387306,842565.3626684418,6629383.462249527
HTTP/1.1" 200 1411
127.0.0.1 - - [20/10/2008:13:58:01 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=753898.4098735198,6579699.39387306,842565.3626684418,6629383.462249527
HTTP/1.1" 200 1189
127.0.0.1 - - [20/10/2008:13:58:04 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.050991058351599,50.8885784619392,7.150554656980435,50.92375916823052
HTTP/1.1" 200 804
127.0.0.1 - - [20/10/2008:13:58:05 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=784912.7340943643,6601608.15710138,795996.1031937294,6607818.665648436
HTTP/1.1" 200 262
127.0.0.1 - - [20/10/2008:13:58:06 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=784912.7340943643,6601608.15710138,795996.1031937294,6607818.665648436
HTTP/1.1" 200 782
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=784912.7340943643,6601608.15710138,795996.1031937294,6607818.665648436
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:13:58:55 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=6.906280517586076,50.83873877820127,7.304534912101424,50.979452621984954
HTTP/1.1" 200 1634
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=768803.6303861695,6592817.898850183,813137.1067836303,6617659.933038416
HTTP/1.1" 200 262
127.0.0.1 - - [20/10/2008:13:58:56 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=768803.6303861695,6592817.898850183,813137.1067836303,6617659.933038416
HTTP/1.1" 200 1411
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=768803.6303861695,6592817.898850183,813137.1067836303,6617659.933038416
HTTP/1.1" 200 834
127.0.0.1 - - [20/10/2008:13:58:59 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.080774307251474,50.90372295561231,7.105665206908684,50.91251776399826
HTTP/1.1" 200 329
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=788228.1901956062,6604281.064433768,790999.0324704476,6605833.691570532
HTTP/1.1" 200 262
127.0.0.1 - - [20/10/2008:13:59:00 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=788228.1901956062,6604281.064433768,790999.0324704476,6605833.691570532
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=788228.1901956062,6604281.064433768,790999.0324704476,6605833.691570532
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:13:59:43 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=6.99365615845124,50.87292803971285,7.192783355708916,50.94328650904165
HTTP/1.1" 200 1104
127.0.0.1 - - [20/10/2008:13:59:44 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=778530.2422336616,6598846.869455092,800696.9804323922,6611267.886549208
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=778530.2422336616,6598846.869455092,800696.9804323922,6611267.886549208
HTTP/1.1" 200 1411
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=778530.2422336616,6598846.869455092,800696.9804323922,6611267.886549208
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:13:59:52 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=6.694965362564728,50.76719087077016,7.491474151595428,51.048624884685495
HTTP/1.1" 200 2397
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=745280.1349355659,6580215.343813917,833947.0877304879,6629899.412190383
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=745280.1349355659,6580215.343813917,833947.0877304879,6629899.412190383
HTTP/1.1" 200 1411
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=745280.1349355659,6580215.343813917,833947.0877304879,6629899.412190383
HTTP/1.1" 200 1189
127.0.0.1 - - [20/10/2008:14:00:40 +0000] "GET /geoserver/welcome.do
HTTP/1.1" 200 3337
127.0.0.1 - - [20/10/2008:14:00:41 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:00:51 +0000] "GET
/geoserver/ows?service=WCS&request=GetCapabilities HTTP/1.1" 200 1203
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.074680328373115,50.82025205614419,7.273807525630791,50.89069005408637
HTTP/1.1" 200 2079
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=787549.8115700568,6589559.770519735,809716.5497687875,6601980.787613852
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=787549.8115700568,6589559.770519735,809716.5497687875,6601980.787613852
HTTP/1.1" 200 1411
127.0.0.1 - - [20/10/2008:14:00:52 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=787549.8115700568,6589559.770519735,809716.5497687875,6601980.787613852
HTTP/1.1" 200 1189
127.0.0.1 - - [20/10/2008:14:01:09 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.149009704590837,50.851501727388296,7.198791503905257,50.86910940554266
HTTP/1.1" 200 782
127.0.0.1 - - [20/10/2008:14:01:10 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=795824.1198804434,6595068.01386958,801365.8044301262,6598173.26814311
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795824.1198804434,6595068.01386958,801365.8044301262,6598173.26814311
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795824.1198804434,6595068.01386958,801365.8044301262,6598173.26814311
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:01:36 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.162088155746957,50.855789132129075,7.1869790554041675,50.86459299292974
HTTP/1.1" 200 672
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=797280.0064033049,6595824.023852327,800050.8486781462,6597376.65098909
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=797280.0064033049,6595824.023852327,800050.8486781462,6597376.65098909
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=797280.0064033049,6595824.023852327,800050.8486781462,6597376.65098909
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:02:14 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.1679353713991745,50.85822729077044,7.180380821227778,50.86262919879307
HTTP/1.1" 200 612
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=797930.9154721775,6596253.982136358,799316.336609598,6597030.295704741
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=797930.9154721775,6596253.982136358,799316.336609598,6597030.295704741
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:02:15 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=797930.9154721775,6596253.982136358,799316.336609598,6597030.295704741
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:03:02 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.170952856540806,50.859468332287534,7.177175581455107,50.86166927966577
HTTP/1.1" 200 612
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=798266.8203815734,6596472.842846213,798959.5309502836,6596860.999630405
HTTP/1.1" 200 262
127.0.0.1 - - [20/10/2008:14:03:03 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=798266.8203815734,6596472.842846213,798959.5309502836,6596860.999630405
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=798266.8203815734,6596472.842846213,798959.5309502836,6596860.999630405
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:03:20 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=6.974937021740281,50.790085302911294,7.37319141625563,50.93094595320085
HTTP/1.1" 200 2397
127.0.0.1 - - [20/10/2008:14:03:21 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=776446.4374671981,6584245.904144192,820779.9138646589,6609087.938332425
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=776446.4374671981,6584245.904144192,820779.9138646589,6609087.938332425
HTTP/1.1" 200 1411
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=776446.4374671981,6584245.904144192,820779.9138646589,6609087.938332425
HTTP/1.1" 200 1189
127.0.0.1 - - [20/10/2008:14:03:27 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.1418428421023,50.85772612412464,7.154288291930904,50.86212807945665
HTTP/1.1" 200 329
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=795026.3083977452,6596165.601822414,796411.7295351657,6596941.915390798
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795026.3083977452,6596165.601822414,796411.7295351657,6596941.915390798
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795026.3083977452,6596165.601822414,796411.7295351657,6596941.915390798
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:03:49 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.14461356401456,50.85918728075782,7.15083628892886,50.86138824140185
HTTP/1.1" 200 329
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=795334.7437501048,6596423.278210693,796027.454318815,6596811.434994885
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795334.7437501048,6596423.278210693,796027.454318815,6596811.434994885
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795334.7437501048,6596423.278210693,796027.454318815,6596811.434994885
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:03:57 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.1467244625092805,50.859712134652085,7.152947187423581,50.86191307052269
HTTP/1.1" 200 329
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=795569.7278956206,6596515.838674619,796262.4384643309,6596903.995458811
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795569.7278956206,6596515.838674619,796262.4384643309,6596903.995458811
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795569.7278956206,6596515.838674619,796262.4384643309,6596903.995458811
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:04:00 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.148674428463107,50.860172646751685,7.154897153377408,50.862373560885686
HTTP/1.1" 200 329
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=795786.7971126346,6596597.053017161,796479.5076813449,6596985.209801353
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795786.7971126346,6596597.053017161,796479.5076813449,6596985.209801353
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=795786.7971126346,6596597.053017161,796479.5076813449,6596985.209801353
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:04:03 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=796047.1607401948,6596793.818648538,796739.8713089051,6597181.975432729
HTTP/1.1" 200 262
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.151013314724094,50.861288353900086,7.157236039638396,50.863489215371025
HTTP/1.1" 200 329
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=796047.1607401948,6596793.818648538,796739.8713089051,6597181.975432729
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=796047.1607401948,6596793.818648538,796739.8713089051,6597181.975432729
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:04:06 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.152568995952732,50.86204681635416,7.1587917208670335,50.86424764202411
HTTP/1.1" 200 329
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=796220.3383823794,6596927.583448014,796913.0489510896,6597315.740232206
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=796220.3383823794,6596927.583448014,796913.0489510896,6597315.740232206
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=796220.3383823794,6596927.583448014,796913.0489510896,6597315.740232206
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:04:10 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.154497504234439,50.86292038728483,7.1607202291487395,50.86512117171994
HTTP/1.1" 200 329
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=796435.0189422597,6597081.651833136,797127.72951097,6597469.808617327
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=796435.0189422597,6597081.651833136,797127.72951097,6597469.808617327
HTTP/1.1" 200 323
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=796435.0189422597,6597081.651833136,797127.72951097,6597469.808617327
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:04:19 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.107827067377172,50.84641119251666,7.207390666006007,50.88162374375978
HTTP/1.1" 200 1085
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=791239.6896769323,6594170.475951703,802323.0587762974,6600380.98449876
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=791239.6896769323,6594170.475951703,802323.0587762974,6600380.98449876
HTTP/1.1" 200 1411
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=791239.6896769323,6594170.475951703,802323.0587762974,6600380.98449876
HTTP/1.1" 200 834
127.0.0.1 - - [20/10/2008:14:04:44 +0000] "GET
/geoserver/wfs?typename=topp%3AWahnerHeide_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A4326&BBOX=7.152807712555429,50.86814792707458,7.177698612212637,50.87694945447703
HTTP/1.1" 200 674
/geoserver/wfs?typename=cite%3Anabu_points&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A900913&BBOX=796246.9121930317,6598003.673486718,799017.7544678731,6599556.300623481
HTTP/1.1" 200 262
/geoserver/wfs?typename=cite%3Anabu_lines&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=796246.9121930317,6598003.673486718,799017.7544678731,6599556.300623481
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:04:45 +0000] "GET
/geoserver/wfs?typename=cite%3Anabu_polys&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A31466&BBOX=796246.9121930317,6598003.673486718,799017.7544678731,6599556.300623481
HTTP/1.1" 200 323
127.0.0.1 - - [20/10/2008:14:18:08 +0000] "GET
HTTP/1.1" 200 2731
127.0.0.1 - - [20/10/2008:14:18:08 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:18:11 +0000] "GET
127.0.0.1 - - [20/10/2008:14:18:12 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:18:13 +0000] "GET
/geoserver/config/data/format.do HTTP/1.1" 200 2918
127.0.0.1 - - [20/10/2008:14:18:14 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:18:18 +0000] "POST
/geoserver/config/data/formatSelectSubmit.do HTTP/1.1" 200 3191
127.0.0.1 - - [20/10/2008:14:18:50 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 200 2930
127.0.0.1 - - [20/10/2008:14:18:50 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:18:52 +0000] "POST
/geoserver/admin/saveToGeoServer.do HTTP/1.1" 200 2743
127.0.0.1 - - [20/10/2008:14:18:54 +0000] "POST
127.0.0.1 - - [20/10/2008:14:18:55 +0000] "POST
127.0.0.1 - - [20/10/2008:14:18:57 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:18:59 +0000] "GET
127.0.0.1 - - [20/10/2008:14:19:00 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:19:01 +0000] "GET
127.0.0.1 - - [20/10/2008:14:19:02 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:19:06 +0000] "POST
127.0.0.1 - - [20/10/2008:14:19:10 +0000] "POST
/geoserver/config/data/coverageEditorSubmit.do HTTP/1.1" 200 6807
127.0.0.1 - - [20/10/2008:14:19:10 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:19:14 +0000] "POST
/geoserver/config/data/coverageEditorSubmit.do HTTP/1.1" 200 6868
127.0.0.1 - - [20/10/2008:14:20:20 +0000] "POST
/geoserver/admin/saveToGeoServer.do HTTP/1.1" 200 2740
127.0.0.1 - - [20/10/2008:14:20:21 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:20:22 +0000] "POST
/geoserver/admin/saveToXML.do HTTP/1.1" 200 2739
127.0.0.1 - - [20/10/2008:14:20:23 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:20:24 +0000] "POST
127.0.0.1 - - [20/10/2008:14:20:26 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:20:29 +0000] "GET
127.0.0.1 - - [20/10/2008:14:20:30 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:20:33 +0000] "GET
/geoserver/config/wcs/coverageplugins.do HTTP/1.1" 200 2837
127.0.0.1 - - [20/10/2008:14:20:42 +0000] "GET
127.0.0.1 - - [20/10/2008:14:20:43 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:20:46 +0000] "GET
/geoserver/config/wcs/content.do HTTP/1.1" 200 2845
127.0.0.1 - - [20/10/2008:14:20:46 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:20:51 +0000] "GET
127.0.0.1 - - [20/10/2008:14:20:54 +0000] "GET
/geoserver/config/wcs/description.do HTTP/1.1" 200 3188
127.0.0.1 - - [20/10/2008:14:20:54 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:21:00 +0000] "GET
127.0.0.1 - - [20/10/2008:14:21:00 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:21:05 +0000] "GET
HTTP/1.1" 200 2731
127.0.0.1 - - [20/10/2008:14:21:05 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:21:09 +0000] "GET
127.0.0.1 - - [20/10/2008:14:21:10 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:21:28 +0000] "GET /geoserver/wcs?
HTTP/1.1"
200 621
127.0.0.1 - - [20/10/2008:14:21:49 +0000] "GET
/geoserver/wcs?service=wcs&Request=Capabilities&version=1.0.0 HTTP/1.1"
200
260
127.0.0.1 - - [20/10/2008:14:22:01 +0000] "GET
/geoserver/wcs?service=wcs&Request=getCapabilities&version=1.0.0
HTTP/1.1"
200 1203
127.0.0.1 - - [20/10/2008:14:22:14 +0000] "GET
/geoserver/wcs?service=wms&Request=getCapabilities&version=1.0.0
HTTP/1.1"
200 15790
127.0.0.1 - - [20/10/2008:14:22:21 +0000] "GET
/geoserver/wms?service=wms&Request=getCapabilities&version=1.0.0
HTTP/1.1"
200 15790
127.0.0.1 - - [20/10/2008:14:22:31 +0000] "GET
/geoserver/wms?service=wms&Request=getCapabilities&version=1.1.1
HTTP/1.1"
200 15790
127.0.0.1 - - [20/10/2008:14:24:33 +0000] "GET
/geoserver/wcs?service=wcs&request=GetCapabilities&version=1.0.0&SERVICE=WMS&REQUEST=GetCapabilities
HTTP/1.1" 200 136395
127.0.0.1 - - [20/10/2008:14:24:51 +0000] "GET
127.0.0.1 - - [20/10/2008:14:24:53 +0000] "GET
/geoserver/wcs?service=wcs&request=GetCapabilities&version=1.0.0&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&BBOX=6.346175,36.491772,20.829683,46.590767&SRS=EPSG:4326&WIDTH=774&HEIGHT=540&LAYERS=nurc%3Amosaic&STYLES=&FORMAT=image/png&TRANSPARENT=TRUE
HTTP/1.1" 200 4998
127.0.0.1 - - [20/10/2008:14:28:50 +0000] "GET
127.0.0.1 - - [20/10/2008:14:28:59 +0000] "GET
127.0.0.1 - - [20/10/2008:14:29:01 +0000] "GET
/geoserver/wcs?service=wcs&request=GetCapabilities&version=1.0.0&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&BBOX=-130.851680,20.705200,-62.005400,54.114100&SRS=EPSG:4326&WIDTH=959&HEIGHT=465&LAYERS=nurc%3AImg_Sample&STYLES=&FORMAT=image/png&TRANSPARENT=TRUE
HTTP/1.1" 200 4998
127.0.0.1 - - [20/10/2008:14:38:00 +0000] "GET
HTTP/1.1" 200 2097
HTTP/1.1" 200 3934
127.0.0.1 - - [20/10/2008:14:38:01 +0000] "GET
HTTP/1.1" 200 12006
127.0.0.1 - - [20/10/2008:14:40:52 +0000] "GET
HTTP/1.1" 200 2097
HTTP/1.1" 200 12006
HTTP/1.1" 200 3934
127.0.0.1 - - [20/10/2008:14:44:47 +0000] "GET
/geoserver/config/data/store.do HTTP/1.1" 200 2912
127.0.0.1 - - [20/10/2008:14:44:48 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:44:52 +0000] "GET
127.0.0.1 - - [20/10/2008:14:44:54 +0000] "GET
127.0.0.1 - - [20/10/2008:14:44:58 +0000] "GET
127.0.0.1 - - [20/10/2008:14:45:08 +0000] "POST
/geoserver/config/data/formatNewSubmit.do HTTP/1.1" 200 3175
127.0.0.1 - - [20/10/2008:14:45:38 +0000] "POST
/geoserver/config/data/formatSubmit.do HTTP/1.1" 500 610
127.0.0.1 - - [20/10/2008:14:45:38 +0000] "GET
127.0.0.1 - - [20/10/2008:14:45:39 +0000] "GET
127.0.0.1 - - [20/10/2008:14:45:46 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:46:20 +0000] "POST
127.0.0.1 - - [20/10/2008:14:46:22 +0000] "GET
127.0.0.1 - - [20/10/2008:14:46:38 +0000] "POST
127.0.0.1 - - [20/10/2008:14:46:39 +0000] "GET /geoserver/images/gs.gif
HTTP/1.1" 200 881
127.0.0.1 - - [20/10/2008:14:46:41 +0000] "GET
[Message clipped]
Eng. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://www.geo-solutions.it/simone.giannecchini
http://www.linkedin.com/in/simonegiannecchini
Simone,
as I come from using UMN, I'm used to preprocess by creating internal pyramids and overviews with
the gdal tools. I didn't try the geoserver extension "pyramids" (which does the same as I understand) yet.
Regards, Till
Ciao Till,
Simone.
Simone, (list)
tiff-tiles
works fine!
Regards, Till
Ciao Till,
Simone.
Simone,
WCS
thanks al ot again!
Till
53111 Bonn
Germany
Till Adams
Geschäftsführung
Komplementärin:
vertreten durch:
HTTP/1.1" 200 3482
HTTP/1.1" 200 12169
HTTP/1.1" 200 3154
HTTP/1.1" 200 4581
HTTP/1.1" 200 3472
HTTP/1.1" 200 4581
HTTP/1.1" 200 4581
HTTP/1.1" 200 3472
HTTP/1.1" 200 3472
HTTP/1.1" 200 13087
HTTP/1.1" 200 3472
HTTP/1.1" 200 1829
HTTP/1.1" 200 13087
HTTP/1.1" 200 3472
HTTP/1.1" 200 1846
HTTP/1.1" 200 3491
HTTP/1.1" 200 11420
200
424
HTTP/1.1" 200 1287
HTTP/1.1"
404 1393
HTTP/1.1"
404 1393
HTTP/1.1"
404 1393
HTTP/1.1" 200 3329
HTTP/1.1" 200 5694
HTTP/1.1" 200 881
HTTP/1.1" 200 2397
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 1189
HTTP/1.1" 200 2097
HTTP/1.1" 200 3934
HTTP/1.1" 200 12006
HTTP/1.1" 200 1853
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 1189
HTTP/1.1" 200 2397
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 1189
HTTP/1.1" 302 0
HTTP/1.1" 200 2784
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 2730
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 3134
HTTP/1.1" 200 3128
HTTP/1.1" 200 14106
HTTP/1.1" 200 1762
HTTP/1.1" 200 3620
HTTP/1.1" 200 3128
HTTP/1.1" 200 3134
HTTP/1.1" 200 14106
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 2730
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 3337
HTTP/1.1" 200 881
HTTP/1.1" 200 2730
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 2397
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 1189
HTTP/1.1" 200 2397
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 1189
HTTP/1.1" 200 804
HTTP/1.1" 200 262
HTTP/1.1" 200 782
HTTP/1.1" 200 323
HTTP/1.1" 200 1634
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 834
HTTP/1.1" 200 329
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 1104
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 323
HTTP/1.1" 200 2397
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 1189
HTTP/1.1" 200 3337
HTTP/1.1" 200 881
HTTP/1.1" 200 2079
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 1189
HTTP/1.1" 200 782
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 672
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 612
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 612
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 2397
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 1189
HTTP/1.1" 200 329
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 329
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 329
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 329
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 262
HTTP/1.1" 200 329
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 329
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 329
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 1085
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 834
HTTP/1.1" 200 674
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 2731
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 2731
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1"
200 621
200
260
HTTP/1.1"
200 1203
HTTP/1.1"
200 15790
HTTP/1.1"
200 15790
HTTP/1.1"
200 15790
HTTP/1.1" 200 4998
HTTP/1.1" 200 4998
HTTP/1.1" 200 2097
HTTP/1.1" 200 3934
HTTP/1.1" 200 12006
HTTP/1.1" 200 2097
HTTP/1.1" 200 12006
HTTP/1.1" 200 3934
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
[Message clipped]
53111 Bonn
Germany
Till Adams
Geschäftsführung
Komplementärin:
vertreten durch:
Can you tell me more about your data?
This way I could try to see if we can improve anything.
Simone.
On Tue, Oct 21, 2008 at 4:21 PM, Till Adams <adams@anonymised.com> wrote:
Simone,
Regards, Till
Ciao Till,
Simone.
Simone, (list)
in
tiff-tiles
everything
works fine!
Regards, Till
Ciao Till,
Simone.
wrote:
Simone,
time
WCS
thanks al ot again!
Till
53111 Bonn
Germany
Till Adams
Geschäftsführung
Komplementärin:
vertreten durch:
HTTP/1.1" 200 3482
HTTP/1.1" 200 12169
HTTP/1.1" 200 3154
HTTP/1.1" 200 4581
HTTP/1.1" 200 3472
HTTP/1.1" 200 4581
HTTP/1.1" 200 4581
HTTP/1.1" 200 3472
HTTP/1.1" 200 3472
HTTP/1.1" 200 13087
HTTP/1.1" 200 3472
HTTP/1.1" 200 1829
HTTP/1.1" 200 13087
HTTP/1.1" 200 3472
HTTP/1.1" 200 1846
HTTP/1.1" 200 3491
HTTP/1.1" 200 11420
200
424
HTTP/1.1" 200 1287
HTTP/1.1"
404 1393
HTTP/1.1"
404 1393
HTTP/1.1"
404 1393
HTTP/1.1" 200 3329
HTTP/1.1" 200 5694
HTTP/1.1" 200 881
HTTP/1.1" 200 2397
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 1189
HTTP/1.1" 200 2097
HTTP/1.1" 200 3934
HTTP/1.1" 200 12006
HTTP/1.1" 200 1853
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 1189
HTTP/1.1" 200 2397
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 1189
HTTP/1.1" 302 0
HTTP/1.1" 200 2784
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 2730
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 3134
HTTP/1.1" 200 3128
HTTP/1.1" 200 14106
HTTP/1.1" 200 1762
HTTP/1.1" 200 3620
HTTP/1.1" 200 3128
HTTP/1.1" 200 3134
HTTP/1.1" 200 14106
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
/geoserver/config/index.do
HTTP/1.1" 200 2730
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 3337
HTTP/1.1" 200 881
HTTP/1.1" 200 2730
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 2397
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 1189
HTTP/1.1" 200 2397
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 1189
HTTP/1.1" 200 804
HTTP/1.1" 200 262
HTTP/1.1" 200 782
HTTP/1.1" 200 323
HTTP/1.1" 200 1634
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 834
HTTP/1.1" 200 329
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 1104
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 323
HTTP/1.1" 200 2397
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 1189
HTTP/1.1" 200 3337
HTTP/1.1" 200 881
HTTP/1.1" 200 2079
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 1189
HTTP/1.1" 200 782
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 672
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 612
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 612
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 2397
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 1189
HTTP/1.1" 200 329
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 329
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 329
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 329
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 262
HTTP/1.1" 200 329
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 329
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 329
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 1085
HTTP/1.1" 200 262
HTTP/1.1" 200 1411
HTTP/1.1" 200 834
HTTP/1.1" 200 674
HTTP/1.1" 200 262
HTTP/1.1" 200 323
HTTP/1.1" 200 323
HTTP/1.1" 200 2731
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1" 200 2731
HTTP/1.1" 200 881
HTTP/1.1" 200 881
HTTP/1.1"
200 621
200
260
HTTP/1.1"
200 1203
HTTP/1.1"
200 15790
HTTP/1.1"
200 15790
HTTP/1.1"
200 15790
HTTP/1.1" 200 4998
HTTP/1.1" 200 4998
HTTP/1.1" 200 2097
HTTP/1.1" 200 3934
HTTP/1.1" 200 12006
HTTP/1.1" 200 2097
HTTP/1.1" 200 12006
HTTP/1.1" 200 3934
HTTP/1.1" 200 881
[Message clipped]
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
