[Geoserver-users] CQL expression in dynamic symbolizers throwing errors
Hello,
I am trying to use CQL expression in dynamic symbolizers. I am using this as guidelines:
http://docs.geoserver.org/2.9.0/user/styling/sld-extensions/pointsymbols.html#dynamic-symbolizers
I wrote an ows service that is returning png image and I want to use it in SLD.
This is what I have in the SLD:
se:PointSymbolizer
se:Graphic
se:ExternalGraphic
<se:OnlineResource xlink:type=“simple” xlink:href=“http://localhost:8888/geoserver/ows?request=getMapSymbol&service=monitoringStationSymbol&version=1.0.0&stationid=${id}” />
se:Formatimage/png</se:Format>
</se:ExternalGraphic>
</se:Graphic>
</se:PointSymbolizer>
id is the primary key in the layer.
When I try to preview the layer I get this error:
java.io.IOException: java.lang.RuntimeException: Parsing failed for href: java.net.URISyntaxException: Illegal character in query at index 117: http://localhost:8888/wmis-web-app/ows?request=getMapSymbol&service=monitoringStationSymbol&version=1.0.0&stationid=${id}
If I remove “&stationid=${id}” from the url, everything is working. My ows service is returning a picture and this picture is used as a symbol when I load the wms layer service in openlayers.
What is wrong in the expression that I am trying to use?
I am using Geoserver 2.9.0 on Apache Tomcat 8.5.4 on windows 8.1.
Best regards,
Kalin
I believe the issue is that you’re using SLD/SE 1.1 instead of SLD 1.0, dynamic symbolizers
are out of spec and require keeping those urls as strings up to the point we expand expressions.
I assume SE 1.1 parser is not doing that.
I’d open a ticket, if you’re by chance proficient with Java development I can give you pointers to where
the fix might have to be done.
On Thu, Sep 15, 2016 at 11:32 PM, Kalin Genov <kalin.genov@anonymised.com> wrote:
Hello,
se:PointSymbolizer
se:Graphic
se:ExternalGraphic
</se:Graphic>
Best regards,
Kalin
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
