Hi Justin
I’m using 1.6.3 and I tried it with 1.6.x trunk and the 1.7.alpha. Same errors… Here is my OpenLayer definition:
var waiting = new OpenLayers.Layer.WMS(
“infogrips”,
“http://srsofaioi12288:8080/geoserver/wms”,
srs: ‘EPSG:21781’,
layers: ‘topp:geo_gemeinden_v’,
transparent: ‘true’,
tiled: ‘true’,
format: ‘image/png’,
styles: ‘av_meta_waiting’,
CQL_FILTER: ‘gem_bfs=2601+OR+gem_bfs=2513’
‘isBaseLayer’: false, ‘visibility’: false, ‘buffer’: 0
regards
Stefan
Von: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Gesendet am: Freitag, 2. Mai 2008 00:19
An: Ziegler Stefan
Cc: geoserver-users
Betreff: Re: [Geoserver-users] cql_filter and string encoding
Hi Stephan,
What version of GeoServer are you using? I know a while back there was
an issue with cql filters similar to this one. I also tried an or filter
similar to this one and it worked ok.
If you are using pre 1.6.1 please upgrade. If not can you include the
source of the openlayers map. Thanks.
-Justin
Ziegler Stefan wrote:
Hi
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
I have a problem using cql_filter with a “OR” statement. The filter
looks like this: “cql_filter: ‘gem_bfs=2520+OR+gem_bfs=2521’” (as option
in a OpenLayers layer definition). OpenLayers (or is it the browser??)
then encodes the filter to: “gem_bfs%3D2520%2BOR%2Bgem_bfs%3D2521”. The
“%3D” would work but encoded ±sign (“%2B”) results in a wms exception:ServiceExceptionReport SYSTEM
“http://schemas.opengis.net/wms/1.1.1/WMS_exception_1_1_1.dtd”>
Could not parse CQL filter list.Encountered "OR" at line 1,
column 14.
Was expecting one of:
<STRING_LITERAL> …
"true" …
"false" …
<INTEGER_LITERAL> …
<FLOATING_LITERAL> …
<IDENTIFIER> …
: gem_bfs=2520+OR+gem_bfs=2521, Current Token : +
Encountered "OR" at line 1, column 14.
<STRING_LITERAL> …
"true" …
"false" …
<INTEGER_LITERAL> …
<IDENTIFIER> …
<STRING_LITERAL> …
"true" …
"false" …
<INTEGER_LITERAL> …
<IDENTIFIER> …regards
StefanMit freundlichem Gruss
Stefan Ziegler
Leiter AufsichtKanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler@anonymised.com
http://www.so.ch!DSPAM:4007,4819f53a278095409313003!
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Don’t miss this year’s exciting event. There’s still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone!DSPAM:4007,4819f53a278095409313003!
Geoserver-users mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-users!DSPAM:4007,4819f53a278095409313003!
Justin Deoliveira
The Open Planning Project
