abelq
1
I create a layer with a simple cql_filter
new OpenLayers.Layer.WMS( 'layer 1', 'http://dmz:8080/geoserver/wms’,
{CQL_FILTER: 'mod_codigo = 3',layers: topp:lineas, transparent:'true',
styles: '', srs: 'EPSG:4326', tiled: 'true',}, { 'reprojected':true,
'isBaseLayer': false, 'opacity': 0.5 },{buffer: 0});
It work!
But
How do I make a conditional composed?
Example
{CQL_FILTER: 'mod_codigo = 3 and cap_codigo = 400',layers: topp:lineas,
transparent:'true', styles: '', srs: 'EPSG:4326', tiled: 'true',}, {
'reprojected':true, 'isBaseLayer': false, 'opacity': 0.5 },{buffer: 0});
This don't work!
Thank you
Abel
View this message in context: http://www.nabble.com/CQL_FILTER-%3A-condicional-composed-tp22874240p22874240.html
The syntax looks fine. What exactly happens. Do you get a blank map? Do you get an exception from GeoServer? More info might help.
-Justin
It work!
But
Example
This don't work!
Thank you
Abel
Justin Deoliveira
OpenGeo - http://opengeo.org
