[Geoserver-users] CQL_FILTER with IN
Hello,
I'm developing an web application based on OpenLayers 3 and Geoserver 2.9.0. In this application, the user can search in a database containing about 8000 entries of species with their locations. The search result is then displayed in a map with the locations of the found species.
To this end, I first do a database query based on the search parameters (using PHP), which returns a list of species ids. I then forward this list to Geoserver with a WFS request using CQL_FILTER such as
   CQL_FILTER=SpeciesID IN (16,17,18,40,41,...)
Geoserver then returns a map with only these species in the search result, which is fine. However, I run into performance problems when the list of ids becomes too large. For 8000 ids, it takes Geoserver about 2 minutes to draw the map which is way too long. The database query may return anything between 0 and 8000 results.
Is there another way to solve this problem more efficiently or some way I can optimize Geoserver for this? I would be glad for any help.
Sincerely,
Eva
Hi Eva,
Which database are you using? There may be an optimization which can be made for your database.
By chance is the data something which could be shared publicly? Another possibility is that the slowness is a bug in a GeoTools datastore implementation. If so, it'd be great to have a bug report.
It may be counterintuitive, but one really, really simple option may be to export your database as a CSV or Shapefile and skip using a database. Some of the fastest queries may become a little slower, but you'd never run into a 2 minute bottleneck.
Jim
On 06/27/2016 08:38 AM, emgerstner wrote:
Hello,
Sincerely,
Eva
Attend Shape: An AT&T Tech Expo July 15-16. Meet us at AT&T Park in San
Francisco, CA to explore cutting-edge tech and listen to tech luminaries
present their vision of the future. This family event has something for
everyone, including kids. Get more information and register today.
http://sdm.link/attshape
Geoserver-users mailing list
Probably Geoserver itself in not slow but if gets results from the data source slow. Where do you keep your data?
-Jukka Rahkonen-
Lähettäjä: emgerstner
Lähetetty: ‎27.‎6.‎2016 16:05
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: [Geoserver-users] CQL_FILTER with IN
Hello,
I’m developing an web application based on OpenLayers 3 and Geoserver
CQL_FILTER=SpeciesID IN (16,17,18,40,41,…)
Sincerely,
Eva
Hi Jukka,
i’m running PostgreSQL (with PostGIS) 9.2.14. From the Geoserver log file, I see that the call is converted into something like
Request: getFeature
service = WFS
version = 1.0.0
baseUrl = http://localhost:8080/geoserver/
query[0]:
filter = [[ SpeciesID = 16 ] OR [ SpeciesID = 17 ] OR [ SpeciesID = 18 ] OR [ SpeciesID = 40 ] OR [ SpeciesID = 41 ] OR …
In the PostgreSQL log, I see the following query
SELECT “SpeciesID”,“Name”,encode(ST_AsEWKB(“geom”),‘base64’) as “geom” FROM “public”.“view_map” WHERE ((“SpeciesID” = 16 AND “SpeciesID” IS NOT NULL ) OR (“SpeciesID” = 17 AND “SpeciesID” IS NOT NULL ) OR (“SpeciesID” = 18 AND “SpeciesID” IS NOT NULL ) OR …
The query itself is quite slow (about 10 sec for 8000 ids), but the main performance loss appears to be with Geoserver. I’m not sure, but this seems to me an inefficient way to handle the CQL_FILTER request.
Sincerely,
Eva
Am 27.06.2016 um 15:31 schrieb Rahkonen Jukka (MML):
-Jukka Rahkonen-
Hello,
Sincerely,
Eva
Eva,
I assume you have an index on SpeciesID?
Ian
On 27 June 2016 at 15:31, emgerstner <eva-maria.gerstner@anonymised.com> wrote:
Hi Jukka,
Request: getFeature
service = WFS
version = 1.0.0
query[0]:
Sincerely,
Eva
-Jukka Rahkonen-
Hello,
Sincerely,
Eva
Ian Turton
On Mon, Jun 27, 2016 at 4:31 PM, emgerstner <
   SELECT "SpeciesID","Name",encode(ST_AsEWKB("geom"),'base64') as "geom"
FROM "public"."view_map" WHERE (("SpeciesID" = 16 AND "SpeciesID" IS NOT
NULL ) OR ("SpeciesID" = 17 AND "SpeciesID" IS NOT NULL ) OR ("SpeciesID" =
18 AND "SpeciesID" IS NOT NULL ) OR ...
performance loss appears to be with Geoserver. I'm not sure, but this seems
The not null checks are redundant for sure, but there is no notion of "att
in (list of values)" in OGC filter, so we have nothing else to translate
into (e.g., we have
no way to represent it in our code, we'd have to go beyond the tools that
OGC provided us there, with some risk of becoming non compliant).
What version of GeoServer is that?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Jim,
the data is proprietary at the moment, but the application will be launched in a few months.
I think the problem lies with Geoserver's handling of the CQL_FILTER=... IN (...) request. OpenLayers 2 has some client-side filtering, which appears to be faster, but map performance is much poorer than in OpenLayers 3.
i would like to keep the database, since the queries can be quite complex (such as looking for species names, species properties, geographical constraints and so on). Also data needs to be added or edited all the time.
Sincerely,
Eva
Am 27.06.2016 um 15:26 schrieb Jim Hughes:
Hi Eva,
Jim
Hello,
Sincerely,
Eva
Hi Ian,
the problem is that I have a view, where i can’t have an index. I could try using a materialized view, but I think the main performance problem lies elsewhere, and I’m not sure if I’m using the right approach here.
Sincerely,
Eva
Am 27.06.2016 um 16:37 schrieb Ian Turton:
Eva,
Ian
Hi Jukka,
Request: getFeature
service = WFS
version = 1.0.0
query[0]:
Sincerely,
Eva
-Jukka Rahkonen-
Hello,
Sincerely,
Eva
Geoserver-users@anonymised.comorge.net
Ian Turton
Hi Andrea,
I’m running Geoserver 2.9.0. If I cannot use “attribute in (list of values)”, is there another way of setting up such a filter which may be more efficient?
Sincerely,
Eva
Am 27.06.2016 um 16:41 schrieb Andrea Aime:
On Mon, Jun 27, 2016 at 4:31 PM, emgerstner <eva-maria.gerstner@anonymised.com> wrote:
The not null checks are redundant for sure, but there is no notion of “att in (list of values)” in OGC filter, so we have nothing else to translate into (e.g., we have
no way to represent it in our code, we’d have to go beyond the tools that OGC provided us there, with some risk of becoming non compliant).
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Jun 27, 2016 at 4:58 PM, emgerstner <
Hi Ian,
the problem is that I have a view, where i can't have an index. I could
lies elsewhere, and I'm not sure if I'm using the right approach here.
If you have a view, I'd try the approach of setting a GeoServer parametric
sql view instead, make the list of speciesId a parameter (with the right
validation expression, mind sql injection attacks) and then pass them via
the view_params parameter.
See here:
http://docs.geoserver.org/stable/en/user/data/database/sqlview.html
Ing. Andrea Aime
@geowolf
Technical Lead
Dear all,
we have troubles in cascading a WMS layer for the OSM of Italy, it is served as basemap to another server’s layer that is used for generating dynamic PDFs.
The architecture is made on two servers (both on Geoserver 2.6.2):
  • SERVER-A, is the map server to publish our replica of the Italian OSM. It works on top of a PostGIS that is synced periodically with OSM planet and it uses styles for points, polygons and lines.
  • SERVER-B, is the map server we provided our client; it uses the WMS rendered by SERVER-A as base layer for another WMS services used for PDF generation.
    Server A and B are in the same network on Digital Ocean. Moving the access to the data and the rendering to the SERVER-B is not an option for now.
We have two kinds of problems, we do not know whether they are related or not:
  • SERVER-B Tomcat crashes periodically, so far we were not able to find any message in the catalpa.out log. We are not sure it is the right place to check as we are not experts of Tomcat.
  • SERVER-A becomes very slow; when this happens the direct calls to WMS done through the SERVER-B and SERVER-A are still working, but the Geoserver admin panel cannot use or preview the SERVER-A basemap, the exception says that the underlying service does not exists.
We wonder whether there is some specific documentation, or somebody can give hints about tracking the errors.
More, we are sure the servers are under-dimensioned. Is there any specific reference to dimensioning and performance optimization on geoserver? Anybody with a similar experience? In your experience should the server chaining the WMS and overlaying few points to it be dimensioned similar to the server doing the OSM rendering?
Thanks for any help.
Simone
Smart technologies for bright ideas
Simone Gadenz
CEO
Mobile: +39 331 72 35 993
Office: +39 0577 588 408
Web: http://www.beecome.it
Hi Andrea,
the parametric sql view did the trick! Thank you very much for your advice,
Eva
Am 27.06.2016 um 17:07 schrieb Andrea Aime:
On Mon, Jun 27, 2016 at 4:58 PM, emgerstner <eva-maria.gerstner@anonymised.com> wrote:
Hi Ian,
If you have a view, I’d try the approach of setting a GeoServer parametric sql view instead, make the list of speciesId a parameter (with the right
validation expression, mind sql injection attacks) and then pass them via the view_params parameter.
See here:
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea,
We’ve hit similar issues in query planning for GeoMesa for queries like this.
If I understand correctly, “attr IN(value1, value2, …)” is part of ECQL. While I know that GeoTools/GeoServer could not depend on OpenLayers to integrate with GeoServer extensions, would there be any possibility to offer tools/library code to ‘collect’ up ORs like this for GeoTools datastores to leverage? It might be a fun activity for a OSGeo code sprint…
Jim
Ing. Andrea Aime
@geowolf
Technical Lead
[http://sdm.link/attshape](http://sdm.link/attshape)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
On Mon, Jun 27, 2016 at 7:06 PM, Jim Hughes <jnh5y@anonymised.com> wrote:
Hi Andrea,
We've hit similar issues in query planning for GeoMesa for queries like
this.
If I understand correctly, "attr IN(value1, value2, ...)" is part of
offer tools/library code to 'collect' up ORs like this for GeoTools
sprint...
When it comes to databases, in theory, the following two are 100%
equivalent, and the query planner should figure it out (Oracle did not a
few years ago, but that should be fixed):
ATT in (v1, v2, ...., vn)
ATT = v1 or ATT = v2 or ... ATT = vn
The translation with the not null over properties is a bit strange, I
actually think there was a reason for that but right now it escapes me,
worth investigating.
Collecting ORs is simple enough, already has examples, see
SimplifyingFilterVisitor, no need to wait for a code sprint :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
Dear all,
Simone
Simone Gadenz
CEO
