[Geoserver-users] CQL filter WITHIN: format of POLYGON representation
Hello!
I am new to using Geoserver and it’s CQL filterand have one question.
When using spatial filters like this on examples: DISJOINT(the_geom, POLYGON((-90 40, -90 45, -60 45, -60 40, -90 40))) is it possible to use different representation of POLYGON part, not in WKT.
My OpenLayers3 map return coordinates of polygons like this : 576672.21, 6540257.09, 577359.71, 6542209.21, 577989.29, 6542495.86, 579026.17, 6541711.21, 580419.39, 6543269.1, 580664.17, 6544099.43, 580614.18, 6544955.09, 580758.17, 6545791.38, 580813.78, 6547493.59, 580882.3, 6547787.52, 580811.63, 6548021.38, 580393.4, 6548714.35, 579647.81, 6549517.7, 579875.04, 6549978.3, 580612.03, 6550602.42, 581146.45, 6551166.54, 582119.77, 6550856.96, 582810.92, 6550037.72, 582907.41, 6549233.2, 583739.4, 6548619.18, 584351.43, 6550480.94, 584724.81, 6551373.5, 585079.15, 6551780.8, 585214.53, 6552210.45, 584823.45, 6552596.57, 583550.39, 6553106.82, 582713.1, 6553609.79, 582769.21, 6554368.62, 583547.58, 6555687.69 and so on.
Is it possible to use them like this?
Tried this, but with no success.
http://loom-gis.geo.ut.ee:8080/geoserver/ermas/ows?service=WFS&version=1.0.0&request=GetFeature&typeName=ermas:testdata_geopnt&outputFormat=text/javascript&format_options=callback:loadFeatures&maxFeatures=300&srsname=EPSG:3301&EPSG:3301&cql_filter=within%28geometry,POLYGON%28%28556500,%206445500,%20637750,%206470250%29%29%29
And what would be geoserver behavior if my polygon contains around 700 points like that I mentioned.
Thanks for any help!
On Thu, Nov 6, 2014 at 5:42 PM, Olga Troškina <olga.troskina@anonymised.com>
wrote:
Hello!
I am new to using Geoserver and it's CQL filterand have one question.
No, WKT is the only supported syntax for any geometry literal in CQL
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Look at http://openlayers.org/en/v3.0.0/apidoc/ol.format.WKT.html#writeGeometry to get the WKT for your feature.
In OL2 you could just write feature.geometry.toString() and you would get the WKT. Not sure if that works now.
/Olle
On Thu, Nov 6, 2014 at 5:51 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Geoserver-users mailing list
On Thu, Nov 6, 2014 at 5:42 PM, Olga Troškina <olga.troskina@anonymised.com> wrote:
Hello!
Ing. Andrea Aime
@geowolf
Technical Lead
Hi again,
Forgot to answer one of your questions.
I bet GeoServer wouldn’t have any problem with 700 points.
But I bet the browser would. Given that your coordinates have 9-10 chars and you have 700 points that would render about 140000 characters, right?
Browsers doesn’t allow unlimited length on URL:s. See http://stackoverflow.com/questions/417142/what-is-the-maximum-length-of-a-url-in-different-browsers
I normally use the 2048 limit as stated in that link.
I have a case where an application creates several hundreds of id:s to filter. Given that they aren’t connected to eachother I can separate these in separate layers in OL.
But that does not work with a polygon…
Try to use the WFS format to create a GetFeature XML document that you can POST to GeoServer instead of using GET.
http://openlayers.org/en/v3.0.0/apidoc/ol.format.WFS.html#writeGetFeature
Perhaps this question should go on the OpenLayers mailing list.
Or http://stackoverflow.com/questions/tagged/openlayers-3
Or http://gis.stackexchange.com/questions/tagged/openlayers-3
Olle Markljung
On Thu, Nov 6, 2014 at 6:03 PM, Olle Markljung <markljung@anonymised.com4…> wrote:
/Olle
Hello!
Ing. Andrea Aime
@geowolf
Technical Lead
