On Sun, Jun 14, 2015 at 11:23 PM, emmexx <emmexx@anonymised.com> wrote:
After the root partition of the server where an instance of geoserver
(2.8 master) is running became full, I'm no more able to run it.
Many configuration files are lost (wcs.xml, wfs.xml, wms.xml have zero
size), the connections to postgis is no more working and in the
geoserver log I found this WARN as last notification:
WARN [support.DisposableBeanAdapter] - Invocation of destroy method
failed on bean with name 'geoServerLoader':
org.springframework.beans.factory.BeanCreationNotAllowedException: Error
creating bean with name 'geoWebCacheExtensions': Singleton bean creation
not allowed while the singletons of this factory are in destruction (Do
not request a bean from a BeanFactory in a destroy method implementation!)
2 questions:
1. Is that the expected behaviour?
In case of disk full there is no expected behavior, we do not have tests
covering that case, nor I think the configuration subsystem is designed
to cope with such case.
Generally speaking, config wise, all we do is to write changes to
a temporary file, and then move the file over the previous one, using
an atomic rename on *nix systems, and a "delete and move" one
on Windows where atomic renames are not available.
Code here, if anyone as suggestions on how to make it better, it
would be appreciated:
https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/org/geoserver/data/util/IOUtils.java#L480
That said... as far as I know, we only change one file at a time,
and fail in case of IO error so... if you have many files corrupted, I may
be
that you had something that insisted on making changes on the configuration
despite the errors, and ended up ruining multiple files?
2. Is there some kind of recovery procedure?
If the file contents is lost... it's lost.
For the service files (wms.xml and friends) you can find copies you
can restart from here:
https://github.com/geoserver/geoserver/tree/master/data/release
Hopefully those are the only you have ruined.
3. I don't have a recent backup of the "data" directory.Is there a way
to understand what files are corrupted or lost?
No guidelines here either, but a 0 length file is a good indicator
that the file is gone
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
