Andrea,
Thanks for the reply, you are usually very helpful with my queries to the geoserver lists, but really that is not a very constructive reply today.
I have already tried many things before posting to the list and I looked at the REST API in detail. It is not clear exactly how the description of the datastore maps to the information to create it. Perhaps you have not looked either, as existing shape file directories are described as below, but that leaves much to be desired in understanding how to create. Please see the comments after.
“dataStore”:{
“name”:“myStore”,
“type”:“Directory of spatial files (shapefiles)”,
“enabled”:true,
“workspace”:{
“name”:“myWs”,
“href”:“http://gis.mysite.com/rest/workspaces/myws.json”
“connectionParameters”:{
“entry”:[
{“@key”:“memory mapped buffer”,“$”:“false”},
{“@key”:“timezone”,“$”:“Europe/London”},
{“@key”:“fstype”,“$”:“shape”},
{“@key”:“create spatial index”,“$”:“true”},
{“@key”:“charset”,“$”:“ISO-8859-1”},
{“@key”:“filetype”,“$”:“shapefile”},
{“@key”:“cache and reuse memory maps”,“$”:“false”},
{“@key”:“enable spatial index”,“$”:“true”},
{“@key”:“url”,“$”:“file:gisdata/myData”},
{“@key”:“namespace”,“$”:“wheatstone”}
“_default”:false,
“featureTypes”:“http://gis.seaplanner.com/rest/workspaces/myws/datastores/mystore/featuretypes.json”
For a start, name and workspace are specified in the POST url, so I guess those are optional?
The href attributes as well, seem unnecessary for a create, so I guess these should not be needed?
Posting type as “Directory of spatial files (shapefiles)” would also seem a bit odd, is that really the way?
As far as connection parameters, are they really specified in this convoluted format? And will it use defaults not set?
Same with “_default” why underscore? And is it Optional, default false?
featureTypes again, this is like the href attributes, seems inappropriate for a create/post, presumably excluded.
So really, what I am still asking is as before, what should be the right data structure?
The curl example, only seems to describe creation with name and workspace, putting the file path in the body:
curl -v -u admin:geoserver -XPUT -H "Content-type: text/plain"
-d "file:///data/shapefiles/"
"http://localhost:8080/geoserver/rest/workspaces/acme/datastores/shapefiles/external.shp?configure=all"
If I want a name, description it is not clear.
Mark
From: andrea.aime@…84… [mailto:andrea.aime@…84…] On Behalf Of Andrea Aime
Sent: 06 June 2014 11:55
To: Mark Paxton
Cc: Geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Create Directory of Shape files Datastore with REST API & JSON
On Fri, Jun 6, 2014 at 12:45 PM, Mark Paxton <mark.paxton@…6564…> wrote:
Hello all,
Please could I ask for a little help – I am trying to create a datastore from a dir of shapefiles already on the server, using JSON via REST API.
I am unsure of the correct data structure to post to the server, as the documentation is not quite exhaustive in this area.
Whenever something is not documented there is an easy way to discover the data structure you need:
go into the user interface, create the objects you need
go into the rest api, and grab their xml/json representation
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
