After a bit of fiddling, I've managed to get a connection to our Oracle DB
setup. The only trouble is that when I use the Create New FeatureType
option, it does not pick up all of the fields. Looking at the log, I see
'Unknown SQL Type: NVARCHAR2' and 'Unknown SQL Type: ST_GEOMETRY' - the
latter is obviously the most annoying. And slightly baffling, as I thought
this was the standard name.
I'm using the thin Oracle client on port 1521, with the ojdbc14.jar. I've
tried going to the Confluence page mentioned in the Oracle plugin zip, but
this doesn't appear to be current.
Can someone point a newbie in the right direction? I think I'm pretty
close.
Thanks in advance,
Frank
View this message in context: http://www.nabble.com/Create-FeatureType-on-Oracle-not-picking-up-certain-column-types%2C-including-ST_GEOMETRY-tp18576892p18576892.html
