After a bit of fiddling, I've managed to get a connection to our Oracle DB
setup. The only trouble is that when I use the Create New FeatureType
option, it does not pick up all of the fields. Looking at the log, I see
'Unknown SQL Type: NVARCHAR2' and 'Unknown SQL Type: ST_GEOMETRY' - the
latter is obviously the most annoying. And slightly baffling, as I thought
this was the standard name.
I'm using the thin Oracle client on port 1521, with the ojdbc14.jar. I've
tried going to the Confluence page mentioned in the Oracle plugin zip, but
this doesn't appear to be current.
Can someone point a newbie in the right direction? I think I'm pretty
close.
Thanks in advance,
Frank
View this message in context: http://www.nabble.com/Create-FeatureType-on-Oracle-not-picking-up-certain-column-types%2C-including-ST_GEOMETRY-tp18587598p18587598.html
AFAIK ST_GEOMETRY is the ESRI geometry type for Oracle, so it's not strange that Geoserver does not know this type. Maybe if you connect as ArcSDE it might work.
The standard in Oracle Spatial is SDO_GEOMETRY.
Best regards,
Bart
FrankMcLean wrote:
close.
Thanks in advance,
Frank
Bart van den Eijnden
OSGIS, Open Source GIS
bartvde@anonymised.com
http://www.osgis.nl
Hi Bart,
Thanks for the reply. The ST_GEOMETRY we're using is 'qualified' (?) as
SDE.ST_GEOMETRY, though I note that there is also an MDSYS.ST_GEOMETRY type,
which I suspect is the Oracle standard - from poking around in the defs, if
looks like a wrapper for SDO_GEOMETRY.
From what you say, it sounds like the Oracle option in GeoServer should be
read as 'Use Oracle spatial types' rather than just 'connect to Oracle', as
I was reading it. It expects Oracle to be using the SDO_GEOMETRY type,
rather than the SQL/MM standard, which makes sense. Is this all ultimately
a GeoTOOLS issue?
Of course, that doesn't explain the NVARCHAR2 issue, but it falls within the
same area, I guess.
Thanks, Bart.
Frank
Best regards,
Bart
FrankMcLean wrote:
DB
thought
I've
but
close.
Thanks in advance,
Frank
http://www.osgis.nl
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Create-FeatureType-on-Oracle-not-picking-up-certain-column-types%2C-including-ST_GEOMETRY-tp18587598p18611860.html
FrankMcLean ha scritto:
Hi Bart,
a GeoTOOLS issue?
same area, I guess.
Yep, both are GeoTools issues. The Oracle datastore code can only read
SDO_GEOMETRY and will only recognize that, to add support for a different geometry encoding quite a big of code has to be created, ranging from pure reading/writing to the way spatial filter functions
have to be encoded.
Supporting NVARCHAR2 is similar (some code needs to be written), but seems a lot easier, provided it's ok to load all of the NVARCHAR2
attribute value in memory (I actually don't know if that type is a
very large char or just an odd variant of VARCHAR).
