[Geoserver-users] Create SQL View - "Table or biew does not exist"?
Hi List,
I’ve come across something weird and wondered if anyone could help.
I’m creating a new SQL view. The query:
select * from TRO_ORDERS where DATE_FROM <= %from_date% and (DATE_TO >= %to_date% or DATE_TO is null)
With the “SQL view parameters” filled in correctly, I then press “refresh” for it to load the attributes, but I get an Oracle error:
“ORA-00942: table or view does not exist”
However that table does exist. If I take the SQL generated from the logs and put it directly into SQL Developer, it works fine with no error but I get no results.
The SQL from the logs is:
select * from (select * from TRO_ORDERS where DATE_FROM <= 20130102 and (DATE_TO >= 20130102 or DATE_TO is null)) VTABLE where 1 = 0
If I trim this down (removing the stuff that GeoServe rappears to have added) to:
select * from TRO_ORDERS where DATE_FROM <= 20100102 and (DATE_TO >= 20100102 or DATE_TO is null)
That works and does return results.
Can anyone advise what’s going on? GeoServer can add the TRO_ORDERS layer just fine as a regular layer, so I’m not sure why it is having issues as a SQL View.
I’ve had a similar SQL view working previously too, so I know it can work.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Figured it out. Turns out GeoServer doesn’t add the schema for Oracle SQL Views. Created a JIRA issue for it as it seems inconsistent (the schema has to be in the store declaration).
http://jira.codehaus.org/browse/GEOS-6084
Seems more like it might be a design decision than an outright bug, but reported anyway just in case. :slight_smile:
Jonathan
On 11 October 2013 12:49, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi List,
Jonathan
Hi Jonathan
Maybe you have a problem with the schema name. Normally, a table name consists of two parts, .. If you omit the schema name, a default is used (depends on the database, for DB2 this is the current user name).
On Fri, Oct 11, 2013 at 1:49 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi List,
Jonathan
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60134071&iu=/4140/ostg.clktrk
Geoserver-users mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Hi Christian,
Thanks, we seem to have crossed emails, but that was the conclusion in the end. It seems GeoServer doesn’t prefix the specified schema name to Oracle SQL Views.
Jonathan
On 11 October 2013 13:10, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi Jonathan
Hi List,
Jonathan
On Fri, Oct 11, 2013 at 2:09 PM, Jonathan Moules <
Figured it out. Turns out GeoServer doesn't add the schema for Oracle SQL
Indeed, GeoServer does not interpret or modifies the sql you provide, it
uses it "as is" (minus the sql view params).
So, it's up to you to specify the necessary schema names in the sql
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea,
But then surely as I’ve explicitly declared a schema in the Store that should be used? I guess expectations may be different between users, but that’s what I’d expect to happen. I don’t normally include the schema myself in any of my queries in any software I use - not even SQL Developer where I’ve entered raw SQL - it is always added transparently.
So I think there’s a case for doing so with GeoServer. Anyone else have an opinion?
Jonathan
On 11 October 2013 16:51, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Oct 11, 2013 at 2:09 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Indeed, GeoServer does not interpret or modifies the sql you provide, it uses it “as is” (minus the sql view params).
So, it’s up to you to specify the necessary schema names in the sql
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Oct 14, 2013 at 1:45 PM, Jonathan Moules <
Hi Andrea,
But then surely as I've explicitly declared a schema in the Store that
that's what I'd expect to happen. I don't normally include the schema
where I've entered raw SQL - it is always added transparently.
This is because these tools setup the "default schema" or "search path"
before giving you a sql
editor to play with.
GeoServer could do the same, it could be an extra sql that send to the
database when retrieving a connection from the pool.
Of course this would have a cost, it would result in an extra call to the
dbms, maybe we should limit it to sql views... and
not everybody would be happy to have it because of that.
Plus, as icing on the cake, setting the default schema uses db specific
sql, so one would have to setup all the dialects we have
with their own custom way of setting the schema (e.g., it's "set
search_path to 'schema'" for postgresql,
"ALTER SESSION SET CURRENT_SCHEMA=schema" for Oracle, and so on)
information.
Ing. Andrea Aime
@geowolf
Technical Lead
