Hii
I want to add a new feature layer in PostGreSQL from open layers.
I got the answer from openlayers forum as...
http://osgeo-org.1560.x6.nabble.com/creating-a-new-layer-in-database-td5089934.html
Using openlayers directly you can't do this:
You need to call from openlayers some server-side code (i.e. java or
c# or whatever you wanna use) that, in order:
1. enstablish a connection to postgres db
2. launch a series of sql commands that create a table, fields,
indices and so on
3. call the geoserver rest api and configure geoserver accordingly:
I have created table using the c# code.
Now I want to publish a layer in GeoServer using REST API.
I saw the documentation of GEoSever REST API. I could not find anything
which can help me do this. I can see the existing layers, workspaces etc.
but I cannot create any layer.
Any help..
Thanks and Regards
Pankaj Bansal
View this message in context: http://osgeo-org.1560.x6.nabble.com/Creating-a-new-layer-in-GeoServer-from-PostGreSQL-table-tp5090539.html
for what concerns the GeoServer REST API, you need that after you have completed points 1 and 2.
Here you can find some examples using curl to create all the objects you may need: http://docs.geoserver.org/stable/en/user/rest/examples/curl.html
You can also find examples in some programming languages here: http://docs.geoserver.org/stable/en/user/rest/examples/index.html (not for C# I’m afraid).
What you could need is:
If you are going to use that from c# and you would like to contribute back some examples in that language to enrich the documentation it would be awesome.
Mauro
2013/11/21 pankaj123 <pankaj.bansal.jiit@anonymised.com>
Hii
I got the answer from openlayers forum as…
Using openlayers directly you can’t do this:
- enstablish a connection to postgres db
- launch a series of sql commands that create a table, fields,
indices and so on
- call the geoserver rest api and configure geoserver accordingly:
Any help…
Thanks and Regards
Pankaj Bansal
Shape the Mobile Experience: Free Subscription
Software experts and developers: Be at the forefront of tech innovation.
Intel(R) Software Adrenaline delivers strategic insight and game-changing
conversations that shape the rapidly evolving mobile landscape. Sign up now.
http://pubads.g.doubleclick.net/gampad/clk?id=63431311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
