[Geoserver-users] Creating a plugin in Eclipse
I created a plugin for GeoServer a while ago using the basic tutorial in the
documentation. I was wondering how to create a plugin using the GeoServer
source in Eclipse that can just be compiled as needed when I run from
source.
Jon
View this message in context: http://www.nabble.com/Creating-a-plugin-in-Eclipse-tp15714663p15714663.html
Hi Jon,
You have a couple of options.
1) Modify the pom.xml in teh web module and have it depend on your plugin module. Then re-run eclipse:eclipse.
2) In Eclipse, manually alter the build path of the web project and add a dependency on your plugin module. This will get wiped out however the next time you run eclipse:eclipse.
Hope that helps.
-Justin
Jon Britton wrote:
source.
Jon
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Ok, thanks. I think I've sorted it out now.
I do have another problem however. My plugin worked fine before under 1.5.0,
but now GeoServer won't find it when I call it. I made my service contructor
(extending AbstractService) output to the command line and this seems to
work out, but the Dispatcher doesn't find it! I assume this has something to
do with my applicationContext but I can't find what it is.
Here it is:
<!DOCTYPE beans PUBLIC "-//SPRING//DTD BEAN//EN"
"http://www.springframework.org/dtd/spring-beans.dtd&quot;&gt;
<beans>
  <!-- the cds service. -->
  <bean id="cds"
    class="uk.ac.glam.geoserver.global.CDS">
    <constructor-arg ref="data"/>
  </bean>
  <!-- this registers the above beans with the servlet context
   it is around to keep the struts app happy as we move away from
   servlets -->
  <bean id="cdsRegisterar"
    class="org.vfny.geoserver.global.GeoServerServletContextInitializer">
    <constructor-arg type="java.lang.String" value="CDS"/>
    <constructor-arg ref="cds"/>
  </bean>
  <bean id="cdsAbstractService" abstract="true"
    class="org.vfny.geoserver.servlets.AbstractService">
    <!-- reference to geoserver bean defined in the 'main' context -->
    <property name="geoServer" ref="geoServer"/>
    <property name="catalog" ref="data"/>
  </bean>
  <bean id="cdsGetChanges"
    class="uk.ac.glam.geoserver.cds.servlets.Changes"
    parent="cdsAbstractService">
  </bean>
</beans>
jdeolive-2 wrote:
Hi Jon,
Hope that helps.
-Justin
Jon Britton wrote:
the
source.
Jon
Justin Deoliveira
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Creating-a-plugin-in-Eclipse-tp15714663p15716521.html
Hmm.. I was just looking at the code for the WCS class and noticed that it
calls setId("wcs") in it's constructors. Is this something I need to do for
my plugin? I didn't have to before.
Jon
1.5.0, but now GeoServer won't find it when I call it. I made my service
constructor (extending AbstractService) output to the command line and
this seems to work out, but the Dispatcher doesn't find it! I assume this
has something to do with my applicationContext but I can't find what it
is.
Here it is:
<beans>
  <bean id="cds"
  </bean>
   servlets -->
  </bean>
  </bean>
  </bean>
</beans>
jdeolive-2 wrote:
Hi Jon,
Hope that helps.
-Justin
Jon Britton wrote:
the
source.
Jon
Justin Deoliveira
View this message in context: http://www.nabble.com/Creating-a-plugin-in-Eclipse-tp15714663p15734921.html
I don't believe it is necessary. There is no code that relies on this being set.
It sounds like you are writing a plug-in for a new service? Do tell.
-Justin
Jon
is.
Here it is:
<beans>
  <bean id="cds"
  </bean>
   it is around to keep the struts app happy as we move away from servlets -->
  </bean>
  </bean>
  <bean id="cdsGetChanges" class="uk.ac.glam.geoserver.cds.servlets.Changes"
  </bean>
</beans>
jdeolive-2 wrote:
Hi Jon,
Hope that helps.
-Justin
Jon Britton wrote:
the
source.
Jon
Justin Deoliveira
Justin Deoliveira
Yeh, this is something I did during my MSc dissertation but didn't really
manage to get very far. I had a working service that subtracted two images
using a specified spectral band and then used a specified tolerance value to
classify between negative change or no change/positive change. It was to be
used for detecting changes in forestry. It only created a non-georeferenced
image since that's all I could get to work at the time, but the idea was to
vectorise the result into a shapefile or GML or something then send it back.
I can't remember now how to get this working with GeoServer. I seem to
remember that I changed web.xml to make it work but I can't get it working
now. Like I said, the constructors get called when GeoServer loads up but it
doesn't recognise it when I call it!
Jon
being set.
-Justin
it
for
Jon
this
is.
Here it is:
<beans>
  <bean id="cds"
  </bean>
   servlets -->
  </bean>
  </bean>
  </bean>
</beans>
jdeolive-2 wrote:
Hi Jon,
Hope that helps.
-Justin
Jon Britton wrote:
in
the
source.
Jon
Justin Deoliveira
Justin Deoliveira
View this message in context: http://www.nabble.com/Creating-a-plugin-in-Eclipse-tp15714663p15758288.html
