[Geoserver-users] Creating CSS styles using the REST API
Hi Geoservites!
I’m doing a project converting ESRI ArcIMS maps to modern PostGIS/GeoServer/OpenLayers.
I want to add hundreds of autogenerated CSS styles to GeoServer, but the API seems not to refuse uploading any style that isn’t an SLD. I’ve got the CSS extension installed and the documentation[1] seems to imply it should work.
Creating the style works fine:
curl -u admin:geoserver -XPOST -H ‘Content-type: text/xml’ -d ‘roads_styleroads.css’ http://localhost:8080/geoserver/rest/styles
Uploading the CSS file does not:
curl -u admin:geoserver -XPUT -H ‘Content-type: text/css’ -d @roads.css http://localhost:8080/geoserver/rest/styles/roads_style
Could not determine format. Try setting the Content-type header.
I’ve concluded that text/css isn’t supported by the API. Which sucks. Does anyone know otherwise? I’d like to try and patch this if it can be patched. For now I’m going to convert CSS-SLD before uploading.
Michael
[1] “Other extensions (such as css) add support for additional formats.” http://docs.geoserver.org/stable/en/user/rest/api/styles.html
