Andrea, thanks for your reply.
Strange, these classes are included in the postgres driver, and I do
not have a PGbox2d around at all, just PGbox3d (in my postgresql
jdbc driver I mean).
We do have a PGbox2d found in our postgis_1.0.0.jar, but not postgresql jdbc
driver.
A full stack trace would be nice, but it seems to me you're having
some kind of conflict between your postgres install and the jdbc
driver we're shipping. Or, have you replaced the driver with a
different one, or maybe put a different driver in your web containers
shared lib?
We are certain that we did not replace any of our drivers anywhere. Here is
the full stack trace:
form connection params { loose bbox=true, user="postgres", passwd="xxx",
wkb enabled=true, host="localhost", schema="public", port=5432,
database="xxx", dbtype="postgis"}
1777753 [SEVERE] org.geotools.data.postgis.PostgisDataStore - Could not
obtain DBInfo object
obtain PostgisDBInfo
org.geotools.data.DataSourceException: Connection
failed:org.postgresql.util.PSQLException: The class class
org.postgis.PGbox2d does not implement org.postgresql.util.PGobject.
at
org.geotools.data.jdbc.JDBC1DataStore.getConnection(JDBC1DataStore.java:1035
at
org.geotools.data.postgis.PostgisDataStore.getTypeNames(PostgisDataStore.jav
a:313)
at
org.vfny.geoserver.action.data.DataDataStoresEditorAction.execute(DataDataSt
oresEditorAction.java:144)
at
org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:98)
at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProces
sor.java:431)
at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at
org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Application
FilterChain.java:237)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterCh
ain.java:157)
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterE
ncodingFilter.java:122)
at
FilterChain.java:186)
at
ain.java:157)
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.ja
va:214)
at
org.apache.catalina.core.StandardValveContext.invokeNext(StandardValveContex
t.java:104)
at
org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:520)
at
org.apache.catalina.core.StandardContextValve.invokeInternal(StandardContext
Valve.java:198)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.ja
va:152)
at
t.java:104)
at
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:137
at
t.java:104)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:118
at
t.java:102)
at
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java
:109)
at
t.java:104)
at
at
org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:929)
at
org.apache.coyote.tomcat5.CoyoteAdapter.service(CoyoteAdapter.java:160)
at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:799)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConne
ction(Http11Protocol.java:705)
at
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:577)
at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.jav
a:683)
at java.lang.Thread.run(Thread.java:534)
Caused by: org.postgresql.util.PSQLException: The class class
at
org.postgresql.jdbc2.TypeInfoCache.addDataType(TypeInfoCache.java:110)
at
org.postgresql.jdbc2.AbstractJdbc2Connection.addDataType(AbstractJdbc2Connec
tion.java:429)
at
org.postgresql.jdbc2.AbstractJdbc2Connection.initObjectTypes(AbstractJdbc2Co
nnection.java:466)
at
org.postgresql.jdbc2.AbstractJdbc2Connection.<init>(AbstractJdbc2Connection.
java:136)
at
org.postgresql.jdbc3.AbstractJdbc3Connection.<init>(AbstractJdbc3Connection.
java:30)
at
org.postgresql.jdbc3.Jdbc3Connection.<init>(Jdbc3Connection.java:24)
at org.postgresql.Driver.makeConnection(Driver.java:369)
at org.postgresql.Driver.connect(Driver.java:245)
at java.sql.DriverManager.getConnection(DriverManager.java:512)
at java.sql.DriverManager.getConnection(DriverManager.java:171)
at
org.postgresql.ds.common.BaseDataSource.getConnection(BaseDataSource.java:82
at
org.postgresql.ds.common.BaseDataSource.getConnection(BaseDataSource.java:65
at
org.postgresql.ds.PGConnectionPoolDataSource.getPooledConnection(PGConnectio
nPoolDataSource.java:60)
at
org.geotools.data.jdbc.ConnectionPool.getConnection(ConnectionPool.java:122)
at
org.geotools.data.jdbc.JDBC2DataStore.createConnection(JDBC2DataStore.java:1
31)
at
org.geotools.data.jdbc.JDBC1DataStore.getConnection(JDBC1DataStore.java:1033
... 36 more
Anyone else has any idea?
Wai See
-----Original Message-----
Sent: Wednesday, December 20, 2006 4:10 PM
To: Lee Wai See
Subject: Re: [Geoserver-users] Creating datastore in GeoServer1.4.0:
PSQLException class org.postgis.PGbox2d does not implement
Lee Wai See ha scritto:
I just downloaded GeoServer 1.4.0 and tried to create a new PostgreSQL
datastore. However, when I submitted, I got the following exception:
Connection failed:org.postgresql.util.PSQLException: The class class
I am using PostgreSQL 8.0 and PostGIS 1.0.4-1. Previously I was using
GeoServer 1.3.0-RC2 with these same versions without this problem, so I
am not sure what is causing it with 1.4.0. I have tried the same
configuration on two different machines and the results are the same.
shared lib?
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.409 / Virus Database: 268.15.25/593 - Release Date: 12/19/2006
No virus found in this outgoing message.
[This e-mail is confidential and may be priviledged. If you are not the
intended recipient, please kindly notify us immediately and delete the message
from your system; please do not copy or use it for any purpose, nor disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
