[Geoserver-users] Creating datastore in GeoServer1.4.0: PSQLException class org.postgis.PGbox2d does not implement org.postgresql.util.PGobject
my name is Kim Sia and I am a colleague of Wai See. I am wondering if Justin has replied with regards to the questions raised by Wai See?
Thank you
–Original Message –
Lee Wai See ha scritto:
Hi Andrea,
Can you try and replace both postgis.jar and the postgres jdbc driver
included in geoserver with the ones shipping with your postgis install?
This works. Well, at least we did not get the exception anymore. But should
this be the correct way of handling it? I mean, would there be any
repercussions if we do it this way?
Unless there are bugs in the jdbc driver, not. In fact I’m investigating
why we do shipt with postgis.jar at all, since nothing I can see in the
postgis data store uses it.
And geoServer.war should just be of a deploy-and-use kind of web application
concept without doing any other changes/settings, right?
And usually it is, provided that your web container is clean. The only
way I can think you getting issues is using a container that has an
incorrect version of postgis.jar in the container shared libs
(/tomcat/shared/libs for tomcat) or worse in the jdk lib/ext… but it
may well be that I lack fantasy today and I’m not thinking about
something obvious :-p We’ll see if Justin can think of anything else.
[This e-mail is confidential and may be priviledged. If you are not the
intended recipient, please kindly notify us immediately and delete the message
from your system; please do not copy or use it for any purpose, nor disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
Sim Kim Sia ha scritto:
No, he did not. Hard to get answers these days, Christmas, end of year...
If you don't get answers report the request after the 8 January, this
is when most of the European/American/Canadian people get back to work
for good :slight_smile: (don't know about Justin, he may well be around today).
