I’m working on a project that has many different types of icons associated with different categories of features in a database. The graphics reside in the web directory of the same machine that is running Geoserver, and are used in other web-based applications besides Geoserver. At the moment, I am hard coding the URL links to the icons in my SLD file’s section. I would like to update this so that I use the database “ICONNAME” attribute which is being returned with my data, but I’m having trouble concatenating the URL and image name together.
How it currently looks:
image/png
How I would like it to look:
image/png
Is it possible for me to nest the ogc:PropertyNameICONNAME</ogc:PropertyName> value inside of the ExternalGraphic element this way?
Roger
Roger Andre ha scritto:
I'm working on a project that has many different types of icons associated with different categories of features in a database. The graphics reside in the web directory of the same machine that is running Geoserver, and are used in other web-based applications besides Geoserver. At the moment, I am hard coding the URL links to the icons in my SLD file's <ExternalGraphic> section. I would like to update this so that I use the database "ICONNAME" attribute which is being returned with my data, but I'm having trouble concatenating the URL and image name together.
<Graphic>
<ExternalGraphic>
<OnlineResource xlink:type="simple" xlink:href="http://12.345.67.89/BMGF/MapIcons/PROJ_LOCATION_9cdf63_symbologia2_30x30.gif"/>
<Format>image/png</Format>
</ExternalGraphic>
</Graphic>
<Graphic>
<ExternalGraphic>
<OnlineResource xlink:type="simple" xlink:href="http://12.345.67.89/BMGF/MapIcons/<ogc:PropertyName>ICONNAME</ogc:PropertyName>"/>
</ExternalGraphic>
</Graphic>
Is it possible for me to nest the <ogc:PropertyName>ICONNAME</ogc:PropertyName> value inside of the ExternalGraphic element this way?
Eh, I wish it was possible, but unfortunately the SLD standard
does not allow for that. xlink:href is a static string, to allow
for a dynamic address (which would have a number of interesting applications) we'd need something like:
<Graphic>
<ExternalGraphic>
<DynamicOnlineResource xlink:type="simple">
</DuynamicOnlineResource>
</ExternalGraphic>
</Graphic>
To support such a use case we would have to break strict compatibility
with the SLD standard and rool our own extension
Ok, is there any other way you can think of setting up the SLD so that it doesn’t have graphic values hard-coded into it? I saw an example of “database driven styling” that shows color values coming from the DB, so it seemed like there was a chance it might apply (somehow) to graphics as well.
<PolygonSymbolizer>
<Fill>
<CssParameter name="fill"><ogc:PropertyName>income_color</ogc:PropertyName></CssParameter>
<CssParameter name="fill-opacity">0.5</CssParameter>
</Fill>
<Stroke>
<CssParameter name="stroke"><ogc:PropertyName>income_color</ogc:PropertyName></CssParameter>
<CssParameter name="stroke-width">1</CssParameter>
</Stroke>
</PolygonSymbolizer>
Roger
name together.
image/png
image/png
applications) we’d need something like:
http://12.345.67.89/BMGF/MapIcons/ogc:PropertyNameICONNAME</ogc:PropertyName>
image/png
Roger André
GIS Developer/Analyst
CH2M HILL
Enterprise Management Solutions
Tel: 425.233.3042
Ok, is there any other way you can think of setting up the SLD so that it doesn't have graphic values hard-coded into it? I saw an example of "database driven styling" that shows color values coming from the DB, so it seemed like there was a chance it might apply (somehow) to graphics as well.
<PolygonSymbolizer>
<Fill>
This is because OGC decided that a CSSParameter can be made up
using ogc:Expression components (PropertyName being one)
whilst the reference to an external graphic is just an xs:string,
that is, a constant.
If you don't have many possible symbols you can makes
lots of Rule objects, each filtering on a different attribute
value. Something like:
<Rule>
<Filter>
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>attribute</ogc:PropertyName>
<ogc:Literal>10</ogc:Literal>
</ogc:PropertyIsEqualTo>
</Filter>
<GraphicSymbolizer>
</Rule>
and have a rule for each different value. It goes way verbose
very quickly, but at least it's supported by the SLD standard
as is.
