[Geoserver-users] *creating FeatureType using Oracle
if you use ArcSDE for converting data, it sometimes (depending to the
settings you use) adds a binary field to the data. Check this in oracle
with "desc table"; If so, you should delete this field. I did so too
(converting data with ArcSDE) and had some similar problems.
regards
Albrecht
aureate820 wrote:
> I have converted some shapfile data to oracle using ARCSDE.
> I was able to successfully create a new oracle data store.
> But when I try to create new feature type using the table
that I just
> loaded
> it gives me following error:
> The FeatureType 'AWS1_PRECIPITATION' has a NULL extent.
> HINT: the dataset is empty or has no default geometry attribute.
> I can see the geometry attribute of the data using ARCSDE,
the data is not
> empty.
> Why is it?
I couldn't find "desc table"
Albrecht.Weiser wrote:
regards
Albrecht
that I just
> loaded
the data is not
> empty.
> Why is it?
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
View this message in context: http://www.nabble.com/*creating-FeatureType-using-Oracle-tp18505047p18580266.html
