On Mon, Jul 6, 2015 at 2:13 PM, Nachtigall, Jens (init) <
Jens.Nachtigall@anonymised.com> wrote:
Sometimes the attribute MY_ATTRIBUTE is null in the database. How can I
match null with GeoServer css selectors?
I have not checked, but give [MY_ATTRIBUTE is NULL] a try
Or – in case this is not possible – can I have a default (fallback) class
for the case when the other three selectors do not match?
No, there is no such a thing in CSS
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
