[Geoserver-users] CSS module questions
Hi Andrea,
First, the CSS extension is awesome; thank you for your hard work on it. I have a few quick questions...
1. I am trying to style GDELT data by EventCode. The first two characters of the EventCode string would be sufficient to name the file I want. I was able to make a separate rule for each code, but it'd be more convenient to do something like
    mark: url([strConcat(strSubstring(EventCode, 0, 2), '.svg')]);
If I'm reading this https://github.com/geotools/geotools/blob/master/modules/unsupported/css/src/main/java/org/geotools/styling/css/CssParser.java#L321 right, it looks like Functions may not work. The docs hint that Expressions might be ok: http://docs.geoserver.org/stable/en/user/extensions/css/properties.html.
Did I goof the syntax? If not, I'd be happy to help cook up a quick PR if expresssions/functions in url should be allowed.
2. How does the CSS extension interact with GeoServer's SLD extensions?
3. In the CSS Styles GeoServer UI, I think it'd be awesome to keep the same map extent as one switches between the tabs. If you like the idea, I might be able to play with it over the next few weeks.
Jim
On Thu, Apr 23, 2015 at 10:29 PM, Jim Hughes <jnh5y@anonymised.com> wrote:
Hi Andrea,
If I'm reading this
You should check the generated SLD, that's the important one.
Also, which version of GeoServer you're using? 2.7 onwards is very much
recommended for CSS, I cannot help with 2.6 and older.
It's a translator to SLD, GeoServer and the rendering subsytem really only
handle the latter.
If you are about to ask about working off the CSS directly, It's been
discussed already, having the renderer work directly off the CSS would
require major API changes, and a heavy refactor
or the renderer itself (we'd end up with two renderers to maintain).
Sure
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
The generated SLD doesn’t update. There is an error reported in the UI: " I’m trying this out on GeoServer 2.8-SNAPSHOT. I suppose I’m asking how new GeoServer SLD extensions will be added to the CSS extension. It makes sense that the CSS module may lag behind. Thanks, Jim
Hi Andrea,
First, the CSS extension is awesome; thank you for your hard work on it. I have a few quick questions…
  1. I am trying to style GDELT data by EventCode. The first two characters of the EventCode string would be sufficient to name the file I want. I was able to make a separate rule for each code, but it’d be more convenient to do something like
mark: url([strConcat(strSubstring(EventCode, 0, 2), ‘.svg’)]);
If I’m reading this https://github.com/geotools/geotools/blob/master/modules/unsupported/css/src/main/java/org/geotools/styling/css/CssParser.java#L321 right, it looks like Functions may not work. The docs hint that Expressions might be ok: http://docs.geoserver.org/stable/en/user/extensions/css/properties.html.
Did I goof the syntax? If not, I’d be happy to help cook up a quick PR if expresssions/functions in url should be allowed.
You should check the generated SLD, that’s the important one.
Also, which version of GeoServer you’re using? 2.7 onwards is very much recommended for CSS, I cannot help with 2.6 and older.
Cannot turn this value into a literal: Expression [expression=strConcat([strSubstring([EventCode], [0], [2])], [.svg])]"
  1. How does the CSS extension interact with GeoServer’s SLD extensions?
It’s a translator to SLD, GeoServer and the rendering subsytem really only handle the latter.
If you are about to ask about working off the CSS directly, It’s been discussed already, having the renderer work directly off the CSS would require major API changes, and a heavy refactor
or the renderer itself (we’d end up with two renderers to maintain).
  1. In the CSS Styles GeoServer UI, I think it’d be awesome to keep the same map extent as one switches between the tabs. If you like the idea, I might be able to play with it over the next few weeks.
Sure
Ing. Andrea Aime
@geowolf
Technical Lead
I suppose I'm asking how new GeoServer SLD extensions will be added to the
Yes, one has to update the CSSParser and CSSTranslator classes in the
GeoTools gt-css module:
https://github.com/geotools/geotools/tree/master/modules/unsupported/css/src/main/java/org/geotools/styling/css
That said, I believe you're using the wrong syntax, external graphics
locations can only be strings, and the expressions
inside them are parsed at runtime. E.g.:
<ExternalGraphic>
                <OnlineResource xlink:type="simple"
xlink:href="http://www.usautoparts.net/bmw/images/states/tn_$\{strToLowerCase\(STATE\_ABBR\)\}\.jpg&quot;
                <Format>image/gif</Format>
              </ExternalGraphic>
This is because we cannot put a Expression in there (would require an API
change in GeoTools).
So, in CSS the above would look like:
mark: url(
and your example would become:
mark: url(${strConcat(strSubstring(EventCode, 0, 2), '.svg')});
Haven't tried it out, but hopefully it will work.... not completely sure
though, I remember at some point we had issues with urls
that were pure expressions (e.g., not starting with a static string portion
like my former example).
Ing. Andrea Aime
@geowolf
Technical Lead
