Hello,
Is it possible to define translations of titles for legends with a CSS based style? Or is it something reserved to SLD?
Regards
Alexandre Gacon
Hello,
Regards
Alexandre Gacon
Hi Alexandre,
it’s currently not possible, but could be implemented. It’s necessary to find a syntax (discussion welcomed),
then update the parser in gt-css, and then update the style builder found in the gt-brewer
module (it’s used by the CSS parser to build the in memory SLD representation of the style)
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Hello team,
We are preparing geoserver container for HA scenario.
I have noticed geoserver-2.21-SNAPSHOT-vectortiles-plugin and geoserver-2.21-SNAPSHOT-importer-plugin are gone in 2.23.0.
https://build.geoserver.org/geoserver/2.23.x/community-latest/
Functionality is incorporated in geoserver core or something else?
Thanks for your time!
With all the best!
Branislav Gaćeša
DevOps Engineer
Engenering&Delivery | HTEC Group Inc
+387 66 808 348
Mladena Stojanovića 30, Banja Luka, BiH
Sent: Wednesday, May 24, 2023 1:08 PM
To: Alexandre Gacon <alexandre.gacon@…84…>
Cc: geoserver-users geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] CSS style - i18n titles
Hi Alexandre,
On Wed, May 24, 2023 at 11:58 AM Alexandre Gacon <alexandre.gacon@…84…> wrote:
Hello,
Regards
Alexandre Gacon
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Look at here https://build.geoserver.org/geoserver/2.23.x/ext-latest/
-Jukka Rahkonen-
Lähettäjä: Branislav Gacesa via Geoserver-users geoserver-users@lists.sourceforge.net
Lähetetty: keskiviikko 24. toukokuuta 2023 16.15
Vastaanottaja: geoserver-users geoserver-users@lists.sourceforge.net
Kopio: Kosta Cavic <kosta.cavic@…11662…>
Aihe: Re: [Geoserver-users] CSS style - i18n titles
Hello team,
With all the best!
Branislav Gaćeša
DevOps Engineer
+387 66 808 348
Cc: geoserver-users <geoserver-users@lists.sourceforge.net>
Hi Alexandre,
Hello,
Regards
Alexandre Gacon
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
I see them both in the 2.23.1 release https://sourceforge.net/projects/geoserver/files/GeoServer/2.23.1/extensions/
Note these graduated to be supported extensions included as part of each release.
Jody Garnett
Note if you are serious about high availability then you should be using the stable releases
The snapshot releases are intended to provide feedback to the development team; this is especially true for “community” modules which are looking for feedback and resources (development or funding) to verify the functionality is useful, tested and documented for wider use.
If their are any community modules your team is considering for use please reaching the developer(s) involved and asking how you can help.
Jody Garnett
Thank you Andrea for the precision. When I have more time I will dig in the css code to see how it could be implemented but for my immediate need, I will stick to the SLD.
Alexandre
Alexandre Gacon
