[Geoserver-users] css styling contour lines
Hi everyone,
I’m trying to find an easy and good looking way on how to show contour lines on a map.
I want the lines 50, 100, 150 … always to look different then the rest of the lines with a different colour and width
but then at the same time I don"t want to always see all the lines, I have contour lines every 10 m which does look too crowded.
So fare my code is
/* Definition for the Label*/
[@scale <50000]{
label:[ALTITUDE];
label-offset:1;
font-family:“SansSerif”;
font-size: 12;
font-fill:#A66829;
halo-radius:1;
halo-color:#E7E7E8;
-gt-label-repeat:150;
-gt-label-follow-line:true;
-gt-label-force-ltr:false;
[@scale <12000]{
-gt-label-repeat:250;
/Definition as default style for every line/
stroke:#A67C29;
stroke-width:0.2;
/* special rules for some lines */
/* could be rewritten as OR, but was slow to process */
[ALTITUDE=‘50’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘100’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘150’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘200’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘300’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘400’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘500’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘600’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘700’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘800’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘900’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘1000’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘1100’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘1200’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘1300’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘1400’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘1500’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘1600’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘1700’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘1800’] { stroke-width:0.3; stroke:#A65329; }
[ALTITUDE=‘1900’] { stroke-width:0.3; stroke:#A65329; }
How can I now create different “styles” for when I have different scales? without the special lines always look the same?
You can combine a scale constraint and a data constraint in the same rule.
[ALTITUDE = ‘1200’] [@scale < 12000] { stroke-width: 0.5; stroke: #A65329; }
This is considered more specific than rules that only constrain one or the other, so it will override.
On Mon, Jun 24, 2013 at 1:21 AM, Lottie Atzenbeck <lotta.atzenbeck@anonymised.com.> wrote:
Hi everyone,
So fare my code is
[@scale <50000]{
label:[ALTITUDE];
label-offset:1;
font-size: 12;
font-fill:#A66829;
halo-radius:1;
halo-color:#E7E7E8;
[@scale <12000]{
stroke:#A67C29;
stroke-width:0.2;
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-users mailing list
