[Geoserver-users] CSS Styling question
Dear List,
I'd like to create a css styled line layer, based on attributes, with
stroke symbols.
But, I can't create two (or more) different types of lines in one
style sheet. Somehow nth-stroke inherits its options.
Sorry I am newbie in css, please help how can I create great styled
lines in Geoservers!
Here is my part of css code:
/* @title Stream axis line*/
[Typ = 151][@scale < 50000]
   stroke: #646464, symbol("shape://oarrow");
   stroke-width: 2m
:nth-stroke(2) {
   stroke: #646464;
   stroke-dasharray: 16 70;
   stroke-width: 2m;
/* @title Channel axis line */
[Typ = 153][@scale < 50000]
   stroke: #646464, symbol("shape://vertline");
   stroke-width: 3m
:nth-stroke(4) {
   stroke: #646464;
   stroke-dashoffset: 70;
   stroke-width: 2m;
There are two different line-types, but the appearance of stroke-hatch
dash-array is is the same.
How does :nth-stroke(n) works? What is 'n' ?
Thanks for advance:
Zsolt
On Wed, Apr 15, 2015 at 9:25 AM, Zsolt Magyar <zmagyar77@anonymised.com> wrote:
Dear List,
stroke symbols.
I think there might be a misunderstanding of what the :stroke :nth-stroke
are
meant to be used... in your styles there are only two levels of strokes,
not 4, if you want to use 4 as the index, you should have a line like:
stroke: #646464, symbol("shape://oarrow"), #646464,
If you want to specify how the oarrow and vertiline are styled, you should
apply the same selectors as the main strokes instead, something like:
[Typ = 151][@scale < 50000] :nth-stroke(2) {
   stroke: #646464;
   stroke-width: 2m;
[Typ = 153][@scale < 50000] :nth-stroke(4) {
   stroke: #646464;
   stroke-width: 2m;
The order of the rules is irrelevant in this case, it not like you
putting nth-stroke rules right after the one you would like
to act on, automatically creates an association, you have to
use the same selectors as the main rule to generate it.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Wed, Apr 15, 2015 at 9:47 AM, Andrea Aime <andrea.aime@anonymised.com>
Damn copy paste.. I really meant this:
[Typ = 153][@scale < 50000] :nth-stroke(2) {
Ing. Andrea Aime
@geowolf
Technical Lead
Thank You Andrea!
Yes ok. I understand the (2) indexes. Now it's works fine. The
specific selector setting was my problem!
Thanks again!
Zsolt
2015-04-15 10:02 GMT+02:00 Andrea Aime <andrea.aime@anonymised.com>:
Ing. Andrea Aime
@geowolf
Technical Lead
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
On Wed, Apr 15, 2015 at 10:09 AM, Zsolt Magyar <zmagyar77@anonymised.com> wrote:
Thank You Andrea!
Glad to hear the problem has been solved :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
Is it possible to add CSS stlye stroke-dasharray: 20 50; in meters?
Like: stroke-dasharray: 20m 50m;
I think it is impossible.
Only in SLD with: uom="http://www.opengeospatial.org/se/units/metre&quot;
Am I right?
2015-04-15 10:14 GMT+02:00 Andrea Aime <andrea.aime@anonymised.com>:
Thank You Andrea!
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Apr 20, 2015 at 3:58 PM, Zsolt Magyar <zmagyar77@anonymised.com> wrote:
Correct, it cannot work because the dash array is represented in memory
as a array of float numbers:
   float getDashArray();
We need that API to change before we can have CSS do what you're asking.
There was a patch back then, but if I remember correctly
the person proposing it never went through the formal process required to
break an esisting API
(official change proposal, copyright assignment):
http://jira.codehaus.org/browse/GEOT-3776
Had a look at the patch, the way it has been implemented is not likely to
be merged anyways...
Ing. Andrea Aime
@geowolf
Technical Lead
Hi List!
I’d like to create a styled line with dashed spikes like in picture below in SLD:
Szövegközi kép 1
The gray sticks are from ArcGIS stlye. The blueish stick comes from GeoServer 2.6.1.
(These are two lines with opposite direction, and symbolize an embankment. One long spike, one half spike.)
I want to see them the same.
At first, I tried with wkt://multilinestring. But where the line curves, the pattern run out from line.
At second, I tried with doubled line LineSymbolizer:
sld:Rule
sld:TitleEmbankment edge</sld:Title>
ogc:Filter
ogc:PropertyIsEqualTo
ogc:PropertyNameVONTIP_KOD</ogc:PropertyName>
ogc:Literal184</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
sld:MaxScaleDenominator50000.0</sld:MaxScaleDenominator>
<sld:LineSymbolizer uom=“http://www.opengeospatial.org/se/units/metre”>
sld:Stroke
<sld:CssParameter name=“stroke”>#646464</sld:CssParameter>
<sld:CssParameter name=“stroke-linejoin”>round</sld:CssParameter>
<sld:CssParameter name=“stroke-width”>2m</sld:CssParameter>
</sld:Stroke>
</sld:LineSymbolizer>
sld:Stroke
wkt://LINESTRING(0 0, 0 -0.5)
#00ffff
#00ffff
<sld:CssParameter name=“stroke-dasharray”>20 50</sld:CssParameter>
<sld:CssParameter name=“stroke-linecap”>round</sld:CssParameter>
<sld:CssParameter name=“stroke-width”>1</sld:CssParameter>
10
</sld:Stroke>
sld:Stroke
wkt://LINESTRING(1 0, 1 -0.25)
#00ffff
#00ffff
10
</sld:Stroke>
</sld:Rule>
How can I create this spiked lines in SLD? I have tried many variations but there was not the same I want.
If I try the “stroke-dashoffset” parameter, it does not works somehow.
Please help me a bit!
Thanks For Advance:
Zsolt
2015-04-27 9:59 GMT+02:00 Andrea Aime <andrea.aime@anonymised.com…1107…>:
Only in SLD with: uom=“http://www.opengeospatial.org/se/units/metre
We need that API to change before we can have CSS do what you’re asking.
the person proposing it never went through the formal process required to break an esisting API
Had a look at the patch, the way it has been implemented is not likely to be merged anyways…
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, May 29, 2015 at 11:27 AM, Zsolt Magyar <zmagyar77@anonymised.com> wrote:
If I try the "stroke-dashoffset" parameter, it does not works somehow.
stroke-dashoffset is the correct answer... wondering if it's related to the
usage of UOM, like, does it work
as expected if you don't use uom in the styhle... looking at the code it
seems correct, but I cannot think
of anything else that might cause this issue
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks Andrea!
With or without “uom” the stroke-dashoffset does not work in my case. Uom can not take any effect (it seems) to dashoffset parameter. But I’d like to styled in true meters.
Maybe if someone make new sld style for spiked line from the beginning, with alternating in spike length. (Short, long, short), so he can take a new look to this problem. I think I have tried all variations on it.
Thanks again for your time!
Bests:
Zsolt
2015-06-01 15:35 GMT+02:00 Andrea Aime <andrea.aime@anonymised.com>:
stroke-dashoffset is the correct answer… wondering if it’s related to the usage of UOM, like, does it work
as expected if you don’t use uom in the styhle… looking at the code it seems correct, but I cannot think
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Zsolt,
I did check myself, and indeed I cannot make it work, believe there is a bug in the handling of dashoffset (although it’s working
in most simple doc examples).
Could you open a bug report?
On Mon, Jun 1, 2015 at 4:07 PM, Zsolt Magyar <zmagyar77@…84…> wrote:
Thanks Andrea!
Bests:
Zsolt
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks for the deeper testing!
I will try to write a bug report about it.
Zsolt
2015.06.01. 20:05 ezt írta (“Andrea Aime” <andrea.aime@anonymised.com…>):
On Mon, Jun 1, 2015 at 4:07 PM, Zsolt Magyar <zmagyar77@anonymised.com.> wrote:
Thanks Andrea!
Bests:
Zsolt
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
