[Geoserver-users] CSS Styling with ogc:Function
I have been trying out the CSS Styling module for GeoServer. Great utility.
but I am struggling with labling a polygon only once at it's centroid when
it overlaps multiple tiles. Below is the SLD to achieve this. How do I call
the centroid() function with CSS?
<Rule>
    <TextSymbolizer>
        <Geometry>
            <ogc:Function name="centroid">
                <ogc:PropertyName>geom</ogc:PropertyName>
            </ogc:Function>
        </Geometry>
        <Label>
              <ogc:PropertyName>label</ogc:PropertyName>
        </Label>
        <LabelPlacement>
              <PointPlacement>
                  <AnchorPoint>
                      <AnchorPointX>0.5</AnchorPointX>
                      <AnchorPointY>0.5</AnchorPointY>
                  </AnchorPoint>
              </PointPlacement>
        </LabelPlacement>
    </TextSymbolizer>
</Rule>
View this message in context: http://osgeo-org.1560.x6.nabble.com/CSS-Styling-with-ogc-Function-tp5224636.html
<Rule>
    <TextSymbolizer>
        <Geometry>
            </ogc:Function>
        </Geometry>
        <Label>
        </Label>
        <LabelPlacement>
              <PointPlacement>
                  <AnchorPoint>
                  </AnchorPoint>
              </PointPlacement>
        </LabelPlacement>
    </TextSymbolizer>
</Rule>
I have not tried it, but according to the property listing
http://docs.geoserver.org/latest/en/user/extensions/css/properties.html
it should be:
label: [label];
label-geometry: [centroid(geom)];
label-anchor: 0.5 0.5
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thank you. That works.
View this message in context: http://osgeo-org.1560.x6.nabble.com/CSS-Styling-with-ogc-Function-tp5224636p5224652.html
