[Geoserver-users] CSV Output Format from WPS
I have been doing some research into a WPS that can return a SimpleFeatureCollection as text/csv. I found several email chains from previous discussions that reference CSV, but nothing definitive about whether setting the outputformat mimetype to text/csv should work. I tried with a simple test and it failed, so I assume it does not, but wanted confirmation this is the case to ensure I wasn’t doing something incorrect.
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, A Polaris Alpha Company
Description: Description: Description: cid:image001.png@anonymised.com
I was thinking about this the other day and I think there is a need for a CSVPiPO class somewhere in GeoServer (or may be GeoTools). I keep meaning to dig further but other things come up.
Ian
On 17 March 2017 at 14:19, Chris Snider <chris.snider@anonymised.com> wrote:
Chris Snider
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ian Turton
Right, I also checked and I don't see one. Just check the inheritance
hierachy of ComplexPPIO.
Building one off the WFS output format should be easy though.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
There is a basic implementation (with no tests) at https://github.com/ianturton/geoserver/tree/cvspipo - I’ll try to finish it when I’m stuck on the train later this week
Ian
Right, I also checked and I don’t see one. Just check the inheritance hierachy of ComplexPPIO.
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
Most excellent! I look forward to what you come up with.
Chris Snider
Description: Description: Description: cid:image001.png@...5633...
Ian
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
