On Sun, Apr 19, 2015 at 8:30 AM, David Percy <percyd@anonymised.com> wrote:
Hi guys, love geoserver!
Trying to get a small SDI going for some of the colleges here in Portland.
Using Geoserver and CKAN.
I looked through all of the listserv archives, and other web resources and
couldn't find anything.
Currently running geoserver 2.7, on java 1.7.0_76, on win2012R2 in a
amazon EC2 instance
When using either QGIS or CKAN (what I really want to use) as a client I
get this error:
Error connecting to service: 'Single value expected for request parameter
service but instead found: [csw, CSW]'
This happens because the client is sending an invalid request with
"&service=csw&service=CSW" in the url.
I guess the client is trying to add its own service and request parameters,
if that's the case instead of giving the
capabilities url as:
http://host:port
/geoserver/ows?service=csw&request=GetCapabilities&version=2.0.1
try just the base url:
http://host:port/geoserver/ows?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
