Hi Henning,
no, this is new to me, we actually have one demo server using a 2.9.x series deploying
CSW and starting without problems here:
http://demo.geo-solutions.it/geoserver/web/
The server deploys once a day the current nightly build, and did not exhibit any startup problem around the
time 2.9.1 was released (a release is pretty much the same as a nightly, minus the installers
that make it easier to setup).
Can you check the GeoServer logs and see if you can find significant (or any) stack traces?
On Fri, Aug 19, 2016 at 3:21 PM, Henning Lorenz <henning.lorenz@anonymised.com> wrote:
Geoserver 2.9.1 web archive, tomcat 8.0.35, java 1.8.0_91, Ubuntu 16.04
Hello,
- Geoserver 2.9.1 works fine without plugin
- Geoserver 2.9.1 does not start with the csw 2.9.1 plugin installed
- the problematic jars are gs-csw-core-2.9.1.jar and gs-web-csw-2.9.1.jar: Geoserver does not start if any of the two jars is in WEB-INF/lib, the other jars of the CSW plugin do not cause any trouble.
Has anybody else observed this problem and are there any solutions?
Thanks for helping,
Henning
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
