Hello list.
Something strange is happening when I load a file to geoserver by curl. I observed in the tomcat manager that the process never leaves the state (s) of service:
Sent Time Stage B B Recv Client (Forwarded) Client (Current) VHost Request
S 1968673 ms 0 KB 59442 KB 172.xx.xx.xx 172.xx.xx.xx 172.xx.xx.xx /geoserver/rest/workspaces/xxxx/coveragestores/yyyy/file.geotiff PUT HTTP / 1.1
The curl command is nailed to the command line:
$> Curl -v -u user: pass -XPUT -H ‘Content-type: image / tiff’ --data-binary @ / mytif.tif http: // myip: myport / geoserver / rest / workspaces / xxxx / coveragestores /yyyy/file.geotiff
- About to connect () to 172.19.12.24 port 8080 (# 0)
- Trying 172.19.12.24 … Connected
- Server using basic with auth user ‘admin’
Authorization: Basic YWRtaW46cHJveWVjdG9VREVHRTIwMTU =
User-Agent: curl / 7.22.0 (x86_64-pc-linux-gnu) libcurl / 7.22.0 OpenSSL / zlib 1.0.1 / 1.2.3.4 libidn / librtmp 1.23 / 2.3
Host: myip: myport
Accept: * / *
Content-Length: 125009107
Expect: 100-continue
<HTTP / 1.1 100 Continue
Versions software I’m using:
Apache Tomcat / 7.0.52 (Ubuntu)
2.7.2 Geoserver
Files up to 60MB me correctly, but when I get over that limit occurs as described above.
I tried changing the boundaries of Tomcat as shown below but the problem remains:
And in the file /usr/share/tomcat7-admin/manager/WEB-INF/web.xml
400428800
400428800
0
I think this must be a problem of Tomcat, but maybe the problem is Geoserver.
Thanks in advanced
Pablo
On Fri, 27 Nov 2015 09:50:05 PM pablo zader wrote:
$> Curl -v -u user: pass -XPUT -H 'Content-type: image / tiff'
Have you tried using POST instead?
Hi list and Bradh
I followed the suggestion of Brad using POST instead of PUT but still does not work (see picture)
Responde from Bradd
Have you tried using POST instead?"
I write again the problem: above 60 MB file the request sent is captured by tomcat and never leaves the state service (s) to move to the state Ready (R).
Thanks in advanced
Pablo
2015-11-27 21:50 GMT-03:00 pablo zader <pzader@anonymised.com>:
Hello list.
Host: myip: myport
Accept: * / *
2.7.2 Geoserver
400428800
400428800
0
Thanks in advanced
Pablo
Pablo J. Zader
Lic. en Cs. de la Computación
pablo.zader@anonymised.com
"Los Grandes Hombres hablan sobre ideas…
Los Hombres Promedio hablan sobre cosas…
Los Hombres Pequeños hablan… de otros Hombres.
del libro Matemática estas ahi? A. Paenza "
