[Geoserver-users] current tip compile error
Could someone help with this compilation error? this is on Windows XP platform with JDK1.5, persistent compile error and it seems to be mismatch of geotool version (??). Thanks.
C:\workspace\geoserver>mvn compile
[INFO] Scanning for projects…
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] GeoServer Maven Plugins
[INFO] Plugins configuration files
[INFO] Configuration Deployment PlugIn
[INFO] Core Platform Module
[INFO] Data Module
[INFO] Open Web Service Model
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Coverage Service Module
[INFO] Validation Module
[INFO] Web Feature Service Model
[INFO] Web Feature Service Module
[INFO] Versioning Web Feature Service Model
[INFO] Versioned Web Feature Service Module
[INFO] Web Map Service Module
[INFO] Web Application Module
[INFO] Test Module
[INFO] ----------------------------------------------------------------------------
[INFO] Building GeoServer
[INFO] task-segment: [compile]
[INFO] Building GeoServer Maven Plugins
[INFO] Building Plugins configuration files
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date
[INFO] Building Configuration Deployment PlugIn
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[INFO] No sources to compile
[INFO] Building Core Platform Module
[INFO] Compiling 8 source files to C:\workspace\geoserver\platform\target\classes
[INFO] Building Data Module
[INFO] Compiling 13 source files to C:\workspace\geoserver\data\target\classes
[INFO] Building Open Web Service Model
[INFO] Compiling 62 source files to C:\workspace\geoserver\net.opengis.ows\target\classes
[INFO] Building Open Web Service Module
[INFO] Compiling 63 source files to C:\workspace\geoserver\ows\target\classes
[INFO] Building Main Module
[INFO] Compiling 118 source files to C:\workspace\geoserver\main\target\classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
C:\workspace\geoserver\main\src\main\java\org\vfny\geoserver\global\FeatureTypeInfo.java:[13,28] can
not find symbol
symbol : class FactoryConfigurationError
C:\workspace\geoserver\main\src\main\java\org\vfny\geoserver\global\FeatureTypeInfo.java:[1131,25] c
annot find symbol
location: class org.vfny.geoserver.global.FeatureTypeInfo
[INFO] Total time: 19 seconds
[INFO] Finished at: Tue Nov 20 12:29:18 EST 2007
[INFO] Final Memory: 16M/56M
Hi Jerry,
There has been lots of changes in both geotools and geoserver this last
week. I fixed this compile error yesterday in GeoServer. Are you sure
you have an up to date checkout?
Regardless, GeoServer trunk is not dependent on Geotools trunk which we
have been deploying nightly.
-Justin
[INFO] Scanning for projects...
[INFO] GeoServer
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
can
not find symbol
c
annot find symbol
[INFO]
[INFO]
[INFO]
!DSPAM:4007,47431a7e189535332866982!
Defy all challenges. Microsoft(R) Visual Studio 2005.
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
