[Geoserver-users] Custom DataStores
Hello,
I guess my main problem is that I don’t understand the lingo that’s being used here.
  1. What is a “feature” in the DataStore sense? Is this the same thing as what WFS considers to be a “feature”?
  2. How do I return coverages through this DataStore interface? What format are the coverages supposed to be in?
  3. Are there any typeNames that I must return? Or can typenames be any random string I want? What is a TypeName used for? Does this get shown to the enduser of Geoserver?
  4. How do I return images through this interface? Is there any specific format those images have to be in? PlanarImage? RenderableImage? Or a simple byte?
Thanks for your continued support!
Ronak
Hi Ronak,
Patel, Ronak Avinash (US SSA) wrote:
Hello,
More or less. The term "feature" definitely comes form WFS. When in teh context of data store a feature means an entry in a dataset which has some attributes.
Coverages are not managed via the DataStore interface. Look at the AbstractGridFormat and AbstractGridCoverage2DReader classes in the org.geotools.coverage.grid.io package for the data access classes relevant to coverages.
Yes type names is the list of "types" you want to publish through the datastore, and should not be random. Type name is used by the outside world to identify "datasets" served by the datastore. For instance when the datastore is db based, type names correspond to table names.
The StreamingRenderer class (org.geotools.renderer.lite) can render data from a DataStore into a Graphics2D context... which can originate from a RenderedImage.
Hope that helps :slight_smile:
Ronak
Create and Deploy Rich Internet Apps outside the browser with Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills and code to
build responsive, highly engaging applications that combine the power of local
resources and data with the reach of the web. Download the Adobe AIR SDK and
Ajax docs to start building applications today-http://p.sf.net/sfu/adobe-com
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
