[Geoserver-users] Custom FeatureType
Hello!
  I created a new FeatureType with Config/Data/FeatureType/New. The
FeatureType is a view in database postgres. And in my jsp I create a layer
with this featuretype
These are the sentences:
olayer = new OpenLayers.Layer.WMS( 'AR_3_13200',
'http://localhost:8080/geoserver/wms’, {layers: 'topp:Nodos_Sistema',
transparent:'true', styles: '', srs: 'EPSG:4326', tiled: 'true',}, {
'reprojected':true, 'isBaseLayer': false, 'opacity': 0.5 },{buffer: 0});
map.addLayer(olayer);
It' is ok!
Now, I want create a custom featuretype filtering 'topp:Nodos_Sistema' from
code.
For example:
'topp:Nodos_Sistema' is this view
CREATE OR REPLACE VIEW "Nodos_Sistema" AS
SELECT "EL_Nodos".sis_pais AS sis_tipo, "EL_Nodos".sis_codigo,
"EL_Nodos".cap_codigo, "EL_Nodos".nod_id, "EL_Nodos".nod_objeto,
"EL_Nodos".nod_descripcion, "EL_Nodos".oid
   FROM el_nodos "EL_Nodos"
  WHERE "EL_Nodos".sis_pais = 'SI';
I want create a freaturetype with
SELECT sis_tipo, sis_codigo, cap_codigo, nod_id, nod_objeto,
nod_descripcion,
       oid
  FROM "Nodos_Sistema"
Where sis_codigo = 1;
And other with
nod_descripcion,
       oid
Where sis_codigo = 3;
But this from my code, no by web Config/Data/FeatureType/New.
In the geoserver docs I find this, but I don`t like this way
      Alternatively, the FeatureType can be defined by manually creating a
directory ("localPostgis_test" in this example), with an info.xml file in
the featureTypes folder, which is itself located in Geoserver's data
directory. The catalog still needs to be reloaded, so the new FeatureType
is available.
Thank you
Regards
Abel
View this message in context: http://www.nabble.com/Custom-FeatureType-tp22789714p22789714.html
The recommended way to do add feature types programatically is via the REST configuration interfaces:
http://gridlock.openplans.org/geoserver/1.7.x/doc/user/extensions/rest/
However you will have to create all the views manually and manually create a geometry_columns entry for each view you want to publish as a feature type. Once you do that you should be able to just make a single rest call (see the examples from the above link) to register the feature type.
-Justin
abelq wrote:
Hello!
It' is ok!
code.
For example:
CREATE OR REPLACE VIEW "Nodos_Sistema" AS SELECT "EL_Nodos".sis_pais AS sis_tipo, "EL_Nodos".sis_codigo,
nod_descripcion, oid
  FROM "Nodos_Sistema" Where sis_codigo = 1;
And other with
  FROM "Nodos_Sistema" Where sis_codigo = 3;
is available.
Thank you
Regards
Abel
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin
I used CQL_Filter
'http://localhost:8080/geoserver/wms’, {CQL_Filter:'campo1=1&&campo2=1'.
'layers: 'topp:Nodos_Sistema', transparent:'true', styles: '', srs:
'EPSG:4326', tiled: 'true',}, { 'reprojected':true, 'isBaseLayer': false,
And It work.
I'll see your way.
Thank you
type.
-Justin
abelq wrote:
Hello!
layer
It' is ok!
from
code.
For example:
nod_descripcion,
       oid
And other with
nod_descripcion,
       oid
a
in
FeatureType
is available.
Thank you
Regards
Abel
Justin Deoliveira
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Custom-FeatureType-tp22789714p22916870.html
