With a simple javascript function (myFn.js) like this:
function run(value, args){
return 20;
Used in an SLD like this:
<sld:UserStyle xmlns=“http://www.opengis.net/sld”
xmlns:sld=“http://www.opengis.net/sld”
xmlns:ogc=“http://www.opengis.net/ogc”
xmlns:gml=“http://www.opengis.net/gml”>
sld:NameDefault Styler</sld:Name>
sld:FeatureTypeStyle
sld:Namename</sld:Name>
sld:Rule
sld:PointSymbolizer
sld:Graphic
sld:ExternalGraphic
<sld:OnlineResource xmlns:xlink=“http://www.w3.org/1999/xlink” xlink:type=“simple”
xlink:href=“http://localhost:82/geoserver/styles/mapIcons/Recovery.svg”/>
sld:Formatimage/svg+xml</sld:Format>
</sld:ExternalGraphic>
sld:Size
<ogc:Function name=“myFn”></ogc:Function>
</sld:Size>
</sld:Graphic>
</sld:PointSymbolizer>
</sld:Rule>
</sld:FeatureTypeStyle>
</sld:UserStyle>
Geoserver always throws an exception when invoking the function from the SLD:
Caused by: java.lang.NoSuchMethodException: No such method: run
Hey Tim,
I have actually hit this as well. Unfortunately there seems to be a bug in the javascript module at this point. I can confirm that the python module functions correctly though.
-Justin
return 20;
sld:Rule
sld:PointSymbolizer
sld:Graphic
sld:ExternalGraphic
sld:Size
</sld:Size>
</sld:Graphic>
</sld:Rule>
</sld:UserStyle>
Managing the Performance of Cloud-Based Applications
Take advantage of what the Cloud has to offer - Avoid Common Pitfalls.
Read the Whitepaper.
http://pubads.g.doubleclick.net/gampad/clk?id=121051231&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
