The fact is that I fought with custom projections last two days
(raster images in my case).
This is not an easy topic, an it covered with documentation poorly.
Looks like your case is WFS usage.
And your case is some base layer in WGS84 projection (EPSG:4326) with
using layer in custom projection over this base layer.
Here is an example, where base layer is in the mercator projection,
and the feature layer had to be reprojected into WGS84 projection, so
note the 'projection' property defined in layer options:
var roads = new OpenLayers.Layer.WFS(
"Controlled Areas",
"/geoserver/wfs",
typename: 'PostGIS_test1:RestrictedArea_test',
!!!>>> projection: "EPSG:4326",
typename: 'RestrictedArea_test',
featureNS: 'http://wg-aim.com',
extractAttributes: true,
styleMap: new
OpenLayers.StyleMap(getDefaultStyle(sld, "My Areas"))
map.addLayers([gsat, roads]);
dixi
2009/5/12 David Rush <david@anonymised.com>:
Raja:
The differences I see are between using the "Map Preview" from my Geoserver's admin pages, and just a very simple OpenLayers-enabled web page.
My data is in a custom Albers projection.
I added my WKT to my epsg.properties (prepending my WKT with "100004=") file and bounced Tomcat. Then I went to each layer (FeatureType) and specified it to use SRS: 100004.
Using "Map Preview" on any of my 3 layers looks fine - the projection looks exactly as it should (curved lines of latitude, and the shape I'm used to).
However, when I point a simple OpenLayers-enabled web page at any of my layers, it's coming out with straight lines of latitude and stretched in the east/west dimension - I presume it's reprojecting to geographic - EPSG:4326. How can get generic (not part of Geoserver) OpenLayers to use my native projection? (Or should I find an OpenLayers list to ask that?)
