This worked. Many thanks. I will try this solution to see if it is good enough.
For the record, my previous wget command was wrong. You actually have to specify the header accepting a compressed response:
Cheers.
Right, in web.xml we have:
<filter>
<filter-name>GZIP Compression Filter</filter-name>
<filter-class>org.geoserver.filters.GZIPFilter</filter-class>
<init-param>
<!-- The compressed-types parameter is a comma-separated list
of regular expressions.
If a mime type matches any of the regular expressions
then it will be compressed.
<param-name>compressed-types</param-name>
<param-value>text/.*,.*xml.*,application/json,application/x-javascript</param-value>
</init-param>
</filter>
I guess you can add .*gml.* to the list and restart GeoServer.
Could you open a ticket at jira.codehaus.org/browse/GEOS
<http://jira.codehaus.org/browse/GEOS> as a reminder to do the same
in GeoServer own code?
On Fri, Oct 24, 2014 at 11:09 AM, Fernando G. C.
<fernando.gonzalez@anonymised.com <mailto:fernando.gonzalez@anonymised.com>> wrote:
Thanks Jonathan, Andrea.
Analyzing the headers I see "Accept-Encoding: gzip, deflate" in the
request but the response gives "Transfer-Encoding: chunked" and no
"Content-Encoding" header. Looks like it is not compressing.
See here[1] for another example with wget.
Cheers.
[1]
wget -S
"http://192.168.0.18:8080/__geoserver/curso_ecuador/wms?__REQUEST=GetFeatureInfo&__EXCEPTIONS=application%2Fvnd.__ogc.se_xml&BBOX=-97.266226%2C-__7.139908%2C-69.760622%2C3.__576561&SERVICE=WMS&INFO___FORMAT=application%2Fvnd.ogc.__gml&QUERY_LAYERS=curso___ecuador%3Aecu_adm0&FEATURE___COUNT=50&Layers=curso_ecuador%\_\_3Aecu\_adm0&WIDTH=847&HEIGHT=\_\_330&format=image%2Fpng&styles=\_\_&srs=EPSG%3A4326&version=1\.1\.\_\_1&x=581&y=133
<http://192.168.0.18:8080/geoserver/curso_ecuador/wms?REQUEST=GetFeatureInfo&EXCEPTIONS=application%2Fvnd.ogc.se_xml&BBOX=-97.266226%2C-7.139908%2C-69.760622%2C3.576561&SERVICE=WMS&INFO_FORMAT=application%2Fvnd.ogc.gml&QUERY_LAYERS=curso_ecuador%3Aecu_adm0&FEATURE_COUNT=50&Layers=curso_ecuador%3Aecu_adm0&WIDTH=847&HEIGHT=330&format=image%2Fpng&styles=&srs=EPSG%3A4326&version=1.1.1&x=581&y=133>"
-O /tmp/output.xml
--2014-10-24 11:03:16--
Connecting to 192.168.0.18:8080... connected.
HTTP request sent, awaiting response...
HTTP/1.1 200 OK
Server: Apache-Coyote/1.1
Content-Disposition: inline;
filename=geoserver-__GetFeatureInfo.application
Content-Type: application/vnd.ogc.gml
Date: Fri, 24 Oct 2014 09:03:16 GMT
Length: unspecified [application/vnd.ogc.gml]
Saving to: `/tmp/output.xml'
On 10/23/2014 04:36 PM, Andrea Aime wrote:
On Thu, Oct 23, 2014 at 4:23 PM, Jonathan Moules
<J.Moules@anonymised.com <mailto:J.Moules@anonymised.com>
<mailto:J.Moules@anonymised.com>>> wrote:
Hi Fernando,
How about using compression? The serverlet container should
be able
to do on-the-fly compression of documents/data, including
GML. That
should significantly reduce the in-transit side.
Actually GeoServer should be doing this already, we have a servlet
filter that does it by default
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
phone: +39 0584 962313 <tel:%2B39%200584%20962313>
fax: +39 0584 1660272 <tel:%2B39%200584%201660272>
mob: +39 339 8844549 <tel:%2B39%20%20339%208844549>
http://twitter.com/__geosolutions_it
<http://twitter.com/geosolutions_it>
Le informazioni contenute in questo messaggio di posta
elettronica e/o
nel/i file/s allegato/i sono da considerarsi strettamente
riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del
messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate
questo
messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del
messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio
stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti,
copiarlo, od utilizzarlo per finalità diverse, costituisce
comportamento
contrario ai principi dettati dal D.Lgs. 196/2003.
The information in this message and/or attachments, is intended
solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the
provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's
New Data
Protection Code).Any use not in accord with its purpose, any
disclosure,
reproduction, copying, distribution, or either dissemination, either
whole or partial, is strictly forbidden except previous formal
approval
of the named addressee(s). If you are not the intended
recipient, please
contact immediately the sender by telephone, fax or e-mail and
delete
the information in this message that has been received in error. The
sender does not give any warranty or accept liability as the
content,
accuracy or completeness of sent messages and accepts no
responsibility
for changes made after they were sent or for other risks which
arise as
a result of e-mail transmission, viruses, etc.
------------------------------__-------------------------
Ing. Andrea Aime
@geowolf
Technical Lead
copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento
The information in this message and/or attachments, is intended solely
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
Protection Code).Any use not in accord with its purpose, any disclosure,
whole or partial, is strictly forbidden except previous formal approval
of the named addressee(s). If you are not the intended recipient, please
contact immediately the sender by telephone, fax or e-mail and delete
sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility
for changes made after they were sent or for other risks which arise as
