I’ve searched the documentation and couldn’t find a definite answer. I’d like to know if there is a way to customize WMS output to a PDF – for instance, if I’m showing a data layer from a WMS, is there anywhere within geoserver that I could add a standard map template to all PDFs generated by Geoserver?
Thanks for the help! We’re enjoying Geoserver and hope to have something to show soon!
Jonathan Harahush
GIS Analyst
Denver Regional Council of Governments
http://www.drcog.org
(303) 480-6746
Jonathan Harahush ha scritto:
Nope, GeoServer does not have a PDF templating system, but there
is MapFish that has a print functionality with one, and that
can integrate with GeoServer (thought there is a bug preventing
the accurate printing of layers with multiple feature type styles).
You can find the module here, http://trac.mapfish.org/trac/mapfish/wiki,
thought you'll have to build it on your own (they don't provide
a pre-build binary as far as I know).
Andrea Aime
OpenGeo - http://opengeo.org
I've searched the documentation and couldn't find a definite answer.
I'd like to know if there is a way to customize WMS output to a PDF –
for instance, if I'm showing a data layer from a WMS, is there anywhere
Hi
There's a war available here:
http://dev.mapfish.org/maven/repository/org/mapfish/print/print-servlet/1.1/print-servlet-1.1.war
And a jar for the print jar alone:
http://dev.mapfish.org/maven/repository/org/mapfish/print/print-lib/1.1/print-lib-1.1.jar
Eric
