[Geoserver-users] DATA_DIR migration from 2.3.1 to 2.7. EncryptingUrlParams error.
Hello,
I’m migrating Geoserver from 2.3.1 to 2.7.
I created a Tomcat instance with Geoserver 2.7 and I’m pointing the new Geoserver to a copy of the old DATA_DIR.
I’m using TOMCAT 7.0.5 and JDK 1.7. I’ve installed the compatible unlimited policy JAR files.
When I try GeoServer I got the folowing 500 error.
exception
org.springframework.web.util.NestedServletException: Request processing failed; nested exception is java.lang.IllegalArgumentException: setAttribute: Non-serializable attribute __ICRYPT
I discovered that if I disable on <DATA_DIR>/security/config.xml, the error stops.
Also, the stores aren’t recognized by GeoServer, but when I remove “crypt2:” of the password at datastore.xml, the stores appears.
I know the problem is related to encryption method, but I don’t know what to do.
JÔNATAS CASTRO
+55 (21) 99109-7575
Hi Jonatas
I think you switched from the limited to the unlimited policy files. As a consequence, Geoserver tries to use better algorithms but your key store still contains the limited keys.
Try the following
  1. stop GeoServer
  2. make a backup of GEOSERVER_DATA_DIR/security/geoserver.jceks
  3. remove GEOSERVER_DATA_DIR/security/geoserver.jceks
  4. restart GeoServer
The geoserver.jceks should be recreated.
Reenter the password(s) for your data store(s) and save them.
Hope this helps
Christian
On Tue, May 12, 2015 at 9:53 PM, Jônatas Castro <jonatascastro12@anonymised.com> wrote:
Hello,
exception
JÔNATAS CASTRO
+55 (21) 99109-7575
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
Geoserver-users mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
