[Geoserver-users] Data directory porting
how to port data directory from 2.3.5 and below to 2.4 and above?
Anas A
Jr.GIS Engineer, Trinity Mobility
facebook twitter linkedin googleplus
+917736368236
anas.24aj@anonymised.com84…
Tattamangalam,Palakkad,Kerala
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Hi Anas,
Standard upgrade process should be fine. This page doesn’t indicate anything special required between those version - http://docs.geoserver.org/stable/en/user/installation/upgrade.html
Although depending how far back you go, this list thread suggests some issues in some cases when upgrading from 2.1 - http://osgeo-org.1560.x6.nabble.com/upgrade-from-2-1-to-2-4-problems-td5080285.html
Jonathan
Anas A
+917736368236
Geoserver-users mailing list
