[Geoserver-users] data fetching from geoserver
I have two problems regarding Geoserver
1.I have loaded some .gtiff images in geoserver but when i tries to access
them using osgearth I get only the last image on the glob.
2.How can i access images under some namespace as a whole without giving
their individual attributes via osgearth.
View this message in context: http://www.nabble.com/data-fetching-from-geoserver-tp24035095p24035095.html
shashank520 ha scritto:
I never used osgearth but I guess you have two options:
- if the images are tiles of the same logical layer (tiles)
   try building a mosaic. Just put all the images in the same folder,
   create an image mosaic, pass the path to the folder containing the
   images as its setup parameter
- if the images are describing unrelated phenomena, you can still
   build a layer group, look into config/wms/contents
Andrea Aime
OpenGeo - http://opengeo.org
