[Geoserver-users] Data outside from GEOSERVER_DATA_DIR
Hello List,
I have a question: Is it possible to map a directory which contains hundreds of orthophoto raster to GeoServer, and it is outside of the GEOSERVER_DATA_DIR path variable?
I have set environmental variable geoserver_data_dir on server, but I need to read data from another file server which is not in the same server. How can I make readable folder outside of default geoserver_data_dir, without any data copying or migration?
Thanks for tips!
Zsolt, Magyar
Hi Zsolt,
Yes you can do that and IMHO that’s best practice - segregating the GeoServer configuration (which is what GEOSERVER_DATA_DIR actually holds), from the raw data means you can use different backup schedules/procedures for them and keeps them logically separated too.
I don’t have any actual data whatsoever in GEOSERVER_DATA_DIR.
When adding the dataset(s)/store(s) just use the file navigator to look for the directory you put stuff into. You folder should be readable depending on what permissions you’re using, but that’s a operating-system issue.
Jonathan
On 16 May 2013 08:36, Zsolt Magyar <zmagyar77@anonymised.com> wrote:
Hello List,
Thanks for tips!
Zsolt, Magyar
AlienVault Unified Security Management (USM) platform delivers complete
security visibility with the essential security capabilities. Easily and
efficiently configure, manage, and operate all of your security controls
from a single console and one unified framework. Download a free trial.
http://p.sf.net/sfu/alienvault_d2d
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Thank you Jonathan!
I didn’t think it was so simple! I can’t try this before.
Thanks again!
Zsolt
2013/5/16 Jonathan Moules <jonathanmoules@anonymised.com>
Hi Zsolt,
Jonathan
Hello List,
Thanks for tips!
Zsolt, Magyar
