[Geoserver-users] Data Security Configuration via REST
Is there any way to configure Data Security Rules via the REST interface? For example, if I create a new workspace using the REST interface, how do I also secure it via the REST interface?
Mike Grogan
On Mon, Apr 6, 2015 at 5:20 PM, Mike Grogan <d.michael.grogan@anonymised.com>
There was a proposal to add this functionality, but it seems to have
stalled:
https://github.com/geoserver/geoserver/wiki/GSIP-120
As an alternative, you can use GeoFence (
https://github.com/geoserver/geofence ), it has a REST API to configure the
security rules.
Of course, it's a bit harder to setup, you have to run an extra external
app (GeoFence itself) and add a plugin to GeoServer
to connect to it.
We are working on building a relationship like the GWC one, where GeoFence
will run as a library inside GeoServer, but it will take some
time, and at the beginning it might not have the REST api included (mostly
to reduce the initial effort of merging the two toghether).
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks for responding, Andrea. I have been considering the GeoFence way of doing this, but may go another way at this point.
  • Mike
On Mon, Apr 6, 2015 at 12:10 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Mon, Apr 6, 2015 at 5:20 PM, Mike Grogan <d.michael.grogan@anonymised.com> wrote:
There was a proposal to add this functionality, but it seems to have stalled:
As an alternative, you can use GeoFence ( https://github.com/geoserver/geofence ), it has a REST API to configure the security rules.
Of course, it’s a bit harder to setup, you have to run an extra external app (GeoFence itself) and add a plugin to GeoServer
to connect to it.
We are working on building a relationship like the GWC one, where GeoFence will run as a library inside GeoServer, but it will take some
time, and at the beginning it might not have the REST api included (mostly to reduce the initial effort of merging the two toghether).
Ing. Andrea Aime
@geowolf
Technical Lead
Hi all
GSIP 120 is still on my TODO list, I hope to create a pull request soon.
Christian
On Mon, Apr 6, 2015 at 7:09 PM, Mike Grogan <d.michael.grogan@anonymised.com> wrote:
  • Mike
BPM Camp - Free Virtual Workshop May 6th at 10am PDT/1PM EDT
Develop your own process in accordance with the BPMN 2 standard
Learn Process modeling best practices with Bonita BPM through live exercises
http://www.bonitasoft.com/be-part-of-it/events/bpm-camp-virtual- event?utm_
source=Sourceforge_BPM_Camp_5_6_15&utm_medium=email&utm_campaign=VA_SF
Geoserver-users mailing list
to connect to it.
Ing. Andrea Aime
@geowolf
Technical Lead
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
