I'm following the example here:
http://geoserver.org/display/GEOSDOC/SLD+Snippets#SLDSnippets-DatabasedrivenStyling
But my polygons are being drawn with no colors (think wire-frame).
Where should I look to start to debug my problem?
I turned up the logging but I didn't see anything there.
Thanks in advance,
Rob
Well, what is the actual content of your table? The property you use
for "fill" should be a string and look like '#FF0000' for red, and so
on. If you have anything that does not follow the '#RRGGBB' pattern
the conversion from string to color will fail and you'll get no fill.
Yes, that's what I have in the table. Does it matter that the type is
for that column? And are the hex chars case sensitive? Should I be
seeing something about a failure in the log?
Many thanks,
Rob
for that column?
Not really, should be a string.
Not as far as I know. Are you sure the attribute name matches? (that's
case sensitive)
Should I be seeing something about a failure in the log?
Nope, there is no logging for type conversion failures, if the conversion succeeds, we fill, otherwise, it's transparent.
Can you share a data + sld combo for us to test?
can I just jump in with one similar bug/issue that i noticed using
attribs from database:
If the attributes in database are numbers, and you want them to
<PointSymbolizer>
<Graphic>
<ExternalGraphic>
<OnlineResource xlink:type="simple"
xlink:href="${status}.png" />
<Format>image/png</Format>
</ExternalGraphic>
<Size>
<ogc:Literal>26</ogc:Literal>
</Size>
</Graphic>
</PointSymbolizer>
it wont work, but if you prepend some string in front of it -
"symbol_${status}.png" - it works
<PointSymbolizer>
<Graphic>
<ExternalGraphic>
xlink:href="symbol_${status}.png" />
</ExternalGraphic>
<Size>
</Size>
</Graphic>
</PointSymbolizer>
Hope it helps,
cheers!
for that column?
case sensitive)
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
http://p.sf.net/sfu/XcvMzF8H
Geoserver-users mailing list
Ivan Grcic
