On Mon, Oct 26, 2015 at 7:27 PM, okusax <federicogodan2000@anonymised.com>
wrote:
Ok, I redefine the rule as dd/MM/yyyy but the dates before 1930 now are
show
as dd/MM/00yy...
i.e: 12/01/1929 -> 12/01/0029 and 12/01/2029 -> 12/01/0029.
feature.fc_res.value?date?string["dd/MM/yyyy"]
In the database the comun is defined as Date (without hour and sec)
Using feature.fc_res.value?string["dd/MM/yyyy"] just trow parsing errors...
Parsing?... odd, which errors? I'd expect formatting ones, not parsing
ones.
No clue... what happens if you do a WFS request against that layer, how
does the output look like?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
