GeoServer 2.7.x is not supported anymore, you should try at least GeoServer 2.9.3 or
better GeoServer 2.10.1.
That said, there are known issues with Oracle and date fields, your problem seems similar to this one:
http://osgeo-org.1560.x6.nabble.com/Mapping-DATE-to-java-sql-Timestamp-in-OracleDialect-gt-jdbc-oracle-td5294871.html#a5295089
As far as I know it has not been fixed already, we did not receive a proper pull request to fix it,
nor anyone stepped up to sponsor a fix (the likeliness that someone will fix an issue relating
to a proprietary database in their spare time is admittedly quite low).
If you can provide a fix see the GeoTools thread, it should give you the right bearings, if you
are interested in sponsoring a fix instead you can check http://geoserver.org/support/
On Fri, Dec 30, 2016 at 8:28 PM, carrbrpoa <carrbrpoa@anonymised.com> wrote:
Hello,
I’ve created an Oracle store over GeoServer 2.7.2 and now I’m trying to
retrieve features data (datetime field included) through WFS’
GetFeatureInfo.
Example from date in Oracle, formatted with /to_char(MYDATE, ‘HH24:MI:SS
DD-MON-RRRR’)/:
10:07:28 30-DEZ-2016
The problem is that when I click the feature in GeoServer’s layer preview
(GeoJSON), it shows “2016-12-30Z” and OpenLayers is even worse, showing
“12/29/16 10:00 PM”.
Any ideas on how to solve this issue? I would like to consume GetFeatureInfo
in my application and obtain the datetime as Oracle stores it.
Thanks in advance!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Datetime-in-GetFeatureInfo-tp5301657.html
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
