Hi Justin,
Yea, I have noticed that my geotools build is 9.2 and the one that geoserver uses is 9.1. I see both in my maven repository.
Is there a geoserver version that uses 9.2 or can the version be overridden when I build geoserver? This sounds like it could be the issue.
I’ve done "“mvn eclipse:eclipse” and restarted Eclipse many times with no difference in behavior.
Edward Judge
Software Engineer
IBM Software Group, Information Management
INZA SW Development
Phone: 508-382-4166 IBM Marlborough
E-Mail: ejudge@anonymised.com Marlborough, MA 01752
USA
To: Edward Judge/Marlborough/IBM@anonymised.com,
Cc: “geoserver-users@lists.sourceforge.net” geoserver-users@lists.sourceforge.net
Date: 07/03/2013 02:49 PM
Subject: Re: [Geoserver-users] Debugging geoserver/geotools source
Hi Edward,
Posting here is fine but you may want to post to geoserver-devel@lists.sourceforge.net for future dev questions.
As for your question, if you have built geotools locally you should have the source attachments for all the jars in the local maven repository. Might be good to just double check this.
Other thing would be to ensure the versions match up. So the version of geotools you built locally is the one that is actually being depended on by geoserver.
Other than that you may need to another “mvn eclipse:eclipse” in geoserver just to kick the project settings. And perhaps a restart of eclipse. I have found myself doing this when it doesn’t automatically pick up source attachments.
-Justin
On Wed, Jul 3, 2013 at 12:06 PM, Edward Judge <ejudge@anonymised.com> wrote:
Not sure if this is the correct forum but I am trying to debug some geotools code used by geoserver. I have followed these instructions:
http://docs.geoserver.org/latest/en/developer/quickstart/index.html#quickstart
Geoserver starts up fine and I can debug (set breakpoints and walk through) most of the geoserver code but can’t get past the Eclipse “Source not found” error when stepping into a geotools function. I have built the geotools code myself and I am trying to debug that. I am a novice when it comes to Eclipse so I could be missing something very basic. Any suggestions?
Edward Judge
Software Engineer
INZA SW Development
USA
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-users mailing list
Justin Deoliveira
OpenGeo -
http://opengeo.org
