I’m using geoserver 2.5 and I need to increase the getinfo buffer for a point layer with the “Default Rendering Buffer” parameter.
After consulting the documentation [1] I have done several tests using the default style “point” with no result.So I tried to explain the parameter in the request:
…&buffer=100&…
and it worked.
What am I doing wrong?
[1] http://docs.geoserver.org/stable/en/user/services/wms/vendor.html#wms-vendor-parameters
thanks in advance
Michele
Hi Michele,
That should work. There was a change back in August to make it 5 pixels by default.
I’ve just tested it on a recent 2.5 nightly and a 2.4.3, and it’s not working as it should.
I’ve set buffer=100 but the GFI is only giving results up to about 20 pixels.
I’ve opened a JIRA - http://jira.codehaus.org/browse/GEOS-6437 - you’re welcome to add to it if you have further thoughts.
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Jonathan
On 31 March 2014 10:09, Michele Beneventi <mbeneventi@anonymised.com> wrote:
…&buffer=100&…
and it worked.
thanks in advance
Michele
Geoserver-users mailing list
Turns out this is because there’s a “maxBuffer” parameter that is meant to be exposed in the WMS settings gui but isn’t. Instructions on changing it are in the JIRA.
Jonathan
On 4 April 2014 14:05, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi Michele,
Jonathan
…&buffer=100&…
and it worked.
thanks in advance
Michele
